Old 10-10-2012, 08:27 AM   #556
locked's Avatar
Originally Posted by theatriks View Post
Is the Fall Fiasco this weekend?
Yessir! There's somewhere around 30 entries for stock TC (17.5 blinky) same for VTA and around 10 for mod TC.
If you can make it, do it. Lou's is awesome!
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 10-10-2012, 10:46 AM   #557
Originally Posted by locked View Post
Nice to see you on here Corey. Would be even nicer to see you racing.
Come race mod Saturday at Lou's.
I put in my time. I like helping Andrew acheive things I never could!
CoreyW. is offline   Reply With Quote
Old 10-10-2012, 11:08 AM   #558
Default Re
Here is Andrews setup from the IIC..
Body: PF Mazdaspeed 6
Tires: Jaco blue's
Compound: Jack 2
Weight: 1397g
Front:
2nd hole from top on shock tower
2.7 Xray spring
300cst oil
4X1.1mm pistons
1.4 Xray bar(short endlinks)
2.25 degrees camber L/R
6 degree caster blocks
1 degree toe-out
1mm spacer in front/rear of arm
Upper links middle hole on bulkhead
2mm under outer link
2mm under inner link
middle roll center blocks
2mm droop(measuring above ride height)
1.5mm Akerman
1mm bumpsteer
stock servo tie-rod position(upper position on servo saver)
Stock track width(1.5mm spacers)
Stock wheel hex with .5mm shim on each side
Xray diff using Plato as filler
52mm ECS shafts
Rear:
2.4/2.6 Xray progressive spring
300cst oil
4X1.1mm pistons
1.2 Xray bar(short endlinks and middle position on arm)
2.75 degrees camber L/R
2.75est degrees toe-in(using .5mm shim at the rear instead of stock .7mm)
1mm spacer in front of the rear arm(2mm behind)
4.5mm under outer link
high roll center blocks(+.75)
2.5mm droop(measuring above ride height)
Stock track width
Stock wheel hex
Xray diff w/2000cst
50mm stock shafts
Notes:
All screws in upper deck
15 grams of weight under steering rack
Old 10-10-2012, 11:18 AM   #559
Skiddins's Avatar
Tires: Jaco blue's
Compound: Jack 2
Weight: 1397g
Front:
2.7 Xray spring
300cst oil
4X1.1mm pistons
1 degree toe-out
1.5mm Akerman
1mm bumpsteer
52mm ECS shafts
Rear:
300cst oil
4X1.1mm pistons
4.5mm under inner link
Stock track width
Stock wheel hex
Xray diff w/2000cst
50mm stock shafts
Notes:
THanks.
Is there anything else you can list that was tried, but didn't work or just made it push or too on edge etc.
I ask as I'm trying to get to grips with possible changes etc before I get the car.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-10-2012, 11:27 AM   #560
artwork's Avatar
Trader Rating: 62 (100%+)
Corey-
Did you swap these by accident?
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is online now   Reply With Quote
Old 10-10-2012, 11:33 AM   #561
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by artwork View Post
Corey-
Probably but Ive been wrong many times before.
Remember that the new clamps on the inside are 2mm lower than before.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 10-10-2012, 11:37 AM   #562
Corey-
Ya, not sure where my head was at while typing that.
It is now corrected.
Old 10-10-2012, 11:44 AM   #563
Originally Posted by Skiddins View Post
THanks.
Skiddins
To be honest, the track conditions were unusal(in my eyes) so a few things that didn't work at the IIC worked at our home track. I think it would be best to try everything youself to see what you find. I feel that any of the T4 setups from the IIC will be a great starting point for any temporary carpet track such as snowbords, indoor champs etc. We have yet to try this particular setup back home so I am not sure how it will work. I will report back after the weekend.
If I think of anything else, I will be sure to post it.
Old 10-10-2012, 11:49 AM   #564
Skiddins's Avatar
Here's the Info Corey has given us put onto a T4 setup sheet.
There are a few bits missing.
http://www.piez0r.com/Skiddins/Xray%...ardman-IIC.pdf
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 10-10-2012, 12:39 PM   #565
locked's Avatar
Thanks for posting Andrew's setup Corey.
It doesn't matter what you say, you know I'm just going to keep bugging you to race with us.
Dave Locke
Old 10-10-2012, 02:11 PM   #566
morgoth's Avatar
My LHS received the first kits today. Gonna pickup mine tomorrow with a friend that also ordered one ^^
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 10-10-2012, 02:24 PM   #567
Nice man. I'm jealous!
Sean B. is offline   Reply With Quote
Old 10-10-2012, 02:38 PM   #568
bvoltz's Avatar
Trader Rating: 44 (100%+)
Soon... Very Soon... I've heard a possible date, but let's not post the date, as some will go nuts if it slips....
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 10-10-2012, 02:41 PM   #569
WRR
Please check your manuals to see if they are missing som assembly steps here and there. Mine did quite a lot.
Had to go to Xray website for a complete assembly instruction.
WRR is offline   Reply With Quote
Old 10-10-2012, 02:47 PM   #570
Have fun with it Jasper. Just finished the build of my T4 and it was a typical Xray experience. Everything fits easy together and no problem at all to fit all the electronics. Hope for nice weather this weekend so I can go to the track with Kay to test the car.
Agama A215 / FX 5K / Kopropo RSX2 Response / Sanwa MT4s
Agama A215E / Team Orion VST2 Pro 1900 / Team Orion Vortex R8.1 Pro / Kopropo RSX2 Response
ebisschop is offline   Reply With Quote
RC10B4/T4 Forum DerekL Electric Off-Road 14338 Yesterday 04:19 PM
Xray T3 2012 rasta_man Electric On-Road 4227 11-14-2017 05:49 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
