Old 10-14-2012, 02:42 AM   #1
Default Body ride height
Your is your 1/10 touring car body distance to the ground? Do you usual set the rear higher?
ioxqq is offline   Reply With Quote
Old 10-14-2012, 03:05 AM   #2
I try to keep it as flat as possible, with the front valance around 0.5mm higher than the bottom of the bumper. I do sometimes raise the back end slightly, it seems to generate more steering this way.
Mb3195 is offline   Reply With Quote
Old 10-14-2012, 08:07 AM   #3
wtcc's Avatar
Put it as flat as possible without the body rubbing the floor while cornering to generate the maximum aerodynamic downforce in front. You can do some finetuning with rising the rear, but that also means to rise the center of gravity slightly.
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Will rasing rear ride height increase rear traction SC10? savannahmick Electric Off-Road 16 02-19-2011 11:24 AM
8T 2.0 Shock/Ride Height jwm2 Nitro Off-Road 11 09-21-2010 07:58 AM
SC10 ride height 253SMITTY Electric Off-Road 6 06-16-2010 10:34 AM
SEO by vBSEO 3.5.0
