Old 12-19-2013, 05:05 PM   #5281
I'm definitely replacing the servo saver. Just wondering what to do about the servo, or what else it could possibly be. Try a brand new savox 1251?
~Xray~RCAmerica~Motiv~Gravity RC~ORCA~
Swift Racing Services, LLC.
JDC Motorsports
Boostinswifty38 is offline   Reply With Quote
Old 12-19-2013, 06:18 PM   #5282
The Savox 1251 is ALL metal gears, and on the brittle side at that. There's no plastic gear like in the Futaba. So even with a saver, if you had a big hit, you could pop a gear tooth. If you did, then it might behave intermittently as the geartrain slipped or got jammed on a piece of debris. I'd definitely at least pull it apart and closely inspect the gears. Maybe clean off the electronics with some motor spray. That doesn't cost any money.
If it is a broken gear, then this and done: http://www.amainhobbies.com/product_...-Set-w-Bearing
(wow, the price went up on that. Used to be $11)
-Mike
Old 12-19-2013, 08:04 PM   #5283
Well, I do know the servo sounds glitchy at times, and when on a setup station it wouldn't return to center. I did pull it apart though and gears seem to be fine. I just wonder if the motor is going bad on it?
JDC Motorsports
Old 12-20-2013, 06:38 AM   #5284
alloyslash's Avatar
Trader Rating: 19 (100%+)
I am installing the new RSDv2 chassis on my '13. Can someone tell me the proper tightening order for the lay shaft/motor mount? I know there is a certain order to go by, but I don't have any paperwork.
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 12-20-2013, 06:48 AM   #5285
Skiddins's Avatar
Download the pdf manual from the Xray website.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-20-2013, 11:43 AM   #5286
porsche928gs's Avatar
Put the screw with the nut first, snug don't tighten all the way yet. Put the other screws and tighten all the way, then tight the one with the nut all the way
AKA Gilberto Santos
MikesHobbyshop.com SuperiorHobbies.com
Xray T4 and Yokomo BD7 2014 -Airtronics M12 Sponsored by Amex :-) open to other sponsorships!
porsche928gs is offline   Reply With Quote
Old 12-20-2013, 12:21 PM   #5287
vabroom's Avatar
page 10 of manual:
1. screws to attach bearing holder to motor mount (not tight)
2. nut on screw (not tight)
3. tighten chassis screws
4. tighten motor mount nut
5. tighten forward bearing mount screw to motor mount
6. tighten rear bearing mount screw to motor mount
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 12-20-2013, 01:16 PM   #5288
alloyslash's Avatar
Originally Posted by vabroom View Post
page 10 of manual:
Thanks. I'm at work, trying to finish it up in my spare time in an attempt to make a race tomorrow.
Old 12-21-2013, 12:16 AM   #5289
chasingthepack's Avatar
for a bit more flex you can leave the nyloc nut loose,tighten it all the way then with the 2mm allen driver undo it until the nut spins,then leave it there,most of the team drivers do this
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 12-21-2013, 04:27 AM   #5290
alloyslash's Avatar
Interesting! Thanks for the tip. For now I think I will tighten everything up and see how it drives with this RSDv2 chassis/top plate. I believe my next mod will be the closed lowered lay shaft holders from RSD.
Old 12-21-2013, 09:38 AM   #5291
Trader Rating: 27 (100%+)
Had an awesome drive with the RSD v1 on Thursday night. I hadn't raced or practiced for probably 3-4 months before Thursday, so I was incredibly rusty. The car during practice was really loose. I was traction rolling or sliding out at every corner. It was incredibly frustrating. I couldn't hold a corner with speed to save my life.
I made 3 small setup changes right before the first qualifier. Laid the rear shocks down 1 notch, took some droop out of the front and the rear, and added a 1mm shim underneath the inner upper bulkhead. OMG what a difference the car made. I quickly jumped out to a lead and was over 6 secs ahead of 2nd place and extending my lead when I decided to just go ahead and choke and jump a dot over half the track! Landed on my back and ended up 4 secs back of 1st place. I still closed down on him, and finished 1sec behind him.
It was amazing how responsive the car was to setup changes. It went from meh to absolutely dialed with some simple changes. Before I got this chassis, I was always a middle of the pack guy, even when I was driving a lot more. Now, after not even driving for MONTHS, I came back and almost won. I'd consider that a success!
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 12-24-2013, 07:40 PM   #5292
Just wondering what others are using for spurs other then Xray.
Friulimotosport is offline   Reply With Quote
Old 12-25-2013, 01:51 AM   #5293
mac853's Avatar
I had used zeppin and xenon before!
Kawada and Serpent possibly work but i never tried before, can't guarantee nothing
mac853 is offline   Reply With Quote
Old 12-25-2013, 03:18 PM   #5294
does anyone know if the Xray t4 graphite battery strap for lipo will fit the T3 2011 aswell?
Fille_SWE is offline   Reply With Quote
Old 12-25-2013, 04:32 PM   #5295
i cant see why not, they use the same battery holders
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
