Old 11-26-2013, 05:07 AM   #5161
mac853's Avatar
Originally Posted by Skiddins View Post
I have mixed feelings about the suspension holders on the T4'14.
Although the car seems an improvement there are fewer settings available, as with the old car I could use any width shim I wanted to get the exact toe etc I was after.
Don't forget, there have been changes to the chassis etc on the new car so flex points are slightly different as well.
Skiddins
Yes, that's the point.
At least you understand me.
mac853 is offline   Reply With Quote
Old 11-26-2013, 05:58 AM   #5162
Skiddins's Avatar
If you want the new style of holders but without all the Xray expense I would suggest the Reflex Racing conversion, their RX4 kit.
Skiddins
P.S. You can't use the new T4'14 holders on the old T4 chassis as holes are in the wrong place.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-26-2013, 06:00 AM   #5163
mac853's Avatar
Skiddins
OK!
Old 12-01-2013, 09:08 AM   #5164
mac853's Avatar
Questions??
Dear anyone:
As i race always on tight corners track with little few high speed corners, i just feel the cars of other brands with conventional long length shocks run better seems be more reactive on curves.
Do somebody think that i should try change with aftermarket long shock tower of Raceberry to run long shocks(eg:tamiya) and springs(eg:HPI) on T4 2013?
Best regards
Old 12-01-2013, 05:12 PM   #5165
No. Try the softest springs you can get, and lighter shock oil. You need to be more specific on what, exactly, the car you have is doing, vs others. Rolls more? Has more steering? Lose or tight in the rear?
X-ray T4'16 stock TC, Xray T4'15 mod sedan, Xray xb4. Xray, Motiv, Team debit card.
Boostinswifty38 is offline   Reply With Quote
Old 12-01-2013, 07:02 PM   #5166
PDR TOO's Avatar
Trader Rating: 24 (100%+)
Default T$ '13 Arrowmax Top Deck
Does anyone have experience with the Arrowmax T4 '13 top decks.
I need a new top deck and these look extremely well priced.
My concern is, as the saying goes, "if it looks too good to be true it probably is".
SMA .....The Track.
Previously Raced Vehicles keep me on the track - sort of.
PDR TOO is offline   Reply With Quote
Old 12-01-2013, 07:32 PM   #5167
RCFREAK's Avatar
Trader Rating: 17 (100%+)
I cant say anything about the Arrowmax T4 topdeck, but i have ran the arrowmax T3'12 one. No problem with it...The weave was slightly different, maybe gave the '12 more flex. Kept it on the car till i sold it never put the stock one on again..
Arv.
RC AMERICA// EA MOTORSPORTS// KO PROPO// ORCA
RCFREAK is offline   Reply With Quote
Old 12-01-2013, 09:10 PM   #5168
mac853's Avatar
My car has got problem in steering in tight corner, steering transition, and huge understering on highspeed curves.
My friend suggest me to use 3 holes piston instead of 4 holes, maybe even try thicker oil which i usually use 35wt oil.
And i want to try use long length tower due mostly front runners are using TCXX and BD7
Old 12-01-2013, 09:20 PM   #5169
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
Yes, keep the three hole piston and use 30wt oil all around and a med to soft spring all around.
better roll for tight turns!
Josh-n-ya is offline   Reply With Quote
Old 12-02-2013, 12:41 AM   #5170
daleburr's Avatar
Post your setup, then we can tell you what's wrong with it.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 12-02-2013, 02:54 AM   #5171
PDR TOO's Avatar
Thanks RCFREAK
SMA .....The Track.
Old 12-02-2013, 07:44 AM   #5172
mac853's Avatar
Downstop F5 R4
Ride height F4.8 R5.4
Camber F1.5 R2.0
R toe in 3.0
F toe out 1.0
Sway bar F1.3 R1.2
Spring F2.5 F2.3
Shock oil Trinity 35
Piston 4 holes 1.1
Trans.F Spool R Gear Diff 5000 oil
Shock tower hole F and R 2nd hole from outside
Bulk head F and R hole 2nd from outside
Old 12-02-2013, 08:54 AM   #5173
erchn's Avatar
Downstop F5 R4
Camber F1.5 R2.0
R toe in 3.0
F toe out 1.0
Sway bar F1.3 R1.2
Spring F2.5 F2.3
Piston 4 holes 1.1
Dropping your rear diff oil to about 2k should increase that low speed steering by quite a lot, and increase your transition speed.
Assuming you are measuring droop as described in the manual, try going to 5.5 or 6 in front droop, it should help with more steering in the high speed sweepers.
Most 35wt oil is around 450CST, I believe that's too heavy for the T4, and going lighter, even to 400 will help in transition speed as well.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 12-02-2013, 09:06 AM   #5174
mac853's Avatar
Thumbs up
You mean me to use trinity 30?
About downstop i just can adjust to 6 due my gauge doesn't have 0.5 step.
Not quite sure of gear diff 2K, due whenever i use 5k it gaves me more confidence but not when i change to 3k, anyway i will try all of them.
How about to try all 2.3 spring?
Can anybody tell me if worth to try RIDE softests short spring?
Best regards
Old 12-02-2013, 09:12 AM   #5175
erchn's Avatar
Best regards
I've not tried 2.3 all around (or Ride springs), but it's certainly an easy test. Yea, I would try going to 30wt.
I'll agree that going to 5k would make the car easier to drive, increasing confidence, but for me it typically kills low speed steering (and transition speed) too much, maybe find another way to gain that confidence.
It's possible you can try thinner shock oil as described above and gain what you need, so try the diff change last.
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
