Xray T4 '13
#5221
So, who has gone the RX4 route and have a 2014 car. Do you see an improvement in the 2014 over the RX4?
What do you think is better about the 2014 or RX4?
I planned to buy a 2014 in the spring to run outdoor and would move my current RX4 car to my backup/spare car. I'm curious if it's worth getting one now or not.
Thanks,
Thanks,
#5222
Thanks,
Thanks,
#5223
I have the RX4 conversion and the '14, but the RX4 is now my wet car so I can't directly compare.
#5225
Plus, the RX4 inserts combined with the option to shim the blocks leaves a ton of options. Certainly enough for my mind to be happy trying to figure out. 289 options is about 271 more than I think I'll ever be willing or have the time to play with.
#5226
Thanks,
Thanks,
Th 2014 is a fantastic car, but if you want to bring new life to your 2013 and save a little money our RX4V2 is a great alternative.
As for help, you can always drop by our thread and I will try to answer with the best of my knowledge what you may need.
#5227
I admit, I had the hardest time shimming up the blocks because I didn't really figure out the trick to doing them. Now it's super easy to to just insert a 2mm shim or a 1mm shim or a .5mm, whichever.
Also, some of us don't like buying the newest car each year and don't mind running the latest and greatest.
#5228
I'm sorry I was referring to converting a 14 to a RX4.
I am currently converting my 13 to a 14 but I also have another 14 also so it only made since to do this vs rx4.
But we also had one local with a rx4/"13" that had issues from day one with tweak he could check it 50 times and it was never the same . think he found a bent aluminum part but by then he done gave up on it .
#5229
The RX4 has tons of setup options itself. Its inserts have basically 8 different settings (4 dots which can be turned either way for 8 toie settings) and then you just shim up the blocks if you want to change roll center heights.
#5230
Christian, will there be shim inserts made in the future?
#5232
Thanks Christian.
I'm currently running the RX4v1 and I like it but there are other minor changes to the '14 which is why I was asking. And, most times I don't have alot of track time to play with setup so it's always nice to have something that seems to work well right out of the gate or have someone who you can borrow a setup from.
I did run on the same track, same layout, again today as last week. I didn't make a single change to the car but a fast friend of mine showed up to run which put some heat into my driving trying to keep up with him. My times definitely picked up purely from having to push harder to stay with him which was really nice to see. The current setup on the RX4 worked really well for me on most of the track. I think I may need to figure something out in the fast chicane section where the car can load up on the front some and get in too deep if I'm not very careful there. Otherwise it's easy to drive with plenty of steering and a fairly stable rear.
#5235
I've already got 3k in the rear and I've been unable to try the front diff because I broke the spec-r version I have and have not fixed it yet. I can't quite think of the motions that the diff will go through to even this out but it's certainly worth a try.
