Old 03-08-2014, 08:53 AM   #5446
Trader Rating: 27 (100%+)
No the bulkhead is actually pulled backward, not downward.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 03-08-2014, 09:22 AM   #5447
mac853's Avatar
Yes, is what i mean.
That's mean we can't use the upper deck of other makes, since the bulkhead is backward in case i need to remove those 4 screws from upper deck then install a post between upper and lower deck.
mac853 is offline   Reply With Quote
Old 03-08-2014, 09:23 AM   #5448
klaymon's Avatar
Trader Rating: 71 (100%+)
I'm confused. My understanding was any of the parts were interchangeable with stock stuff.
klaymon is offline   Reply With Quote
Old 03-08-2014, 09:30 AM   #5449
CristianTabush's Avatar
The v2 has the layshaft bulkhead back 1mm. It is NOT compatible with the stock chassis.
This is incorrect.
The layshafts are in the same spot relative to the rear. The front bulkhead is back. .75mm to change the frontdriveshaft angle and give more on power steering.
The only part you are bound to is the RX4 top deck.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 03-08-2014, 09:32 AM   #5450
klaymon's Avatar
So the chassis and top deck are a matched set, correct? You cannot use an RX4 top deck with a stock chassis and vise versa?
Old 03-08-2014, 09:34 AM   #5451
Correct.
They can also be purchased separately if need be, via email.
Old 03-08-2014, 09:36 AM   #5452
klaymon's Avatar
Got it. Mine is arriving today except for suspension mounts. I was told they were on backorder and would be about a week behind.
Old 03-08-2014, 10:10 AM   #5453
mac853's Avatar
OK, thanks for all!
Old 03-08-2014, 11:22 AM   #5454
Originally Posted by CristianTabush View Post
This is incorrect.
Ah, thanks for clearing that up. I was mistaken.,
Old 03-08-2014, 05:59 PM   #5455
mac853's Avatar
That means the front belt will be loose?
Anyway
Sorry for 1 more question.
That means could use Spec-r Alu. Motor Mount Support w/ Graphite Upper Deck even Smokem's 1 on RX4 V2 or not?
As you said the front bulkhead will be pulled back ward, as well as to say the top deck is shorter, or not?
Best regards
Old 03-09-2014, 07:02 AM   #5456
torinogt1971's Avatar
I am looking into some front double universals. I see various manufactures of these. Are there any brands to stay away from?
Thanks.
torinogt1971 is offline   Reply With Quote
Old 03-09-2014, 07:34 AM   #5457
Thanks.
Most of them are actually pretty good. I wouldn't get CSO's DCJs, but any of the others are just fine.
I've had good success with the spec-r, rsd, and the hudy ones.
Old 03-09-2014, 01:59 PM   #5458
Tommy R's Avatar
Trader Rating: 19 (100%+)
Hey folks,
After my last race I saw that my upper deck broke. I see that I can get the Xray 1.6mm or 2mm version for approximately $45. Are there less expensive alternatives or are these our only choices?
Thanks!
Tommy
Tommy R is offline   Reply With Quote
Old 03-09-2014, 02:16 PM   #5459
Originally Posted by Tommy R View Post
Hey folks,
Thanks!
Tommy
http://rcmarket.com.hk/product_info....ducts_id=14116 2.0mm
Very good alternative to the Xray stock upper deck. I've ordered tons of stuff over the year from rcmarket. Very good company and shipping doesn't take that long at all. Usually about a week to get here to Texas.
Old 03-09-2014, 05:27 PM   #5460
Spec-R topdeck with motor mount post is worth considering.
-Mike
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
