Old 05-18-2013, 07:36 AM   #61
M3Man03's Avatar
Even with the high speed gears, what kind of speed are you talking?
Team Durango DESC210R / DEX210 / DETC410 / SJF01 / F104-F1R / Tamiya 416x / TE-Maxx 3.3 / OFNA DM-1e
M3Man03 is offline   Reply With Quote
Old 05-18-2013, 11:50 AM   #62
Jstall7543's Avatar
I'm preparing the car to hit 100mph. That's the goal anyway. It might take a while. I have a gtp2e also thats closer right now.
RC is a way of life and a ridiculous hobby.
Ridiculously Fun! Subscribe to my YouTube Channel! Or ELSE! Hehee! http://www.youtube.com/user/Jstall7543
Jstall7543 is offline   Reply With Quote
Old 05-19-2013, 02:13 PM   #63
Jstall7543's Avatar
Here's what I have so far on my journey to 100mph with the ofna gt-v2e
https://www.youtube.com/watch?v=qkyi...e_gdata_player
Old 05-22-2013, 01:47 PM   #64
Jstall7543's Avatar
Here's my initial test run with the new setup. Since the back end seemed really loose with this kind of power and my light weight 3s batteries I added some weight to the rear of the car. Also the savox 1257tg had way to much responce so I had to slow that down. Out of fear I only took it up to...
https://www.youtube.com/watch?v=XcVZ...e_gdata_player
Old 05-22-2013, 02:05 PM   #65
Jstall7543's Avatar
Maybe this weekend I'll get to really open it up, its got plenty more throttle to go. I'm pretty new at these high speed passes. It's kinda scary!
Old 06-04-2013, 04:48 AM   #66
scooby61's Avatar
Anyone got a source for different rate shock springs for the gtv2 can't find anything at ofna and not sure what will fit ??
scooby61 is offline   Reply With Quote
Old 06-06-2013, 04:39 AM   #67
Jstall7543's Avatar
Im not sure but I was thinking the same thing. I added a bunch of weight to my car for speed runs and that made the car drive much better. I actually want the pro shocks but the price is insane. $120 minimum. Just like every thing else that's metal on the car is being sold like it's machined out of solid gold or unobtainium.
Old 06-06-2013, 06:52 AM   #68
scooby61's Avatar
I'm not doing speed runs I'm trying to race this thing on Sunday and seem to be at an impasse on suspension tuning. Using. Droop and ride height and shock position has got it handling ok but I'm either loose on corner exit or pushing the front at neutral power mid corner with those adjustments. Any help would be appreciated. Usaa looking at some losi truck springs that might fit. Will take the car to my lhs today and try to find something .
Old 06-06-2013, 12:47 PM   #69
Jstall7543's Avatar
What batteries are you running? If your running 4s then I would try adding some stick on weight under the rear drive shaft just a little at a time till you feel good on power out of a turn, my car was really loose in the rear and that seemed to make a nice difference on mine. This was a alternative to softer springs for me since I cant find any springs. I assume your running sweep tires or something similar because the stock tires are way to hard for serious handleing. Im running 2 3s lipos that weigh the same as 2 2s lipos so my power to weight ratio was way off without the added weight. If your tuning on the street then the handleing on a prepped track might be a lot different. I hope this helps some.
P.S. try some tire sauce if you don't have tire warmers.
Old 06-06-2013, 03:39 PM   #70
scooby61's Avatar
Good suggestions I'm running the stock rubber waiting on my good tires to come in but the weight may be what. I need since I'm running on 2-2s packs
Old 06-06-2013, 05:51 PM   #71
Jstall7543's Avatar
Cool, let me know how it works out for ya!
Old 06-06-2013, 08:41 PM   #72
jag88's Avatar
Can you buy these shocks separately ? If so where at ?
Thanks.
jag88 is offline   Reply With Quote
Old 06-07-2013, 03:54 AM   #73
Jstall7543's Avatar
The only place that has both front and rear is rcboyz on ebay Team C GT8L (same car but nitro version I think) I would verify this before ordering to be 100% sure. Nitrohouse has a lot of parts for the car but shocks are back ordered.
Rear--Check out this item I found on eBay: http://pages.ebay.com/link/?nav=item...d=350805935909
Front--Check out this item I found on eBay: http://pages.ebay.com/link/?nav=item...d=370825644551
Old 06-07-2013, 08:54 AM   #74
jag88's Avatar
Thanks for the reply. Might be the start of converting a Mugen buggy ...
Old 06-07-2013, 12:21 PM   #75
Jstall7543's Avatar
Not a problem guys. I'm going to continue running my gtp2e for on road track stuff and the gt-v2e for speed runs. My gtp was rippen on the track last summer, should be even better this summer.
What 4X4 SCT is this? coaltrain Electric Off-Road 9 10-25-2012 08:23 PM
