Kyosho Plazma Formula 1
#107
Just need to figure out one more hole location.
As for purchasing these parts, you will need to purchase from shapeways. I will post the link tonight.
Just a reminder that, these parts will not be plug and play. I recommend you to purchase a M3 Tap, M4 Tap, and a 3mm reamer.
Tapping the holes before installing will be beneficial as the screws kyosho supplied are not self-tapping screws. The 3mm reamer is for the upper arm because 3D printing cannot print true circles. Also, on the lower arms where the pivot balls are installed, use a dremel ball bit to smooth the inner surface can reduce binding.
#108
It will be done tonight.
#109
http://www.shapeways.com/shops/QIMB528 is the link to the models.
Remember to purchase the Plazma Ra's adjuster rods. KYO92414 - Kyosho 42mm Titanium Adjuster Rod
#110
Any one still racing the Formula Plazma? is it worth it? or should I look somewhere else? anyone has the new Drago kit yet? any comments? Thanks in advance
