Old 10-24-2012, 12:34 PM   #991
Skiddins's Avatar
Originally Posted by EAMotorsports View Post
No its not possible to run the same body on both. The holes are just far enough off on the new car that you cant put a 2nd set in your old body as they will hit part of the old holes too. Its shorter and narrower.
EA
Originally Posted by nashrcracer View Post
now I'm going to have to spend time tonight painting a new body
Yes it is, see my above post.
On the T3 the posts mount on the front of the rear shock tower.
On the T4 the posts mount behind.
Although you can mount them either way.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-24-2012, 12:44 PM   #992
bvoltz's Avatar
Trader Rating: 44 (100%+)
We have seen your paint job, this should be a 15min job....
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 10-24-2012, 12:50 PM   #993
samnelso's Avatar
Thx. I think I can live with this.
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 10-24-2012, 01:00 PM   #994
Send a message via AIM to RCing15
Default Steering rack mod!
About a week ago I was thinking that the steering rack should be mounted on top of the steering arms. This would raise the cross-member and you would be able to use less shims at the steering knuckle and on top of the cross-member. This would allow the steering to move further and the cross-member to be supported versus hanging from steering arms.
I started taking apart the steering on my T3 11 to see what I could come up with. I flipped the steering post and mounted it upside down with a 1.5mm shim between the post and chassis. I flipped the steering arms and mounted the cross-member that I previously drilled and tapped a hole between the Ackerman mounts.*
The steering arms barely clear the belt and the belt slightly rubs the right side steering arm. With some minor tweaking this could be done. The drag link clears the top deck too. I'm currently having a friend mill/lathe some old posts to try this on the T4.*
I'm hoping the steering posts on the T4 have a wider stance then the T3 and that will make the belt clear the right side and with some shimming of the post it will clear the belt. I will let you guys know how it works out when I get my T4.
Jeff Hastings*
RCing15 is offline   Reply With Quote
Old 10-24-2012, 01:01 PM   #995
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
I have always mounted my post on the back of the shock tower to get them farther back. That explains why your body mount holes are so far apart. If youve always mounted them on the back of the tower they will overlap each other a little. Just enough to not be able to use the same body with 2 sets of holes.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 10-24-2012, 01:19 PM   #996
I just received shipping confirmation that my pre-order from NexusRacing.com has shipped! Anyone else?
rafyel is offline   Reply With Quote
Old 10-24-2012, 01:36 PM   #997
morgoth's Avatar
Steering mods are not needed. This car has tons of steering with the stock setup. My friends that drive stock classes can't drive it because it has too much steering
And remember, more angle on the wheels is less corner speed.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 10-24-2012, 01:46 PM   #998
Skiddins's Avatar
Jeff Hastings*
Remember that even though you will be using less bump shims, you are effectively changing the inner pivot point for the steering link, which means you are altering the way bump steer will be applied through the suspensions range of travel.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-24-2012, 01:56 PM   #999
Skiddins's Avatar
This bit (despite being true and important) just doesn't sink in to far too many people.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-24-2012, 02:53 PM   #1000
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
If I'm not mas taken isn't it the outside wheel that carries most of the traction around a corner . So wouldn't running more toe in give more outside tire angle?
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 10-24-2012, 03:01 PM   #1001
Skiddins's Avatar
Yes, but you're changing the suspension geometry in other ways.
This is one of the reasons we can adjust ackermann to allow the outside wheel to turn more while maintaining toe.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-24-2012, 03:03 PM   #1002
Yes but more likely to grip roll and getting it to go in a straight line might be difficult. .5-1 degree toe out is the norm, if you grip roll try adding a bit more. I never run toe in.
Bb
bucketboy is offline   Reply With Quote
Old 10-24-2012, 04:15 PM   #1003
Regional Moderator
CarbonJoe's Avatar
That will take you about 5 minutes, tops.
Are you going to run it at the Halloween Classic this weekend?
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 10-24-2012, 04:33 PM   #1004
superspeed's Avatar
skip the window masks and decals, lol.
superspeed is offline   Reply With Quote
Old 10-24-2012, 04:40 PM   #1005
bucknuts's Avatar
Nexus shipped mine as well
Btw for all those with reusing a T3 body, just shoe scrap lexan over the area of the body for the holes
bucknuts is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
