Tamyia F104w GP/F104w VerII Hop-up's
Hey guys,
Does anyone know if the F104w VerII hop-up's fit the F104w GP? I'm looking to add some of the more colorful hop-up's to my car instead of black on black.
Any information would be much appreciated.
Respectfully,
CipherDec
Respectfully,
CipherDec
You need to look at the standard F104 Pro hopups. The v2 uses a different rear end.
The only thing that may work is the aluminum servo mount, new style F104v2 diff that uses 417 diff rings (nothing wrong with the F104WGP diff), and aluminum side damper. And thats about it.
What doesn't work is:
Motor mount
The carbon cross brace -replaces the plastic wing mount
The carbon upper pod plate - replaces #9 on the C tree
All the diff parts should work, anything on the front end, and the roll damper...but the roll damper on the Gp is probably the one you want anyway.
Motor mount
Well I might as well leave it as is, Its just going to be allot of black with the body. I'm having a friend do a 2012 Renault body in carbon fiber, other then driver area and helmet. I think the fake carbon fiber will pop with the gold decals. Also if I can get my hands on a set of Tamiya 51009 he's going to paint them the same gold as the real car uses.
