Old 09-07-2014, 01:48 PM   #5596
metalnut's Avatar
Trader Rating: 36 (100%+)
Originally Posted by Troy Carter View Post
Email Reflex about an RX4 chassis. They just got their own router so they can make one on demand nkw and it is a good chassis with or without their tow block conversion.
Yep, I did that in parallel I have a mixed history of getting responses from them, but I'm hoping they'll ping me back on this one.
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 09-07-2014, 03:32 PM   #5597
stulec52's Avatar
Trader Rating: 26 (100%+)
Send a message via ICQ to stulec52 Send a message via AIM to stulec52
hey guys,
I just picked up a nice used T4 '13, planning to run it in 17.5 stock.
I tried to put my Killshot in the car and it doesn't fit. Only way I can get 2 screws in it means it's pushing down on the chassis.
I tried to mount my Viper motor in the car and it was fine.
what am I doing wrong with the Killshot???
thanks
www.pmhobbycraft.ca/store/
www.tamiyaclub.com/
stulec52 is offline   Reply With Quote
Old 09-07-2014, 04:38 PM   #5598
Trader Rating: 20 (100%+)
Originally Posted by stulec52 View Post
hey guys,
thanks
Early killshots hat the bearing plate drilled wrong. You need a new one to fit properly. Or one from a dofferent trinity motor if you have one.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 09-12-2014, 06:20 AM   #5599
C&B RC's Avatar
Anybody know where I might pick up a spec-r top deck mount? Everybody seems to be out.
SPR027-USX4
http://www.reflexracing.net/SPR027-U...T4_p_1794.html
It's all fun & games til the flying monkeys show up!
C&B RC is offline   Reply With Quote
Old 09-12-2014, 08:34 AM   #5600
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
You can call Trinity and they will send you a new motor end plate. Luckily my Killshot wasn't affected and it fit my T4 just fine.
Dan is offline   Reply With Quote
Old 10-18-2014, 06:45 PM   #5601
Chaz955i's Avatar
Anyone try using the Spec-r gear diff? It is listed under T3/4 parts on the Reflex site but I can't get it to fit. Do I have to use different bearings or bearing holders?
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 10-18-2014, 07:36 PM   #5602
Dan
Dan's Avatar
I'm not sure if the Spec R gear diff will work but for sure you need to use the T4 bearing holders. The T4 bulkheads are closer together than T3 bulkheads.
Old 10-18-2014, 08:30 PM   #5603
nf_ekt's Avatar
Trader Rating: 113 (100%+)
I tried the SR gear diff in my T4 (came out of a 2012 T3)... no-go
Not sure what is required to make it fit, I quickly gave up.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 10-18-2014, 11:55 PM   #5604
metalnut's Avatar
The Spec-R gear diff (and spool) from the R1/S1/S2 will fit a T4'13 for sure, as I've had both, I don't have a T3 so I can't comment on that. Having said that, the Xray gear diff is nicer.
- Ricky Bobby
Old 10-19-2014, 12:36 AM   #5605
chasingthepack's Avatar
you just need the bearing holders from a t4 as they have more of an offset
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 10-19-2014, 06:19 AM   #5606
Chaz955i's Avatar
Thanks, I'm currently running the t4 so I assume the bearing holders are correct. When installed the holders tightly wedge into the bulkheads but rub on both sides of the diff case.
Appreciate everyone's response.
At The Gate Bizzos
Old 10-19-2014, 07:18 AM   #5607
Hi--when prepping a T4 for USGT--where are some good places to put weight in the chassis? Yes--I know I should use scales, but wondering if there's anything else I need to be aware of. Thanks!
stigsdad is offline   Reply With Quote
Old 10-19-2014, 07:55 AM   #5608
metalnut's Avatar
It's all about weight transfer. If you put weight in the rear, that weight will want to transfer to the front when you brake or go off power, thus generating more steering. On power, that same weight in the back will already be in the back, so not much transfer and thus you'll have more on power steering while sacrificing some rear grip.
Weight in the front will make the car push more off power (less weight transfer to the front), and push on power (more weight transfer to the rear).
In general, these cars are built around the standard set of electronics. Most people prefer to place lead in the middle, under the belt, but you can use the corners as well. This is where scales as well as weight transfer characteristics come into play.
To sum it up... no easy answer. It depends on your electronics layout, setup and track conditions. I'd start in the center if you don't have scales, then move weight around as you observe the car behavior.
- Ricky Bobby
Old 10-19-2014, 12:14 PM   #5609
Great answer, thanks!
Old 10-24-2014, 08:00 AM   #5610
Meradin's Avatar
Trader Rating: 19 (100%+)
So, who makes an aluminum chassis for the '13? If no one, I was thinking of having one made up but the cost might make it not worth it. I am curious who else might be interested or is everyone jumping ship to the '15?
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
TJames987
