Old 10-14-2012, 11:25 PM   #661
Originally Posted by Skiddins View Post
Well, we had a big meeting in the South East in UK yesterday, with 70 drivers in 13.5 boosted;
+ YouTube Video
Although I only managed to make the C final (with my T3'12), half the the A-Final were T4's built over the last couple of day's!
How did they look/any feedback?
Mb3195 is offline   Reply With Quote
Old 10-15-2012, 01:30 AM   #662
Skiddins's Avatar
I didn't see one that looked bad on track
They are still trying to tweak setups for them, but most were virtually kit setup.
Someone else was videoing the A-Final etc, so I'll try to link to it when it gets put up.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is online now   Reply With Quote
Old 10-15-2012, 02:18 AM   #663
morgoth's Avatar
What bucket boy did is mounting 16mm diameter washers that are 5mm on top of the bumper. So the washers touch the bulkheads.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 10-15-2012, 05:33 AM   #664
Skiddins
nice track, may have to try and make it down later in the series.
What was the finishing order in the a final?
Old 10-15-2012, 08:01 AM   #665
Send a message via AIM to Matt W
Default EWS Setup!!
+ YouTube Video
Hey Damian,
I dont suppose you could post your final setup sheet for EWS on the forum or perhaps email me it?
Matt W is offline   Reply With Quote
Old 10-15-2012, 08:11 AM   #666
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Originally Posted by Matt W View Post
Hey Damian,
That track is nice but it looks like it has zero traction?
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 10-15-2012, 09:07 AM   #667
zero traction? that is high traction for Uk tracks!
Old 10-15-2012, 09:42 AM   #668
AdrianM's Avatar
If you watch the ETS final videos Adrian Berntsen's T4 looked great. In A2 he repeatedly ran up on Marc Rheinard but could not get by him. Note that he was trying everything to get by and this lead to him blowing some corners.
That said...the Völker/BD7 combo is on another planet right now. He is in that zone where Marc was with his 415 and 416 a couple years ago.
Adrian Martinez
Old 10-15-2012, 10:04 AM   #669
Default re
Originally Posted by RCknight View Post
. My guess is they didn't want to tool molds. I'll be more confident when I don't read reports of broken chassis plates.
They in fact had to use new molds to form the upper bumper plate supports as they are shorter. The entire design of the car was based around achieving the lowest possible CG, and this included the bumper, so sometimes there are sacrifices that a designer must make to acheive a certain goal. Having said that, this "problem" you refer to is so minor, it leads me to believe(and everyone else apparently)that you will never be happy. I suggest you purchase the T3 bumper supports, foam bumper and be done with it.
Latest report on the T4:
This past weekend Andrew and I were racing again(fall fiasco at Lou's speedway) and it gave us the chance to try the setup we ended up with from IIC. Out of the gate the car was decent but was not quite as good from the first test day a week prior so I decided to go back to the original setup I had built the kit with. To my surprise the car was much worse. Since we were now qualifying, I decided to go back to the IIC setup including a couple other changes I thought would help. Turns out, it did! For the main, I made one last change(thinner rear diff oil) and the car was noticeably better and as reported by Andrew, much easier to drive.
The key things I learned that day were:
-Setup works very well on two COMPLETELY different tracks. Something we couldn't do with the T3. Of course, minor changes might be needed(more for feel than anything).
-Anything lower than the second hole from the top on the rear shock tower is less than ideal(IMO). I think this might have something to do with the rear springs being progressive and as we all know, laying the rear shock down does the same thing. Perhaps with linear spring sets I will be able to make it work.
-Short rear link does not provide as much grip as the T3. Also, might be due to the progressive rear springs. The next test session I will try it again with less rear camber.
Hope this helps some of you.
Corey
CoreyW. is offline   Reply With Quote
Old 10-15-2012, 10:30 AM   #670
MikeXray's Avatar
Trader Rating: 73 (100%+)
Hmm, good point, I hadn't thought about that relationship when trying those springs, since I typically run the rear very leaned in.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-15-2012, 10:30 AM   #671
Xpress's Avatar
Where are the videos?
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 10-15-2012, 10:41 AM   #672
http://ets.redrc.net/
Volker did walk away with it (again), but through the chicanes and at the end sweeper the T4 looked immense. Looks like Berntsen got a little ragged, he definitely had the pace in the car for a 2nd or 3rd.
Old 10-15-2012, 10:41 AM   #673
bvoltz's Avatar
Trader Rating: 44 (100%+)
Would you be so kind to share the changes you tried and the cst of diff oil?
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 10-15-2012, 10:42 AM   #674
Corey
Hi Corey, you make some good points ref the progressive springs.
My first outing with mine is on Wednesday. I noticed you run +0.75mm blocks on the rear. How are you finding this, whenever I tried this on the t3 I had no back end at all.
Old 10-15-2012, 10:45 AM   #675
Xpress's Avatar
Thanks....they must have just put them up after the last time I checked the site.
-Espo
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
