Old 10-17-2012, 11:46 AM   #751
bvoltz's Avatar
Trader Rating: 44 (100%+)
Originally Posted by Kensei View Post
Not what I was looking for.
In the end it seems as if, like with other cars, I have to drill the shock cap (part number 308333) myself.
Any comment on using the shock foam insert? I mean as to using it or not.
What are the preferences as to the use of 3- or 4-hole piston?
No foam...
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 10-17-2012, 11:46 AM   #752
M-Technic's Avatar
Trader Rating: 15 (100%+)
There is no sense is having the hole in the cap if you run the foam insert, as it blocks the hole. So if you are going to run the hole in the cap, run without the foam insert. This allows the bladder to collapse and the air to escape out of the cap, letting you run 0 rebound easily.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 10-17-2012, 11:51 AM   #753
Skiddins's Avatar
4 hole 1.1mm pistons.
Whats the point in using the foam inserts if your trying to get zero rebound and drilling a hole
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-17-2012, 11:55 AM   #754
Fred Hubbard's Avatar
Originally Posted by artwork View Post
I heard it was on this one;
ROFL.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 10-17-2012, 02:39 PM   #755
Fjeld's Avatar
it is hole in the caps how are in the kit
|| Yokomo BD7 2015 || XRAY T4'15 ||
|| Muchmore Fleta POWER :D ||
Fjeld is offline   Reply With Quote
Old 10-17-2012, 03:14 PM   #756
Probably. I heard it was Somali pirates.
Sean B. is offline   Reply With Quote
Old 10-17-2012, 03:16 PM   #757
artwork's Avatar
Trader Rating: 60 (100%+)
Probably the Yokomo guys trying to find parts that don't break when you sneeze on them (otherwise known as Somali Pirates).
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 10-17-2012, 03:35 PM   #758
Is there any other little things people have noticed while building these cars?
I've got my kit on order so once it gets here ill need all the help I can get to build it correctly.
Carpet: Tamiya M05V2 R
Asphalt : Tamiya M07 , Xray T4'17
d.k.vmatt is offline   Reply With Quote
Old 10-17-2012, 03:59 PM   #759
Ran mine for the first time tonight. Really impressed, generates more traction and drive out of the corners than the t3, also easier to drive, you don't feel like you have to drive the nuts off it to be fast with it, whereas I always felt the t3 needed to be on the limit to be quick.
Overall, very happy!
Mb3195 is offline   Reply With Quote
Old 10-17-2012, 04:21 PM   #760
mikeohara's Avatar
couple of real quick questions, as I'm looking to get back in the hobby and I'm eyeing the T4 as my possible on-road kit purchase.
a.) What does Rubber-spec mean? I remember when I looked at XRay cars before (T3 '10 and '11) they also made a US version. Does rubber-spec mean that if the car hits a rail (just using this as an example), it doesn't come apart? Forgive me if I seem ignorant, I really am not.
b.) What normally is easiest to break on XRay cars? My wife sees a(n) giant money hole if I go back to racing RC (my other hobby choice is tabletop games) with no end in sight. Can I be prepared ahead of time if something were to break?
c.) Could someone recommend me a radio/ESC and Motor/servo kit to go along with this that wouldn't break $1200?
mikeohara is offline   Reply With Quote
Old 10-17-2012, 04:45 PM   #761
Regional Moderator
CarbonJoe's Avatar
Rubber spec is a chassis designed for rubber tire racing.
In a full year of running the T3 '12, I've only broken one rear upright. That's it.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 10-17-2012, 05:31 PM   #762
mikeohara's Avatar
Interesting to know. I'm kinda rough on stuff, so I'll make sure to get a few parts from the LHS (I have two within a couple hours of me) to tide me over in case I break something.
Old 10-17-2012, 05:47 PM   #763
ByteStream's Avatar
+1
One rear upright for the year as well for me .. it didn't really break, but a hard side hit ripped the ballstud from the upright, (with the other hole ocupied by a set screw). I probably could have threaded it back in with a drop of glue, but why bother .. $8 in parts for the year, not bad.
I have lots of spare parts collecting dust.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 10-17-2012, 05:52 PM   #764
silvalis's Avatar
Trader Rating: 29 (100%+)
1200. That's fairly easy. I would figure your budget something like this
550 = kit
100 = tyres, body, misc bits
100 = low profile servo. I'd look at the Futaba 9551, about 85 bucks. Or you could go cheaper, such as a spektrum for 60.
100 = motor. Pick a turn and a brand.
150 = ESC. Sort of depends on what class you are going to run. If you're running something like a 17.5 or VTA you could get away with a hobbywing juststock (100 bucks) or whatever. If you're running boost or mod, expect to pay 150 to 200 for a hobbywing v3, lrp, tekin, speed passion, viper.
200 = Transmitter. You could go cheap and buy a futaba/sanwa for 100 to 150, splurge a bit on a mid-high end radio like a futaba 4PL or Sanwa MT4 for 250-300 or go supercheap and get a flysky for <50.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 10-17-2012, 06:29 PM   #765
mikeohara's Avatar
550 = kit
Thanks for the help, I'll keep that in mind!
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
