LRP X12 Timing Inserts >
Old 09-21-2012, 08:08 AM
Jim_1987's Avatar
Default LRP X12 Timing Inserts
Does anyone know what the LRP timing inserts are in degrees?
4 dot is minus 10 degrees, but what does this equal? 30 degrees?
Jim_1987 is offline
Old 09-21-2012, 08:43 AM
swimbikerun's Avatar
Trader Rating: 108 (99%+)
It's 27.5, 32.5, 37.5, 42.5, 47.5 if I recall correctly. 2 dot being 37.5.
swimbikerun is offline
Old 09-21-2012, 10:11 AM
Jim_1987's Avatar
Thanks.
Jim_1987 is offline
Old 09-21-2012, 10:20 AM
Are you sure thats right ?? there are only 4 timing choices thats im aware of not 5 ??
FLAT OUT is offline
Old 09-21-2012, 10:29 AM
Trader Rating: 22 (100%+)
Put two of them in backwards to go from + to -. 3 inserts will cover 5 settings.
Troy Carter is offline
Old 09-23-2012, 09:59 AM
Robert_K's Avatar
-10 / -5 / 0 / +5 / +10?
Regards Robert
Robert_K is offline
Old 09-29-2012, 03:04 AM
UrabusDenis's Avatar
Just to check, when putting eg. 4 dots inserts, you have to see the 4 dots (they are on the outside of the motor) ?
UrabusDenis is offline
Old 09-29-2012, 12:27 PM
AE-Reedy
Yes.
Also LRP has made a 30/45 degree insert. It comes with the x20 motors.
And the inserts now have the timing marked on the insert.
So too recap
4 dot 27.5
New 30
3 dot 32.5
2 dot 37.5
1 dot or 3 dot flipped 42.5
New flipped 45
4 dot flipped no marks 47.5
Sean Cochran is offline
Old 09-30-2012, 09:52 AM
X12 Vector brushless modified:
oooo: X-10º
ooo: X-5º
oo: X
o: X+5º
-: X+10º
I read: adjustable timing (LRP X12) is to set-up the motor to different speed controllers. Recommended for Xerun?
Thanks and regards,
TyoBBS is offline
Old 07-15-2013, 07:49 AM
mac853's Avatar
Questions??
Just want to ensure 1 thing:
If I use X12 motors in my Tekin RS but with sensor wire unplugged, that means motor timing with insert is totally disabled, isn't it?
mac853 is offline
Old 07-15-2013, 08:37 AM
Correct no sensor wire no sensored timing advance.
Smartypants is offline
Old 07-15-2013, 08:58 AM
mac853's Avatar
Questions??
Maybe this is the reason to allowing 13.5T sensored motors mixed with 3500KV sensorless but no sensor wire allowed
Thanks!
mac853 is offline
