Old 08-01-2013, 11:29 PM   #316
Jspeed's Avatar
Originally Posted by MantisWorx View Post
I believe that you sent a PM to someone that stated that you planned on ruining GT racing in anyway possible.
For real marcus, now you're going so low as to having to make up rumors too.
Jspeed is offline   Reply With Quote
Old 08-01-2013, 11:33 PM   #317
Jspeed's Avatar
Question,
What features do you top-speed runners look for in the different speed controls and why?
Old 08-02-2013, 05:00 AM   #318
Jstall7543's Avatar
When I buy another esc for this car it will definitely run 8s, data logging would be cool I guess. XL2 is the most used from what I've seen for over 100mph. The size of the xl2 is insane.
RC is a way of life and a ridiculous hobby.
Ridiculously Fun! Subscribe to my YouTube Channel! Or ELSE! Hehee! http://www.youtube.com/user/Jstall7543
Jstall7543 is offline   Reply With Quote
Old 08-02-2013, 05:15 AM   #319
Jstall7543's Avatar
Originally Posted by Jspeed View Post
I'm building one too, the Top Speed racers are having a lot of fun.
+ YouTube Video
http://www.youtube.com/watch?v=PWXNdQ4Ptl8
I would check to see if the stock VE speed control can handle 6 cells. If it can Ipanema Top Speed Club member johnracerx just went 128 mph on 6 cells and a pretty inexpensive motor.
Not the fastest of his runs, but impressive none the least. Good way to get started, on the cheap!!
+ YouTube Video
I like the Garman set-up for recording speeds, but the Bushnell gun is good too.
From what I read the stock esc can handle 6s but the motor has a 4s limit. I have a gps and a bushnell radar gun but my wife was saying how much she enjoyed my new gps because she can film with 2 hands. That would be cool if you built speed run car too!
Old 08-02-2013, 08:14 AM   #320
JLock's Avatar
So, are the majority of you top speed guys running the Steve Neu motors?
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 08-02-2013, 11:11 AM   #321
Jstall7543's Avatar
Im the slowest of everyone I think but im running what I had Hpi tork 2650kv on mamba monster on two 3s SMC 6500mah 70c. By all means if you can afford a neu just for speed runs then get one but its not necessary unless your going for a world record.
Old 08-02-2013, 11:37 AM   #322
JLock's Avatar
Thanks for this bit of info. Right now, I am more on a learning/fact finding mission on what you guys are using and doing to hit these insane speeds. The fastest I have ever been is 142mph in an Infiniti Q45 I owned back in 1998, so just trying to imagine a scale car going that fast is amazing to me.
Texas 5
Old 08-02-2013, 02:28 PM   #323
Jspeed's Avatar
Iím leaning towards the more inexpensive 128 mph 6 cell combination that John tested in the video for right now.
Not having experience driving an R/C car over 100 mph, it seems like a safe way to get accustomed to those kind of speeds. If I can master that set-up, I would most likely step up to an all out 8 cell.
I do think I will get a speed control that can handle 8 cells well from the start, so I wouldnít have to spend the money twice.
Thatís why I appreciate any information I can get about the different features available in speed controls; research time!
Old 08-02-2013, 03:21 PM   #324
Jstall7543's Avatar
Dude, once you drive one of these car that fast you will be trippen! At first I was really scare around 70mph then I hit 86mph then I hit 97mph! Its absolutely intense!
Old 08-02-2013, 03:38 PM   #325
Jspeed's Avatar
I can only imagine how much of a rush it must be, looking forward to it!
What are the different diff gear ratios Ofna offers?
Old 08-02-2013, 04:02 PM   #326
Jstall7543's Avatar
I bought these diff gears. http://www.nitrohouse.com/ofna_gt-v2e_hop-ups.html
Then I bought a 34t 8mm bore mod 1 pinion from keshaw designs, im hoping it shows up today or tomorrow. This will replace the factory spur setup on the factory shaft. Ill be trying 34/25.
You have the pro car or the rtr? I just put these new shocks together with 80wt shock oil in all 4 what fluid are you guys running? The 6 hole pistons take some heavy fluid if you dont want the front to scrape when you brake hard. Sexy!
Old 08-02-2013, 06:03 PM   #327
Jspeed's Avatar
So 13/43 = a diff ratio of about 3.30
Does anyone make a 14T that fits the 43T ring gear?
That 14T would give a diff ratio of about 3.07 for an even higher top-end.
Gotta check into that, since the brushless should have more than enough torque to pull them.
Old 08-02-2013, 09:00 PM   #328
NiteCap2k's Avatar
Jstall
where did you find the shocks at? looks like they would fit my dm-1 it scrapes also and they would be nice to have to replace the stock ones on my gt-v2e..thanks
NiteCap2k is offline   Reply With Quote
Old 08-02-2013, 11:20 PM   #329
Jstall7543's Avatar
Originally Posted by NiteCap2k View Post
Jstall
I got the shocks on rcboyz "team c gt8l" for $121 something shipped. These are 16mm dia so you would probably need some spacers to clear the shock towers. If your car is grinding you should thicken the front shock oil or put some external limiters on or raise the ride height by tightening the springs or back off droop screws. I wound up using the rtr front springs and spring perches and 80wt fluid and it still feels a little to soft in front. The front springs that come with the pro shocks are a little to short for my taste. The rear feels perfect, alot better dampening feel with the new springs.
Old 08-02-2013, 11:24 PM   #330
Jstall7543's Avatar
Here is a small GT-V2e Road to 100mph update from some things I did today.....
http://youtu.be/5qnVpaXe9p8
What 4X4 SCT is this? coaltrain Electric Off-Road 9 10-25-2012 08:23 PM
