Old 11-03-2012, 03:17 PM   #1321
Originally Posted by Skiddins View Post
Is this a problem on the rear left by any chance.
You might find that the rear front toe block is not pointing inwards as it should (it twists as the screws are tightened)
I posted about this when I built the car.
You need to hold that block pointing inwards with a spanner or pliers while tightening the screws.
Skiddins
It is the rear. I have assembled the block a couple of times holding both times but I'll try again taking all suggestions on board to see if I can free it up.
He who dies with the most toys wins, if it's a tie, then it's he with the best.
sjh28 is offline   Reply With Quote
Old 11-03-2012, 04:56 PM   #1322
Mikkel_R's Avatar
Some more racing tonight at Newbury in the UK.
In practice tried 2.7 rear springs so I had the same at both ends. This did increase initial steering and made the car more aggressive, but it resulted in the rear breaking loose if you weren't smooth (virtually how my T3'12 was)
Went back to progressive springs.
Next up, more bump steer. I got a former national winning driver to try my car and he said it had lot of initial but lacked mid.
So I added 1mm of bump steer which helped mid corner, added another 1mm for the final so I ended up running 3mm bump steer.
Also tried a gear diff with 2000cSt instead of 1000cSt.
Although the 2000cSt diff didn't appear much faster, 0.02 etc, it did make the car feel more consistent so I was able to stay closer to my fastest laps more often.
So by the end of the evening had kit carpet setup except; 3mm bump steer, 2000cSt in diff and the rear shocks were in the top hole. LTC-R body.
Car felt very good, got my fastest lap to within 0.25s of our 5 times BRCA national champion Chris Grainger's fastest (which is superb by my standards )
Hopefully they'll put the video's up tomorrow so I'll link to it so you can see the results of the changes
Have you tried a different bodyshell to carm the steering down. Best neutral handling shell ive found is the Mazda speed 6.
Mikkel_R is offline   Reply With Quote
Old 11-03-2012, 06:17 PM   #1323
Skiddins's Avatar
I started with the Speed 6 last week, but the LTC-R was 0.2s faster per lap
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-03-2012, 08:44 PM   #1324
whiteflagwar's Avatar
Raced my t4 today for the first time. It felt so good! Rather than being two or three laps down I was only one lap down now if I could learn to drive I could possibly be on the lead lap!
whiteflagwar is offline   Reply With Quote
Old 11-03-2012, 09:08 PM   #1325
Jerz616's Avatar
Trader Rating: 49 (100%+)
It did look good. Heading back to mikes tomorrow to get mine. Although my t3 didn't fair too bad.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 11-03-2012, 09:32 PM   #1326
Brokin Racing's Avatar
Trader Rating: 68 (100%+)
2nd T4 arrives next Tuesday, just need time to build'em...
Xray - LRP - PF - Futaba -
Brokin Racing is offline   Reply With Quote
Old 11-03-2012, 10:04 PM   #1327
B00t13g's Avatar
Car looked good homie. I'm glad you're happy with it!
B00t13g is offline   Reply With Quote
Old 11-04-2012, 12:42 AM   #1328
Jerz616's Avatar
I think this was talked about but I can't find the answer I was looking for. I am guessing the ESC from '12 will work on my T4 when I get it, but what about other brands aside of X-ray make decent ones. Anyone use the spec r? I'm guessing the v2 is better then the older ones I obliterated in my '11. Or do we not even need them with the new car.
Ryan Gracey
XRAY XB8'14
Old 11-04-2012, 01:35 AM   #1329
Skiddins's Avatar
Are you talking about ECS driveshafts?
If so I haven't fitted any yet. All the parts I've used are in the kit except for heavier diff oil.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 11-04-2012, 07:01 AM   #1330
Jerz616's Avatar
Yes. The ECS not ESC. I had a bout of dyslexia last night. So the stock drives seem to be fine? No chatter or anything.
Ryan Gracey
XRAY XB8'14
Old 11-04-2012, 07:02 AM   #1331
Jerz616's Avatar
Hey Cole were you running any ECS shafts or just kit shafts. I wonder if AWD was running kit or ECS. Trying to figure out what to get.
Ryan Gracey
XRAY XB8'14
Old 11-04-2012, 07:52 AM   #1332
haywood's Avatar
Get the Hudy or Spec R version 2! I only run the Hudy Ecs but always have a spare set handy! Heatshrink the joints to save from a major failure if the set screw comes loose!
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 11-04-2012, 08:34 AM   #1333
Standard drive shafts.
Old 11-04-2012, 09:06 AM   #1334
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
Unsettling to see the xray block system is still giving people headaches.
EXOTEK I have a mission for you
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 11-04-2012, 09:36 AM   #1335
B00t13g's Avatar
I would also look into the rsd ones. I believe that is what Andrew is running.
RC10B4/T4 Forum DerekL Electric Off-Road 14338 11-18-2017 04:19 PM
Xray T3 2012 rasta_man Electric On-Road 4227 11-14-2017 05:49 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Allan drake
