TC design talk.
#166
Alright what's the public opinion on keying bulkheads on a chassis? Does it help prevent chassis tweaking or does it allow permanent tweaking? What is the census and opinions?
#168
I think the main reason is to make sure everything is positioned exactly where it should be just like with matched parts on an engine (e.g. a ported head and its manifold).
Don't think tweak is avoided this way.
#169
But if you look at what causes tweak. In my opinion its.parts shifting or moving during impact. Well pining the parts properly in the right locations in theory reduce movement and stay in its origional position . So that is why I feel like it can prevent tweak. At least until the.pins and pin hole develope slop or wear.
#170
#171
Lay-Down or Lever Shocks/Dampers for Lower CG
Does anyone want to re-visit the subject of laydown or lever shocks/dampers to lower the center of gravity? I think we touched on it previously, but there's probably much more to discuss. Manufacturers seem to have paid much attention to lowering all the other parts of the car, but we still have those huge lumps and their towers sticking way up in the stratosphere.
#173
Robitronic did that on their TC but they abandoned it along the way, not sure when, or why . Cost ? Tweak ? I don't know.
http://www.rcinfos.com/2006/2006_02_...0/P1010339.jpg
Tamiya had a super thick chassis for the 415, for foam use. They had some milling/machining under the bulkheads etc, but I think that was for the CG, not to key antyhing.
http://www.tamiyausa.com/product/ite...roduct-id=1011
#174
Keying requires extra machining hence it can not be cost cutting. I have the Robitronic car and its keys are so tight you can barely push the damn things in (I think they subcontracted manufacturing and didn't get it quite right). A good idea, but with huge costs compared to what they achieve (as far as the buyer is concerned - how much more would you be willing to pay to have bulkheads/suspension holders keyed?). I would like everything keyed, but I am not the market.
As for the shocks and their CG lowering effect, I am not so sure. I think it's not worth the effort. The CG change would be minimal. The extra complication and the inherent slop induced becomes a problem too. Tamiya put the shocks on their M01 chassis flat against the bottom, now that woudl be nice but not easily achievable in a TC. Their M01 chassis/suspension arms was/were so soft it didn't really matter if you had shocks or not, but the idea was innovative and good that way (you can not have shocks lower than that).
Right now I think even bringing the motor out on the side for the sake of lowering the top deck is pointless. I picked up an old Xray T1 and it was wonderful to drive with a stock setup on a carpet with low traction. I think centralising the weight distribution is more important than lowering the CG by a few millimeters and I would even take a punt sooner or later the centralised design the likes of T1 will be back (perhaps along with other improvements).
Right now, to keep the top deck low, I would like to try a centralised design with two spurs (so you don't have to run a belt over the motor) and a saddle pack. I think this would be as close as possible to a perfectly symmetrical weight distribution. I know it brings extra weight but with Lipos we now have a bit of room to move. Torsional rigidity of the chassis is another problem, but I imagine it can be dealt with. Just an experiment I am contemplating. If a company put something like this out, I would buy it.
#176
#177
According to the rcinfos article from Nuremberg '06 from which I took the pictures, the top plate also had pins to position itself. I believe we can see one here :
http://www.rcinfos.com/2006/2006_02_...0/P1010335.jpg
Again, they didn't keep it. And I fail to see how it would bring a more precise/reliable alignment than a well manufactured top plate with countersunk holes, or like Xray does, button head screws with a tiny cone under the head.
#178
.....or like Xray does, button head screws with a tiny cone under the head.
#179
oh, I didn't know. Any idea why ?
#180
This is now back for the BD7. All bulkheads and the split suspension mounts are keyed to the chassis, and the shock towers are keyed to the upper bulkheads. Very nice little detail. Would much rather have this that a load of bling like Ti turnbuckles and hingepins.
