Old 12-02-2013, 09:29 AM   #5176
mac853's Avatar
Thumbs up
Originally Posted by erchn View Post
I've not tried 2.3 all around (or Ride springs), but it's certainly an easy test. Yea, I would try going to 30wt.
I'll agree that going to 5k would make the car easier to drive, increasing confidence, but for me it typically kills low speed steering (and transition speed) too much, maybe find another way to gain that confidence.
It's possible you can try thinner shock oil as described above and gain what you need, so try the diff change last.
Ok, thanks for suggestions, they are so good to try!
Could anybody tell me which springs of other brands is same or even softer than 2.3?
How about if i wonder to use 3 holes piston?
best regards
mac853 is offline   Reply With Quote
Old 12-02-2013, 04:16 PM   #5177
porsche928gs's Avatar
Originally Posted by mac853 View Post
Downstop F5 R4
Ride height F4.8 R5.4
Camber F1.5 R2.0
R toe in 3.0
F toe out 1.0
Sway bar F1.3 R1.2
Spring F2.5 F2.3
Shock oil Trinity 35
Piston 4 holes 1.1
Trans.F Spool R Gear Diff 5000 oil
Shock tower hole F and R 2nd hole from outside
Bulk head F and R hole 2nd from outside
Right of the bat, your car is too heavy upfront. Is like a poorly balanced front wheel drive car. It's because your ride height, 4.8f 5.4 rear. It will understeer severely when braking or off power. Second your rear diff oil is too thick, try 2000k
AKA Gilberto Santos
MikesHobbyshop.com SuperiorHobbies.com
Xray T4 and Yokomo BD7 2014 -Airtronics M12 Sponsored by Amex :-) open to other sponsorships!
porsche928gs is offline   Reply With Quote
Old 12-02-2013, 07:29 PM   #5178
mac853's Avatar
That you mean higher front height, set from 4.8 to 5.0, but i think is not enough to makes difference.
Anyway, why nobody tell me if worth use 3 holes piston?
Best regards
Old 12-03-2013, 12:43 AM   #5179
Best regards
Yes, raise your front end. Make it even or no more than.2 difference (lower). Is better to change oil than to have different piston sizes.
AKA Gilberto Santos
Old 12-03-2013, 12:47 AM   #5180
daleburr's Avatar
Downstop F5 R4
Camber F1.5 R2.0
R toe in 3.0
F toe out 1.0
Sway bar F1.3 R1.2
Spring F2.5 F2.3
Piston 4 holes 1.1
I think you're too soft on the springs and too heavy on the damping, resulting in a lazy sluggish car. I don't even run 2.3 in the wet as they're too soft.
Go to 2.7f and 2.5r, and 30wt oil all round.
Also reduce your rear camber to 1.5deg, this will give better direction change and more HS steering, while improving traction on the power.
And as others have said, drop the diff oil to around 2k.
The pistons are fine, those are what everyone uses with the T4.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 12-03-2013, 06:09 AM   #5181
mac853's Avatar
But I run on bumpy and surface is going losing grip to be old
Old 12-03-2013, 07:49 AM   #5182
daleburr's Avatar
Sounds like every outdoor track in the UK lol.
Is this carpet or asphalt?
If it's bumpy you may need to raise your rideheight, 5.5 to 6mm is common for bumpy asphalt tracks.
A progressive spring like the Xray 2.5-2.8 or Reflex Silver are also a good option for that type of surface, they tend to soak up the bumps a little better without resulting in too much body roll.
Team Xray
Old 12-03-2013, 08:19 AM   #5183
mac853's Avatar
Is asphalt, you mean progressive spring all round?
Reflex Silver, what hardness if compare with original spring?
Best regards
Old 12-03-2013, 08:39 AM   #5184
Skiddins's Avatar
Best regards
The 'closest' spring would be Xray 2.5-2.8 progressive
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-03-2013, 09:21 AM   #5185
mac853's Avatar
Ok, thanks!
Old 12-03-2013, 09:53 AM   #5186
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
I wonder why u ran front at 4.8 on a bumpy asphalt track?
If it was my car I would run
2.3-2.6 progressive f&r
300 all corners
Low role blocks in front mid in rear .
Lots of droop in rear / very little in front .lol
And ride height around 6mm.
Seemed to work last time I ran low traction bumpy track
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 12-03-2013, 10:34 AM   #5187
mac853's Avatar
300 all corners
Lot droops rear less in front, but i have heard more in the front before.
And 6mm height is too much, maybe next time i should run 5mm front and 5.2 rear.
Front 6 with rear 4 in downstop, i think is only way
But what do you mean low roll blocks?
Old 12-03-2013, 10:48 AM   #5188
We had a really bumpy surface . yes more droop in front does help with stability in the bumps but kills on power steering in high-speed exits.
Low blocks refers to the inner hinge pin mounts theirs a low (.) ,mid (•), and a high (') . the higher u go the less the car will lean in the corners which in my opinion takes away traction .
Justin & Matt Lyons
a800s sanwa m12s
Old 12-03-2013, 11:13 AM   #5189
I tried 3x1.1 pistons on high grip carpet with a tight layout. The car was very responsive, but it was more prone to traction roll. I think it was because of the extra pack and overall increased damping. So it might be good for bumpy asphalt.
-Mike
Old 12-03-2013, 12:00 PM   #5190
Skiddins's Avatar
If you can get away with 5 & 5.2mm ride height and not scrape the chassis, your track isn't very bumpy
Don't be afraid to try the higher ride height, just remember to adjust the droop to compensate.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
