Old 11-06-2012, 02:11 AM   #1396
Originally Posted by jlfx car audio View Post
Is everyone building per kit suggestions . I really don't like the ball stud on inner links. Its only 4mm long and has a2mm shim in there also its scary. Think iI'm going to have to order some 6mm/8mm studs just to keep my mind at ease . ..
Has anyone tried running no shims under inside and 2mm outside in rear ?
And front 1mm inside and 0mm out side front ?
This would keep same link angles & length but lower them.
I never liked the short links on the '12 however on the t4 the feeling is totally different. I started with the middle links but changed to shorter links to try and actually preferred it. On the '12 I always felt the car would roll far too much but as the t4 cog is so much lower, the short links feel more like the middle links did on the '12
Mb3195 is offline   Reply With Quote
Old 11-06-2012, 03:05 AM   #1397
morgoth's Avatar
I'm running 2.5mm shims in the front with the 4mm ballstud and no problems so far :-) There's enough thread left to tighten them.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 11-06-2012, 06:22 AM   #1398
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Yea u can tighten them but u need at least 3threads to get full strength of metal . But in the event of a accident on the sweeper I know what that short stud will do
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 11-06-2012, 06:34 AM   #1399
bvoltz's Avatar
Trader Rating: 44 (100%+)
I think the point here is it will work, just don't hit anything... I changed mine out because of the pinball effect on a carpet track. I'm not saying I don't started it....
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 11-06-2012, 07:18 AM   #1400
Same here . Hopefully my longer studs will be here Friday
Justin & Matt Lyons
a800s sanwa m12s
Old 11-06-2012, 09:01 AM   #1401
Skiddins's Avatar
Must confess I fitted 6mm ball studs from the start of the build.
I was never worried about there not being enough thread in the clamps, they'll be fine, but I did want the option to be able to use everything from no shims on the clamps up to 4mm and everything inbetween if I wanted.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-06-2012, 02:05 PM   #1402
transplantlife's Avatar
Trader Rating: 43 (98%+)
Default BNIB T4 FOR SALE
BNIB XRAY T4
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 11-07-2012, 08:19 AM   #1403
Jerz616's Avatar
Trader Rating: 49 (100%+)
What was the degree of steering on the T4. I got mine all together and seems like its a max of 26*. This sounds like what was talked about buy not sure. My '12 could go to about 30* before any binding.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 11-07-2012, 08:29 AM   #1404
Nico''s Avatar
Yes it's 25 on the T4.
30 is too much for driveshafts and it slows the car.
25 is the best, if you car does'nt turn enough with 25, you need to find another way to have more steering and your cornerspeed will be increased.
Nico' is offline   Reply With Quote
Old 11-07-2012, 08:30 AM   #1405
Trader Rating: 15 (100%+)
Read this:
http://www.teamxray.com/teamxray/new...the T4, Part 1
Specifically, this part:
We had made a lot of progress in recent years, but we still felt that there was something missing or something not completely perfect with our steering system. Specifically, when I was observing our cars on carpet, I saw that we have a lot of steering on corner entry (which was good), but then the car kind of ‘stopped’ as it slowed down and then in the middle of the corner the car started to push.
After thinking and discussing the potential causes of our problem I came up with a very simple idea - to test a different servo linkage mounting position. Our main observation was that on the T3 when you set-up steering you have 25 degrees, but in reality it is always more as the force from the wheel touching the surface will overpower the servo saver and therefore in reality would steer more(allowing as much as 33degrees of throw). This excess steering angle resulted in the car having the “stop” effect in the corners. The driver would feel as though they have lots of steering, but it was only an illusion.
The initial idea to test and prove this theory was to glue backstops on the C-hub (simple alu shims) which would stop the steering block at exactly 25 degrees. In the first test I felt initially that the car had less steering but since the “stop” effect was removed I was able to reach higher cornering speeds and the car was much easier to drive which of course translated into improved lap times. With our theory proven, I now had to figure out how to change the steering system to limit the steering at 25 degrees without allowing the steering block to touch the C-hub. The solution was very simple indeed. I added a large mounting bushing on the central alu steering plate where the servo linkage is mounted. When the steering reaches 25 degrees the alu shim works as a backstop and limits the steering throw to the maximum 25 degrees.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 11-07-2012, 08:43 AM   #1406
ByteStream's Avatar
I measured 27 degrees when using the aluminum bellcrank arms, they are thinner than the plastic arms by a small amount. I'm still not at 100% dual rate so it doesn't really matter.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 11-07-2012, 08:53 AM   #1407
artwork's Avatar
Trader Rating: 56 (100%+)
Even if you need a little more steering...which people probably do not you can grind on the plastic steering rack arms to provide the additional three degrees that people will never use. I would not grind on those pretty aluminum arms...but plastic is cheap . 25 Deg of Mechanical steering is more then anyone would ever need for most applications.
Sounds to me like you got a little Xtra there Joey...(you can take that where ever you would like)
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 11-07-2012, 09:55 AM   #1408
Jerz616's Avatar
Originally Posted by LloydLoar View Post
Read this:
Thanks. That was a great article. I haven't ran mine yet, but just wanted to make sure my steering was set right.
Ryan Gracey
XRAY XB8'14
Old 11-07-2012, 07:22 PM   #1409
Xpress's Avatar
fyi rcmarket has T4 option parts in stock...
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 11-07-2012, 07:23 PM   #1410
Jerz616's Avatar
My T4 all ready for it's first run tomorrow.
The New Xray T4 '13-t4.jpg   The New Xray T4 '13-t42.jpg   The New Xray T4 '13-t43.jpg
Ryan Gracey
XRAY XB8'14
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
