Old 04-09-2014, 09:16 AM   #5536
Trader Rating: 20 (100%+)
Originally Posted by mac853 View Post
Dear Reflex chassis or Spec-R R1 users:
The pivot mounts are too tight to put those suspension mount inserts.
Could somebody teach me or share me your "specific" method to change them.
Could anybody tell me your inserts setup, please?
best regards
The plastic insert is too tight to go into the aluminum block?
Some seem to be tighter than others but I just align them and push with no real issue getting them to go in. So, when I change the insert I just set the aluminum mount on a hard surface with the insert end overhanging the edge and push it out from the back side with a blunt end of a tool. Then I just push the new insert into place and squeeze if flush to the mount with pliers if needed.
For insert setup it really depends on your setup. I like my car really narrow in the rear for low grip but need to run it really wide for high grip so there is no one magic setup for the inserts. Tune them for your track/driving just like all adjustments.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 04-09-2014, 09:22 AM   #5537
mac853's Avatar
Some is tighter than others is right, but all of them are unacceptable tough for me.
Thanks anyway!
mac853 is offline   Reply With Quote
Old 04-09-2014, 01:23 PM   #5538
porsche928gs's Avatar
Thanks anyway!
Make sure you are not installing them backwards ( thru the wrong side of the aluminum blocks). Look very closely. One side of the blocks has a ridge the other is smooth.
AKA Gilberto Santos
MikesHobbyshop.com SuperiorHobbies.com
Xray T4 and Yokomo BD7 2014 -Airtronics M12 Sponsored by Amex :-) open to other sponsorships!
porsche928gs is offline   Reply With Quote
Old 04-09-2014, 01:28 PM   #5539
I believe the plastic side that has the hole it should be with the ridge side of the aluminum block.
AKA Gilberto Santos
Old 04-11-2014, 01:13 AM   #5540
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Anyone try a CSO replacement chassis? Thoughts on quality?
Dan is offline   Reply With Quote
Old 04-11-2014, 02:30 AM   #5541
Smokem Racing's Avatar
I'd go for this - http://shop.smokem-racing.com/Smokem...T414_p_12.html - but I'm a little bit biased...
And it's on special so you can't go wrong!
Don't beat them. SMOKEM...
facebook.com/smokemracing
Smokem Racing is offline   Reply With Quote
Old 04-11-2014, 03:25 AM   #5542
CSO Carbon is Turd steer clear!
Smartypants is offline   Reply With Quote
Old 04-11-2014, 01:05 PM   #5543
Dan
Dan's Avatar
Thanks for the input!
Track went from permanent, smooth asphalt to parking lot. So chassis will be a higher wear item.
Old 04-11-2014, 02:32 PM   #5544
mac853's Avatar
Of course not!
I saw Spec R R1 manual before install it!
Old 06-01-2014, 03:47 AM   #5545
Thumbs up
hi guys, xray parts are expensive but quality is number 1, i used to buy spares but then i started buying used t4's and have saved heaps in the long run, buy genuine is the best advice, new or 2nd hand
cheers
oldenuff
p.s belts are the exception to the rule here, genuine belts are way over priced and aren't any better then a belt that is a third of the price
oldenuff is offline   Reply With Quote
Old 06-01-2014, 09:20 AM   #5546
Meradin's Avatar
Trader Rating: 19 (100%+)
I need to put together a setup sheet but for the most part I am running the kit rubber tire setup with the exception of 2mm akerman shims and 500K front diff.
I am running this in a VTA car and out new track layout DOES NOT cooperate with my car! There are a number of 180's that I need to slow way down for as it is a tight section. I am in desperate need of more steering!
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Old 06-01-2014, 09:42 AM   #5547
Trader Rating: 27 (100%+)
Carpet or asphalt? I feel like on carpet, a gear diff up front only really helps on high traction.
Try less rear toe but its hard to kinda say without knowing what setup you have already.
In VTA on carpet, most of us were running 350 oil 2.3 springs all around. 2 hole front arms were the key for us too.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 06-01-2014, 02:22 PM   #5548
Bigz84's Avatar
Trader Rating: 15 (100%+)
stand the rear shocks up, lay the fronts down
more front camber
#3 hole on the front roll center clamp, no shims, use about 1mm on top of the c hub. this will make your car very aggressive though...
harder front spring, heavier front oil
do you have all the screws in for the top deck? Is your top deck cut?
Airtronics/Sawna : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs: Motiv : Team Scream Racing
Bigz84 is offline   Reply With Quote
Old 06-02-2014, 12:49 AM   #5549
tc3team's Avatar
For some reason, my screw that attaches the servo saver to the servo keeps undoing itself, has anyone else experienced this?
My end points are set correctly.
I don't fancy using thread lock in case I need to change servo, but I suspect it's my only choice
I race with foams, so the grip levels are pulling the car about quite a bit, I suspect that's not helping
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 06-02-2014, 01:56 AM   #5550
cheers
oldenuff
Hi guys, I am having belt snap issues on my t4 in modified. the rear belt is really getting chewed out, id say I have done twenty packs and three belts in the car, two xray and one crappy cso that lost its teeth and burnt the crap out of my layshft pulleys. The first belt was snapped because it was too tight, now I dont know what? I got an aluminum layshaft pulley set, maybe it is damaging the belt??? help!
Fly'n Fish is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
