Old 02-08-2014, 01:10 AM   #5386
Originally Posted by chasingthepack View Post
you can say that again!
Pardon?
bucketboy is offline   Reply With Quote
Old 02-08-2014, 01:38 AM   #5387
spencehotbodies's Avatar
Destiny RX-10s - Xray X1- Spec-r- nosram -Trinity-Wild turbo fans
West London Race Club
spencehotbodies is offline   Reply With Quote
Old 02-08-2014, 04:37 AM   #5388
chasingthepack's Avatar
Originally Posted by spencehotbodies View Post
probably an option on the 13 but the 14 i dont think needs it as they come with captive bulkheads
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 02-08-2014, 11:09 AM   #5389
But the '14 bulkheads still hit the top deck.
-Mike
Old 02-08-2014, 01:58 PM   #5390
Skiddins's Avatar
-Mike
I can't be bothered to raise the top deck up. I just remove the screws and add/remove the centre post as required.
Still seems to have the desired effect, with a lower risk of breaking the top deck.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 02-08-2014, 02:47 PM   #5391
Trader Rating: 20 (100%+)
Skiddins
Yep, I've run the stock '13 layshaft screws out with the Spec-R post and not had an issue or noticed any real difference from that to when I swapped to the RSD captured mounts. The only real think I like about the captured mounts is that it seems safer for your spur gear, particularly in mod. Maybe you fast guys can tell a slight difference but to me, it's all the same.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 02-11-2014, 09:33 AM   #5392
porsche928gs's Avatar
I ran my Rx4 v2 Xray at Snowbirds on 17.5 stock. I didn't have much luck with it on the qualifiers but I finally figured the best setup for it at the last race. The car was absolutely wonderful; very easy to drive fast and consistent even though I was trying to pace myself just to win my main. I let the car loose on the last part of my last lap and managed the fastest lap of the week with a 10.5sec lap. I absolutely encourage anyone thinking in upgrading their car to do so, this is a great conversion kit. My only criticism would be the inner suspension pins that come with it, the steel is too soft, they bend easily. Do yourself a favor and buy the yokomo bd7 front and rear inner pins they fit perfectly. (I hope Christian; You would take note of this and use them in every new kit). Anyway great first Snowbirds for me and RSD keep up the good work.
AKA Gilberto Santos
MikesHobbyshop.com SuperiorHobbies.com
Xray T4-Airtronics M12 Sponsored by Amex :-) open to other sponsorships!
AKA Gilberto Santos
Xray T4 and Yokomo BD7 2014 -Airtronics M12 Sponsored by Amex :-) open to other sponsorships!
porsche928gs is offline   Reply With Quote
Old 02-11-2014, 10:07 AM   #5393
klaymon's Avatar
Trader Rating: 71 (100%+)
Do you think it would be adequate to get just the chassis and top deck or is there something about the suspension mounts that really makes it?
klaymon is offline   Reply With Quote
Old 02-11-2014, 10:25 AM   #5394
I really think is the entire package. This conversion will make your car to drive like the Xray t4 14 . In fact my setup is almost the same Chris Adams ran in his superstock 13.5 car at snowbirds to finish 2nd after Keven Hebert's Associated. Chris was impressed how good my car looked. Get the spec r shims to shim the suspension blocks. I ran 1mm under all of them and it was perfect.
AKA Gilberto Santos
Old 02-11-2014, 10:29 AM   #5395
I would get the mounts as well. I've learned that they are easier to swap and make changes to than the stock mounts and they are smooth too. I'm sure the stock mounts would be OK but I really like the split FR mount rather than the stock one piece mount.
Old 02-11-2014, 10:57 AM   #5396
Trader Rating: 27 (100%+)
Getting the chassis alone could be a very good upgrade. The suspension mounts greatly lighten up the car though. Its also more consistent run to run because they don't build up slop as you drive more.
I noticed a huge difference going from a stock 13 to a full conversion rx4 (although I have the v1 chassis). My car gained so much steering and thus far, I've put down some of the fastest laps in stock sedan at my local track. The top guy here did an 11.1 (he was in the A-main at 'birds in mod and got 2nd in the A 13.5) while I was at an 11.3. I'd never been that close to him before and I believe it's because I finally got a dialed setup.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 02-11-2014, 02:17 PM   #5397
Bigz84's Avatar
Trader Rating: 15 (100%+)
AKA Gilberto Santos
can you send me over your entire setup. I'm curious to see it. I haven't had chance to run my V2, but loved the V1. just want to see how diff it would look from mine.
thanks
Airtronics/Sawna : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs: Motiv : Team Scream Racing
Bigz84 is offline   Reply With Quote
Old 02-11-2014, 04:42 PM   #5398
cwoods34's Avatar
thanks
I've been having a blast with Pauly's IIC mod setup on my v2 kit...... Except I run the RSD layshafts, SpecR post and upper deck, and 1mm shims under the arm mounts (which are roughly equal to XRAY middle I believe).
For you guys on low bite swap to a spool, 1.4 front swaybar, go to the 2hole on the front shock tower, thinner diff oil, LTCR, and medium plastics..... leave the rest the same.....
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 02-11-2014, 04:51 PM   #5399
Bigz84's Avatar
you back to running stock or this your mod setup?
Old 02-11-2014, 04:56 PM   #5400
cwoods34's Avatar
Works great regardless of the motor in it
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
