Old 11-01-2012, 05:07 PM   #1291
bvoltz's Avatar
Trader Rating: 44 (100%+)
Hope you find this helpful...
Attached is shows the largest possible 64P pinion that will fit on the T4. In some cases you will need to use a Ball End to get to the motor screws.
Your other option is to put the gear on after installation of the motor, which is my personal preferred method.
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 11-01-2012, 08:09 PM   #1292
bozzplayer's Avatar
Trader Rating: 16 (100%+)
Hey guys, so i started the build on my new t4, and am loving it so far, just had a very small issue with the parts in the the bag, I'm missing 1 of the hats that go into the c-hub (the smaller hat) and also i am missing 1 shim that goes behind the satellite gears in the gear diff (#964031), was wondering if anybody else had any issues with small missing parts, I'm lucky that i have a bunch of extra parts from my t3 12 or else i would be fiddling with my thumbs waiting for these little parts.
bozzplayer is offline   Reply With Quote
Old 11-01-2012, 08:12 PM   #1293
defcone's Avatar
Trader Rating: 15 (100%+)
I thought I lost one of the hats as well, but it was stuck on one of the parts tree.
defcone is offline   Reply With Quote
Old 11-01-2012, 09:19 PM   #1294
bozzplayer's Avatar
ya, no such luck for me
Old 11-01-2012, 10:09 PM   #1295
Nico''s Avatar
Hi,
Do you know please when optional anti-roll bars will be available please?
( and 2,3 and 2,9 springs please?)
Thanks,
Nico'
Nico' is offline   Reply With Quote
Old 11-01-2012, 10:34 PM   #1296
trigger's Avatar
I too thought I was missing the washer that goes behind the satellite gear but found it stuck to another washer. My kit was luckily 100% compete.
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 11-01-2012, 11:05 PM   #1297
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Missing one M3x8 flathead screw. No biggie....all I have left now are to do the shocks.
This is the first time I've built an Xray brand new. Its coming together really solid. Will definitely be much harder for me to goto a lesser quality car.
Dan is offline   Reply With Quote
Old 11-02-2012, 01:49 AM   #1298
Only issue I had was one of the rear arm hinge pins slightly bent making the arm a little stiff. Will have to look at replacing at some stage.
I find the pinion grub screw hard to get to; the hole doesn't line up with the screw and the top deck gets in the way.
He who dies with the most toys wins, if it's a tie, then it's he with the best.
sjh28 is offline   Reply With Quote
Old 11-02-2012, 02:22 AM   #1299
Skiddins's Avatar
Are you absolutely sure the pins were bent, one of the arms I had was a bit stiff on the pin so I reamed it out, too a while but worked fine.
If you're unsure about a pin, roll it across a dead flat surface, if it 'bobbles' it's bent.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-02-2012, 05:00 AM   #1300
Team EAM
EAMotorsports's Avatar
Trader Rating: 78 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by jlfx car audio View Post
EA where is ur set up compaired to Andrews? Sunday I will still be roling my T3 but hopefully by next race day I can be converted into my T4
Justin
I am not sure. I haven't looked at his or written mine down yet. I am out of town this weekend and will be back next. Dirla wasn't there last week to give your motor too. I can ship it when I get home or bring it next week.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 11-02-2012, 05:21 PM   #1301
Skiddins's Avatar
Some more racing tonight at Newbury in the UK.
In practice tried 2.7 rear springs so I had the same at both ends. This did increase initial steering and made the car more aggressive, but it resulted in the rear breaking loose if you weren't smooth (virtually how my T3'12 was)
Went back to progressive springs.
Next up, more bump steer. I got a former national winning driver to try my car and he said it had lot of initial but lacked mid.
So I added 1mm of bump steer which helped mid corner, added another 1mm for the final so I ended up running 3mm bump steer.
Also tried a gear diff with 2000cSt instead of 1000cSt.
Although the 2000cSt diff didn't appear much faster, 0.02 etc, it did make the car feel more consistent so I was able to stay closer to my fastest laps more often.
So by the end of the evening had kit carpet setup except; 3mm bump steer, 2000cSt in diff and the rear shocks were in the top hole. LTC-R body.
Car felt very good, got my fastest lap to within 0.25s of our 5 times BRCA national champion Chris Grainger's fastest (which is superb by my standards )
Hopefully they'll put the video's up tomorrow so I'll link to it so you can see the results of the changes
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 11-02-2012, 05:48 PM   #1302
Hi Skiddins,
Did you use the kit 350 shock oil and roll centre positions ??
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 11-02-2012, 05:53 PM   #1303
That's exactly what I did to confirm it is bent. The arm moves free until the blocks are tightened, I tried reaming the arm but the reamer is like a d*ck in a bucket.
Old 11-02-2012, 06:28 PM   #1304
Trader Rating: 38 (100%+)
Originally Posted by d.k.vmatt View Post
The new t4 is narrower
This is incorrect BTW.
or8ital is offline   Reply With Quote
Old 11-02-2012, 08:49 PM   #1305
Regional Moderator
CarbonJoe's Avatar
Loosen the screws for the hinge pin holders, push the arm towards the hinge pin holder and tighten it. Then press the arm towards the other hinge pin holder and tighten it.This prevents the hinge pin holders from tweaking when you tighten them, making them square to the arm. Result: arms move freely.
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
