Old 03-06-2014, 08:07 PM   #5431
Trader Rating: 20 (100%+)
Originally Posted by erchn View Post
I made this quite a while back and believe it to be accurate, though small variances can occur.
https://www.dropbox.com/s/j774j6oo2h...th%20sheet.pdf
I remember seeing that but couldn't find it. Thanks.
For reference, I measured my v1 cars rear toe. Maybe not perfect but it's something to work off.
Car 1
( ...)(... ) rf
( .)(. ) rr
2.8 toe - This is the narrowest rr setting available.
Car 2
(.. )( ..) rf
(.. )( ..) rr
3.2 toe - not quite the widest setting but it's almost 2mm wider than with Car 1's rr inserts.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 03-07-2014, 01:29 AM   #5432
Skiddins's Avatar
Sometime back, someone posted their own chart, a bit like the Spec-R one but for the RX4 conversion.
I can't find it or remember who posted it.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-07-2014, 02:38 AM   #5433
Could it be erchn, who re-posted it about 5 posts up? :P
-Mike
Old 03-07-2014, 05:10 AM   #5434
Skiddins's Avatar
-Mike
Err, yes
There's no avatar for 'removing egg from face'
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 03-07-2014, 05:52 AM   #5435
torinogt1971's Avatar
Originally Posted by Bigz84 View Post
this chassis will give you a ton more steering but keep the rear planted. much easier to drive.
Would I need the whole conversion, or would just the chassis be good enough? According to RSD's website, their chassis will work with the standard T4 suspension mounts. There is a big difference in price.
torinogt1971 is offline   Reply With Quote
Old 03-07-2014, 06:11 AM   #5436
klaymon's Avatar
Trader Rating: 71 (100%+)
I asked this same question about a week ago and the general consensus is get the whole thing. Mine is on the way.
klaymon is offline   Reply With Quote
Old 03-07-2014, 08:43 AM   #5437
cwoods34's Avatar
I ran just the plate at Vegas and it worked great. I went full-conversion afterwards and the car handled nearly the same but was way more consistent!
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 03-07-2014, 09:05 AM   #5438
So the full conversion is the way to go....
I am new to Xray and have a question about spur gears. The car I have came with a 84T 48P spur gear. I have tried some various 64P gears that I have laying around, and they are too thick. Do I need Xray spurs, or is there another option?
Old 03-07-2014, 12:15 PM   #5439
cwoods34's Avatar
The LeeSpeed spurs sold by Eric (EA Motorsports) are the best I've used so far.
Old 03-07-2014, 01:06 PM   #5440
Serpent fits nicely, is cheap, and easy to get from A-Main, with lots of sizes, but perhaps not the best concentricity.
Panaracer should work, too. Maybe ARC.
-Mike
Old 03-07-2014, 09:31 PM   #5441
Default t4 13 with RSD conversion
Need a good setup for vta thanks
bigtee is offline   Reply With Quote
Old 03-08-2014, 01:43 AM   #5442
Skiddins's Avatar
RW also do spurs that are specific to Xray cars, they have the centre milled down slightly to fit the layshaft;
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 03-08-2014, 02:20 AM   #5443
mac853's Avatar
Questions??
Could somebody tell me what's the difference between RSD RX4 V1 and V2.
At least want to know if their lower deck are the same:http://www.reflexracing.net/RSD-RX4-...y-_p_1967.html
Since I want to make replacement in case is broken.
Best regards
mac853 is offline   Reply With Quote
Old 03-08-2014, 06:30 AM   #5444
Trader Rating: 27 (100%+)
The v2 has the layshaft bulkhead back 1mm. It is NOT compatible with the stock chassis.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 03-08-2014, 08:31 AM   #5445
mac853's Avatar
Sorry, explain to me better, layshaft bulkhead?
You mean is behind 1mm, just for that 0.5mm shorter bulkhead from Reflex for the better for the belts, isn't it?
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
