Old 03-19-2014, 01:54 AM   #5491
daleburr's Avatar
Originally Posted by mac853 View Post
Could anybody tell me if is possible to buy from somewhere long shock towers?
Best regards
Yes, from Raceberry:
http://www.fast-webshop.com/tonispor...o=long+version
Although they're not worth the money. I've tried long shocks on the T4 and there's no benefit over the kit shocks.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 03-19-2014, 08:51 AM   #5492
mac853's Avatar
Forget it, front ones are out of stock and never come back!
For me has benefit since use standard length springs as other cars
mac853 is offline   Reply With Quote
Old 03-19-2014, 08:53 AM   #5493
mac853's Avatar
Originally Posted by hyujmn View Post
There's a company on Facebook called Bezerk RC that does custom shock towers and just about custom anything for any car.
Unfortunately, they just accept paypal then i can't apply it due the geographical problem
Old 03-19-2014, 02:24 PM   #5494
kermit's Avatar
I used them to make a custom front bumper brace before the xray part was released. Good quality, no issues and still using it on my car.
Adelaide RC Team Driver - www.adelaiderc.com.au
XRAY T4 | Futaba | HOBBYWING | Muchmore
kermit is offline   Reply With Quote
Old 03-19-2014, 06:21 PM   #5495
edhchoe's Avatar
Trader Rating: 41 (100%+)
Do cars need stiffer springs on asphalt than on carpet?
edhchoe is offline   Reply With Quote
Old 03-19-2014, 06:38 PM   #5496
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
Id say it really depends on your conditions. High or low traction carpet/asphalt. When I go from small low traction carpet to large high traction asphalt I generally dont have to change much, on asphalt maybe slightly softer springs and more vertical shocks, with less rear toe. But I do run foams on carpet usually, which requires a stiffer suspension than rubber tires. But it really depends on your conditions
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 03-20-2014, 01:53 AM   #5497
daleburr's Avatar
Depends how smooth the surface is. Most of the tarmac tracks I race at have a few big bumps. If I go much softer than 2.7 springs the chassis will just deck out all the time, unsettling the car and ruining the chassis.
And generally tarmac tracks are bigger and faster, requiring harder springs to reduce the body roll.
Team Xray
Old 03-24-2014, 02:05 AM   #5498
alecladanga's Avatar
hi guys, just need help on spur/pinion combination:
need to achieve 3.2 - 3.6 FDR with 64pitch
I've got 41 - 46 teeth pinions already but I highly doubt that combining it with 90-86 teeth spur gears would be a good idea. Just by looking at it, i think they wont meet (gap will be big).
any ideal/suggestions?
alecladanga is offline   Reply With Quote
Old 03-24-2014, 03:22 AM   #5499
Send a message via Skype™ to martinskarin
I have run 92/47 it works but have to file a little on the top deck for the motor to go that far back. A little larger pinion should be possible. So 90/48 or 49 should work I believe.. You'll have to take the top deck of just to change the pinion probably tho.
Martin Skärin
Shanghai
Roche
Destiny
PROAMPS
martinskarin is offline   Reply With Quote
Old 03-24-2014, 06:39 AM   #5500
torinogt1971's Avatar
How can I identify which springs that I have on my car? I bought the car used and I am not sure if it has the stock springs or not. Can I measure the spring wire diameter to determine the rate? How do the aftermarket springs, such as RSD, work?
I ran the car for the first time yesterday. It was on a tight medium bite carpet track with rubber tires. The chassis was dragging on the motor side. I am thinking that a stiffer spring may help, but not sure. The ride height was about 4.8 MM, which may be a little low. Any ideas will be appreciated.
Thanks.
torinogt1971 is offline   Reply With Quote
Old 03-24-2014, 06:46 AM   #5501
klaymon's Avatar
Trader Rating: 71 (100%+)
If the springs are OEM Xray springs, they will have the spring rate printed on the top coil of the spring (2.3, 2.5, etc).
It depends on the brand of spring on how they spec them out. Some brands use a number (Xray), some use a color code (RSD I think) and some use a wire size and number of coils (3Racing/Sakura). More coils is a lighter/softer spring.
4.8 isn't too bad of a ride height. I run 5 - 5.2 mm on mine and I still rub the motor in the sweeper at one of the tracks I go to with relatively stiff springs (Xray 2.7). I also run a 1.4 front sway and a 1.3 rear.
klaymon is offline   Reply With Quote
Old 03-24-2014, 07:12 AM   #5502
Assuming that my car has stock springs, I am not too far off of what you run. Do you run 2.7's front and rear, or the 2.3/2.6's in the rear?
Old 03-24-2014, 07:15 AM   #5503
How does Xray shock oil weights compare to Losi shock oil weights? Would Xray 400 be equal to Losi 40WT, or would that be too easy?
Old 03-24-2014, 07:27 AM   #5504
erchn's Avatar
http://www.rctech.net/forum/attachme...-shock_oil.pdf
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 03-24-2014, 07:40 AM   #5505
klaymon's Avatar
2.7 all around
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
