Old 03-24-2014, 09:07 AM   #5506
torinogt1971's Avatar
Originally Posted by erchn View Post
Thanks.
torinogt1971 is offline   Reply With Quote
Old 03-24-2014, 10:01 AM   #5507
alecladanga's Avatar
Smile
Originally Posted by martinskarin View Post
I have run 92/47 it works but have to file a little on the top deck for the motor to go that far back. A little larger pinion should be possible. So 90/48 or 49 should work I believe.. You'll have to take the top deck of just to change the pinion probably tho.
Thanks martin! :-)
alecladanga is offline   Reply With Quote
Old 03-24-2014, 04:54 PM   #5508
Default rt
Originally Posted by chasingthepack View Post
then your already here,its about the best source of info,if you want set up sheets then the xray forum although most are locked,also petit rc has alot of usefull set ups,as for drivers giving you tips good luck the ones that talk are few and far between
very true
kasiraki is offline   Reply With Quote
Old 03-25-2014, 10:15 PM   #5509
Trader Rating: 27 (100%+)
Anyone know if the t4'14 motor mount fits the t4'13?
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 03-25-2014, 10:19 PM   #5510
Odin544's Avatar
Trader Rating: 93 (100%+)
Yes, the only difference in it is the recessed screws so the pinion doesn't hit the motor screws.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 03-25-2014, 10:39 PM   #5511
Sweet, the stock '13 mount is fine in mod when your pinion size is tiny, but it sucks in stock when you gotta run large pinions.
Old 03-26-2014, 06:40 AM   #5512
Default t4 14 suspension mounts
Will the t4 14 suspension mounts work on a rsd conversion chassis?
bigtee is offline   Reply With Quote
Old 03-26-2014, 07:39 AM   #5513
No they're different but the Spec-r suspension mounts are the same as the rsd conversion
Old 03-26-2014, 08:22 AM   #5514
Originally Posted by klaymon View Post
2.7 all around
I checked and I do have 2.7's in the front and 2.3/ 2.6's in the rear.
What does the 2.7, in the rear, offer over the 2.3/2.6's?
Thanks.
Old 03-26-2014, 09:51 AM   #5515
klaymon's Avatar
Trader Rating: 71 (100%+)
Thanks.
Helps keep the car from rolling so much and dragging the chassis (it still drags a bit in the sweeper but not as much). Plus I got more rotation in the corners. It frees up the rear end.
klaymon is offline   Reply With Quote
Old 03-26-2014, 01:37 PM   #5516
Sounds like I need to get some 2.7's for the rear and try them out.
Thanks.
Old 03-26-2014, 02:23 PM   #5517
Depends on the traction levels too. If you have low levels of traction, the car is going to be super loose.
Old 03-26-2014, 03:45 PM   #5518
klaymon's Avatar
True. The track I use this setup at is high bite.
Old 03-26-2014, 04:06 PM   #5519
Thanks for the input. The one track that I race at is medium bite. The one that I plan on going to this weekend should be high bite. I will get some 2.7's and try them back to back at both tracks and see what works best.
Thanks again.
Old 03-26-2014, 06:24 PM   #5520
On our low/medium traction track, most guys are using 2.3's all around.
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 02:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 03:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
