Old 03-09-2014, 06:02 PM   #5461
blade072's Avatar
Trader Rating: 98 (100%+)
Originally Posted by torinogt1971 View Post
I am looking into some front double universals. I see various manufactures of these. Are there any brands to stay away from?
Thanks.
i would only buy roche or spec-r
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 03-10-2014, 01:51 AM   #5462
daleburr's Avatar
Thanks.
The Roche ones look very good so far; great quality with no binding or slop.
I hear the Spec-R quickly develop slop so I stayed away from them.
The Xray ones are great quality and I used them last year, but I did snap an axle towards the end of the season in the same place that I've seen a few others snap, so decided to give Roche a try for this year.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 03-10-2014, 01:53 AM   #5463
Smokem Racing's Avatar
Thanks.
We reckon the Tamiya DCJ's are some of the best in the business. Very smooth, super tough and you can use them when you use our T4HS Spool Cups - http://shop.smokem-racing.com/Smokem...DCJs_p_20.html. We also stock the Tamiya DCJ's and individual parts for maintenance.
Originally Posted by Tommy R View Post
Hey folks,
After my last race I saw that my upper deck broke. I see that I can get the Xray 1.6mm or 2mm version for approximately $45. Are there less expensive alternatives or are these our only choices?
Thanks!
Tommy
You can try our T4V7 conversion for just a little bit more than that!
http://shop.smokem-racing.com/Smokem...sion_p_33.html
Don't beat them. SMOKEM...
facebook.com/smokemracing
Smokem Racing is offline   Reply With Quote
Old 03-10-2014, 05:11 AM   #5464
mac853's Avatar
Will this fit reflex low deck, but I am sure not, since reflex V2 chassis front is backward
mac853 is offline   Reply With Quote
Old 03-10-2014, 02:09 PM   #5465
Bigz84's Avatar
Trader Rating: 15 (100%+)
mac853, to answer your question, yes the belt will be loose. I have the eccentric all the way tight along w/ a belt tensioner (might be over kill, but..) and it works fine.
I ran the RSD V2 yesterday and it was fast. I ran the top deck w/ the 2 rear layshaft screws in and I had a tad too much turn in mid corner. nothing that wasn't drivable, just wasn't to my liking. I am going to try the top deck post to the motor mount next time and have all the 4 screws to the layshaft off to see if they will cure that, hopefully that will give my car a tad more push mid corner, or round out the corner.
As Christian states it does carry a ton more corner speed. very nice chassis.
Radiopost : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs:
Bigz84 is offline   Reply With Quote
Old 03-10-2014, 03:12 PM   #5466
mac853's Avatar
What, belt tensioner, need it?
thanks
Old 03-10-2014, 03:17 PM   #5467
Bigz84's Avatar
thanks
no, it is not needed. just my preference
Old 03-11-2014, 07:44 AM   #5468
mac853's Avatar
Ok, thanks!
Old 03-11-2014, 10:20 AM   #5469
Tommy R's Avatar
Trader Rating: 19 (100%+)
Originally Posted by hyujmn View Post
http://rcmarket.com.hk/product_info....ducts_id=14116 2.0mm
Very good alternative to the Xray stock upper deck. I've ordered tons of stuff over the year from rcmarket. Very good company and shipping doesn't take that long at all. Usually about a week to get here to Texas.
That looked great 'til I saw the cost for shipping was as much as the price of the top plate. I suspect it would be well worthwhile if I were buying more items, but this is really all I need.
Originally Posted by grippgoat View Post
Spec-R topdeck with motor mount post is worth considering.
-Mike
Thanks, Mike! I'm not really familiar with the Spec-R stuff. Do you happen to have a link or anything I could check out? Which Spec-R model components would fit the T4?
That's very intriguing! But what if I want to run the top plate with full stiffness (I also run on carpet, not just asphalt)? I see holes on the plate for two more screws, but there is a gap between the top plate and the center pulley mount. Do you provide shims to take up the space?
Thanks!
Tommy
Tommy R is offline   Reply With Quote
Old 03-11-2014, 12:54 PM   #5470
There's this one:
http://www.reflexracing.net/SPR027-U...mm_p_1778.html
Which is just a budget top deck replacement.
And this one:
http://www.reflexracing.net/SPR027-U...T4_p_1794.html
Which is a top-deck and post. I ran the top deck with post on my T4, and I thought it made the flex better on carpet. Better rear stability, but more steering and response. That's with the layshaft bulkhead screws removed.
Fitment wasn't perfect, though. It seemed to be a touch longer than the kit one, so I did some file work on it. Worked on track, though. Also, the aluminum is a bit soft. Make sure you use the longest screws you can get to fit in there on the bottom.
-Mike
Old 03-11-2014, 03:00 PM   #5471
Tommy R's Avatar
Thanks again, Mike!
Old 03-11-2014, 09:36 PM   #5472
Anyone have a gearing suggestion or fdr ratio for 13.5 boosted running on a medium size track.
brendon is offline   Reply With Quote
Old 03-12-2014, 01:15 AM   #5473
Send a message via Skype™ to martinskarin
Depends on motor and esc but I'd start at 6.2 if I did not know any better. At large track I have been running 6.0 lately, that's with Hobbywing motor.
However for titc we ran 5.4 but that was a special motor compared to others. So can be very different.
Martin Skärin
Shanghai
Roche
Destiny
PROAMPS
martinskarin is offline   Reply With Quote
Old 03-12-2014, 02:00 AM   #5474
alecladanga's Avatar
same FDR for me in TITC dude! :-) and that hand out motor is really powerful! I prefer that motor compared to my orca RX
alecladanga is offline   Reply With Quote
Old 03-12-2014, 02:34 AM   #5475
Skiddins's Avatar
Around 6.5 here;
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
