Old 01-20-2014, 02:09 AM   #5371
Default narrow chassis mod?
I have been looking at the chassis differances between the T4 13 and 14 and was wondering has anyone tried to mod the 13 by making it narrower overall and narrower near the suspension arms, would this help on low grip surfaces?
Bb
bucketboy is offline   Reply With Quote
Old 01-20-2014, 09:12 AM   #5372
Trader Rating: 27 (100%+)
That's not the biggest difference between the two cars though. There's an updated motor mount, and perhaps the biggest change is the upgraded suspension system. No more roll center pieces, but rather plastic inserts for roll center.
Besides that, I know a couple of guys back with the old T3'11/T3'12 were modding their chassis. They were just cutting out the rear to gain some flex.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 02-05-2014, 11:36 AM   #5373
mac853's Avatar
Could anybody tell me if suspension pivot mount and even inserts(suspension mount adapter) of Spec-R R1 could be used on the RSD RX4V2 conversion kit, isn't it?
best regards
mac853 is offline   Reply With Quote
Old 02-05-2014, 12:12 PM   #5374
Yes, the SPec-R suspension mounts are the same ones that Christian uses in his RSD RX4 conversion. You could buy the whole Spec-R set (pins, blocks, inserts and insert balls) and use it perfectly on the RX4.
Old 02-05-2014, 12:18 PM   #5375
mac853's Avatar
Really, but did see price difference of those toe inserts?
Can you see of those spare parts for rsd conversion kit has never restock, that is why i asked!
Thanks!
Old 02-05-2014, 08:58 PM   #5376
mac853's Avatar
Thanks!
Could somebody tell me if can use Tamiya or HPI pivot balls on these toe inserts(suspension mount adapter)?
Best regards
Old 02-06-2014, 04:31 AM   #5377
alecladanga's Avatar
Hi guys,
I wish to ask for your help. I'll be joining the TITC 2014 Open Brushless at Thailand two weeks from now.
Can anyone advice for a set up? Please look at the video below as this would be the lay out, but that's Jilles running mod and i'll just using 13.5T boosted.
Track is high grip.
Any help would be appreciated.
thanks in advance.
https://www.facebook.com/photo.php?v...type=2&theater
alecladanga is offline   Reply With Quote
Old 02-06-2014, 04:40 AM   #5378
Trader Rating: 57 (100%+)
Go to http://forum.teamxray.com/xsheets-search.php
Seach for T4 and under country select Thailand. Alexander Hagberg has 2 setups from that track. The 2012 one is with 13.5, the 2013 TITC was with modified. Try both setups!
PROMODVETTE is offline   Reply With Quote
Old 02-06-2014, 05:04 AM   #5379
alloyslash's Avatar
Trader Rating: 19 (100%+)
+1 Hagburg's setups will get you very close. Run multiple packs thru it and really get a feel for the setup, then if you feel it needs tweaked to your driving style make small changes. I would start with his 13.5 setup and concentrate on making something based of it work first. If I couldn't make that work i would look at the other one. 2 weeks isn't a lot of time! Good luck
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 02-06-2014, 07:58 AM   #5380
Thanks guys, downloaded both set ups sheets :-)
Old 02-07-2014, 02:36 AM   #5381
Send a message via Skype™ to martinskarin
It's not the same track. Above is rc addict, this time titc will be held at Huge Rc a new track by surikarn.
I'll be going with my best Asfalt setup from my home track which should be pretty similar size vise but likely lower grip. Also I don't have a good set up for ride tires on that track.
Martin Skärin
Shanghai
Roche Rapide P12
martinskarin is offline   Reply With Quote
Old 02-07-2014, 02:42 AM   #5382
see you there then dude :-)
same here, we have an indoor asphalt track but lower grip and half the size of huge.
huge rc track has high grip conditions and they did a ride series race there last year.
i'll try to work on hagberg's set up tomorrow.
Old 02-08-2014, 12:51 AM   #5383
spencehotbodies's Avatar
The new smokem top deck and layshaft holders could be a good hop up
http://www.redrc.net/2014/02/smokem-...onversion-kit/
Xray T416- Xray X1-Spec-r-Sanwa-Orca-Ame-Arrowmax-Wild turbo fans
West London Race Club
spencehotbodies is offline   Reply With Quote
Old 02-08-2014, 12:51 AM   #5384
Dooohhhhhh
Old 02-08-2014, 01:29 AM   #5385
chasingthepack's Avatar
you can say that again!
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 02:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 03:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
SEO by vBSEO 3.5.0
