Sakura Zero S - Setup Thoughts & Gearing
Hey all! I'm new to the forums so please go easy on me :)
I'm currently in the process of building a 1/10 RC car & would like some input on my current setup as I will be using it for tarmac high speed runs. Please also help me on what gearing I should run for top speed & efficiency. Factory spur is 48P / 80T. My current setup consists of.. * 3Racing Sakura Zero S Touring Car * Speed Passion Reventon Pro (2S 140A) * Speed Passion 5.5R v3 (Sensored) * 2x 7.4v 5500MAH 35C / 60C Burst (Hard Case) * Power HD 1207TG Servo (Digital) * Yeah Racing Twin Fan Motor Heatsink * Kawada Pinion (48P/26T) * Yeah Racing Tornado Fan (ECU) * 4x Antenna Tubes Hop-up's consist of.. (Genuine 3Racing Parts) * Belt Tension Post * 50mm Aluminium Oil Damper Set * Chassis Downstops Protection Plate * Front One Way v2.0 * 2x 46mm Steel Universal Shafts (Pair) * Front / Rear Stabilizers & Mount Set * 4x 4mm Wheel Adapters All up it set me back $498.87 AUD inc postage & handling. I will also be using my existing Spektrum DX3S w/ telemetry receiver. Thank you all for looking & many thanks in advance for all your help! Cheers :smile: |
Bump! Anyone?!..
Check the sakura zero s thread. initial set up and gearing has been covered many times as well as all of the recommended upgrades.
