Old 10-30-2012, 04:19 PM   #1246
Skiddins's Avatar
Originally Posted by bucketboy View Post
Yes but it makes the steering much more precise
If you're referring to the link with the servo saver, it would be more precise at the higher point as it take a larger movement of the servo to make the same movement of the wheels.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-30-2012, 04:27 PM   #1247
Xpress's Avatar
Skiddins
I think you have that backwards. The longer the lever the less rotation required for a given amount of steering throw.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 10-30-2012, 04:33 PM   #1248
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Yes, the longer the servo horn, the more speed and travel, at the expense of torque and resolution.
Old 10-30-2012, 05:15 PM   #1249
syndr0me's Avatar
Trader Rating: 32 (100%+)
Didn't Hudy buy up an entire batch of Hanulec's spool outdrives for their own use?
syndr0me is offline   Reply With Quote
Old 10-30-2012, 05:28 PM   #1250
Skiddins's Avatar
Yep, you're correct, after staring at my steering linkages etc it all became clear
I don't really want to have to butcher the saver, but I don't think full lock is achievable in the lower central position without modifying the saver.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-30-2012, 08:35 PM   #1251
bozzplayer's Avatar
Trader Rating: 16 (100%+)
Got my car today,will start building her tomorrow, any tips for the build
bozzplayer is offline   Reply With Quote
Old 10-30-2012, 09:06 PM   #1252
Xpress's Avatar
Are you referring to the soon to be invented and patented by Xray optimized spool outdrives?
-Espo
Old 10-30-2012, 10:27 PM   #1253
syndr0me's Avatar
What ever could you mean?
Old 10-30-2012, 10:34 PM   #1254
defcone's Avatar
Trader Rating: 15 (100%+)
That's a different concept to the xray ones.
defcone is offline   Reply With Quote
Old 10-31-2012, 01:35 AM   #1255
Skiddins
Some may call it "butchering" if prefer the term "optimization"
Bb
bucketboy is offline   Reply With Quote
Old 10-31-2012, 03:40 AM   #1256
On my T3 never used the plastic ones, i use this ones released on Nov,2011:
Solid Axle Driveshaft Adapter - HUDY Spring Steel™
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 10-31-2012, 04:55 AM   #1257
C@T
C@T's Avatar
XRAY can even do better:
305136 Alu Solid Axle Driveshaft Adapters (2) - Hard Coated
release date: Sep. 19, 2008
C@T is offline   Reply With Quote
Old 10-31-2012, 06:14 AM   #1258
Originally Posted by Mikkel_R View Post
If Corey could post what set up changes he would make on a very low grip track and explain why that would be great.
Michael
Unfortunately, every track surface is different and each change may not work across the board. Another thing worth mentioning is depending on the carpet and what the the layout looks like, you might find that the track offers more forward bite than lateral grip, and vice versa. Before making any siginificant changes make sure that you are NOT chasing the track, speaking to locals about what the tracks does throughout the day helps greatly, but if its brand new carpet like IIC, Indoor champs or Snowbords, just wait for the grip to come up before taking a big swing at it. Lastly, sort out your tire prep as you may be able to get allot more grip just by adjusting the length of time your compound sits on the tires or the type of compound.
Below is what I have found to work from both testing with Andrew and from when I used to race.
To increase forward bite:
Stand up shocks
Less camber
More rear toe
More front droop
Higher rear roll center
Thinner rear diff oil
Spool
To increase side bite:
More droop all round
Shocks in
More camber
Shorter links
Lighter swaybars
Lighter springs
Lighter oil
Keep in mind, you can go too far with any of these changes and end up going the wrong direction.
CoreyW. is offline   Reply With Quote
Old 10-31-2012, 06:30 AM   #1259
Skiddins's Avatar
The trouble with Xray's outdrives for blades is that a lot of the blade is left exposed which means you wear a groove in them.
On Xray's forum I mentioned that they needed better outdrives for their spools.
Perhaps they've listened
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-31-2012, 06:40 AM   #1260
Meradin's Avatar
Trader Rating: 19 (100%+)
Corey, can you explain what forward bite is? Do you mean traction going forward? I don't think I have ever had a car just spin it's wheels unless on pavement. I only race on carpet. The only weird handling issue I have ever faces is a back end that wont stay planted when I pour on the power at the apex of a turn. The back end comes loose. Would that be lateral grip?
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
