Old 10-25-2012, 01:31 AM   #1021
Oh dam i was about to fit my 1257-tg in her.... Yet another issue with this car...
Tamiya F104 V2, TT-01E CS Drifter
XRAY T4 '13
Yokomo R12C3
d.k.vmatt is offline   Reply With Quote
Old 10-25-2012, 01:35 AM   #1022
there are 6 holes in the servo saver why not use one of the other 5 if your servo fouls
Bb
bucketboy is offline   Reply With Quote
Old 10-25-2012, 01:39 AM   #1023
silvalis's Avatar
Trader Rating: 29 (100%+)
Originally Posted by bucketboy View Post
Already had ECS drive shaft, they give a smoother front end, fitted better bumper because I go club racing, modded the shock collars to take the longer springs that I already have, mounted a fan to a servo post attached to the layshaft bulkhead, added some electrics, fitted some tyres, sprayed up a body and off I went.
Better than the T3 12
Bb
What did you do to the shock collars?
I've got a set of ride springs I dont really want to part with yet...
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 10-25-2012, 01:50 AM   #1024
explanation a couple of pages back. I've got Hpi springs on mine, can get ride height down to under 5mm.
Mb3195 is offline   Reply With Quote
Old 10-25-2012, 01:56 AM   #1025
Skiddins's Avatar
Originally Posted by bvoltz View Post
Wow the Shock build was great... 0 rebound....
So let me ask why do some not use the o-ring at the bottom?
If you're talking about the O-ring on the setup sheets, it isn't the O-ring in the shocks, it's an O-ring on the bottom of the shock shaft to limit up travel in an attempt to reduce grip roll, you used to sometimes see it on carpet setups.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-25-2012, 02:00 AM   #1026
mate, I bought a 1257Tg specifically for this kit... Gosh it is really annoying
cheapskate.brok is offline   Reply With Quote
Old 10-25-2012, 02:10 AM   #1027
Bb
Hi Bucketboy, Can you post a picture of the way you have mounted the fan please.
Bryan D is offline   Reply With Quote
Old 10-25-2012, 03:17 AM   #1028
I don't think its an issue with the car, just one more reason out of many to not use a savox
Sean B. is offline   Reply With Quote
Old 10-25-2012, 03:25 AM   #1029
Like this. Use a servo post with a grub screw at the end of it, then screw the post into the spare hole in the bulkhead, then just screw a fan to the post. Perfectly positioned.
Old 10-25-2012, 04:12 AM   #1030
Great thanks for that.
Old 10-25-2012, 04:44 AM   #1031
NR
NR's Avatar
Trader Rating: 52 (100%+)
Does it actually blow like a tornado.
I feel that the small yeah racing Tornado fans would be just as powerful yet 3 times smaller. I could be wrong
NR is offline   Reply With Quote
Old 10-25-2012, 05:01 AM   #1032
these fans cost 3 each though! Plus they are 5v so when you have 8.4v running through them they do certainly whizz!!
Old 10-25-2012, 05:29 AM   #1033
Skiddins's Avatar
http://www.nmbtc.com/fans/part-numbe...L-01W-B50/4966
That's the highest airflow 40mm fan I have yet found (still looking for stuff that's faster) It is 20mm deep and is a lot faster than the standard LRP fan.
8.1CFM
It's 5V so it needs to run off the receiver.
Haven't found a 5V fan that can push more air than that
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-25-2012, 05:31 AM   #1034
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Umm, how about removing the rubber grommets ?
Originally Posted by cheapskate.brok View Post
you have to be careful in your servo selection, for example a Savox 1257TG will cause the steering post/arms/bellcranks/whatever to bind because its too tall. Pictures is a low profile 1251MG with a lower servo height
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 10-25-2012, 06:05 AM   #1035
i went to a not so local hobby shop and picked up a 1251mg. so ill be good to go
XRAY T4 '13
Yokomo R12C3
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
