Old 10-17-2012, 01:16 AM   #721
Originally Posted by bucketboy View Post
Think is because of the torque of the screws on the blocks, put a small spanner over he block to hold it still while you tighten up the screws, might help.
Bb
+1 on the screw torque thing
I solved this issue by first installing the whole suspension assembly with the screws holding the blocks still loose and tightening them in the end.
Works just fine
Regards David
niemand is offline   Reply With Quote
Old 10-17-2012, 01:32 AM   #722
Skiddins's Avatar
Bb
Works just fine
Regards David
OK, guys
I will try that later.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-17-2012, 01:42 AM   #723
Skiddins's Avatar
Originally Posted by azwan View Post
the chassis edge look great. how u do it? just sand with sandpaper? what grit of sandpaper?
Start with 120grit to take the 'sharp' edges off the chassis (I also do the shock towers, just because they look better)
Then smooth it slightly with 600grit.
I then use a Sharpie pen or similar to blacken the edges of the chassis before using the superglue/crazyglue.
I then run a 'bead' of superglue all around the chassis edge, then leave to dry.
Sand with 600 grit
Another couple of coats of superglue (allow to dry inbetween), then depending on how smooth you can use either 600grit to remove any roughness again or straight to 1200-1500grit to smooth it right out.
Superglue never dries completely evenly, hence the sanding
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-17-2012, 05:53 AM   #724
Skiddins's Avatar
Bb
Works just fine
Regards David
Just did it, worked perfectly
If anyone else is thinking of using a spanner to hold the block in position while screwing it on, you'll need a 5mm
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-17-2012, 06:30 AM   #725
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
R u refering to the screw/nut holding the front of the motor mount ?
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 10-17-2012, 06:34 AM   #726
No, that one is 5.5mm.
Regards David
Old 10-17-2012, 07:06 AM   #727
Sorry guys don't get it? Torque of what screws?? If u have a countersunk hole and a flat head scre that is suppose to sit in the countersunk hole and the thread is straight. And to top it off u have a flat surface of the chassis and a flat surface of the pivot block how can it be tweaked slightly??
Surely only a default with the mounting holes of a defect with the screw will allow it not to sit perfectly?
Ok I understand its not a major thing to be concerned with as it straightens easily but I just thought I'd put my 2 pence's worth in.
P.p.s my 2 t4's got delivered today so am so excited but at work now to finish and build!!!!
Jampot is offline   Reply With Quote
Old 10-17-2012, 07:12 AM   #728
bvoltz's Avatar
Trader Rating: 44 (100%+)
It is the hole that the nub sets in. It may allow for a very small amount of movement. In the manual it shows how you should put pressure when tighting the screw.
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 10-17-2012, 07:18 AM   #729
superspeed's Avatar
Will there be a U.S. Foam version
superspeed is offline   Reply With Quote
Old 10-17-2012, 07:24 AM   #730
Trader Rating: 38 (100%+)
I'm sure that would be a big seller.
or8ital is offline   Reply With Quote
Old 10-17-2012, 07:29 AM   #731
M-Technic's Avatar
Trader Rating: 15 (100%+)
They haven't made a foam version of their electric touring car in years, so I would say no.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 10-17-2012, 07:48 AM   #732
superspeed's Avatar
RC America is the exclusive Xray distributor in U.S.?
Old 10-17-2012, 07:53 AM   #733
Skiddins's Avatar
It isn't a nub, the new rear split block mounts use two screws.
As you tighten the screw the are applying a torsional force in the clockwise direction, this tries to make the mount rotate slightly, it's also obviously impossible to tighten both screws at the same time.
Once I tried it while using the spanner (or pliers) to hold it at the slight angle while tightening the screws it was very easy and aligned easily.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-17-2012, 08:28 AM   #734
morgoth's Avatar
Drove mine for the first yesterday on a tight indoor track. I haven't driven enough to get it dialed, but car was a little loose in the rear. And 350 in the shocks is very soft. My body was scraping in long tight turns.
I'm going to leave the 350 in the shocks for my race on sunday which is on a bigger and more open track which is less grippy. It might work over there. Leaning in the rear shocks 1 holes was a big difference from the stock position. The rear end was a lot calmer.
But the car feels drives better than my 2011 with 2012 chassis and topdeck. I'll let you guys home it handles on my hometrack, where I have driven my T3 last week so I can compare it better to the T3.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 10-17-2012, 08:37 AM   #735
Yes.
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
