Old 11-05-2013, 04:38 PM   #5116
Tommy R's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Osiris 75 View Post
I haven't noticed a real perfomance difference, but I do know thet hards holds up better during an impact. I would stock op on arms, c-hubs and bushings. Thats all I usually break.
Thanks, Chris!
Any thoughts on the aluminum steering arms? I've got some (came with the car when I bought it), but I figured they would just add unsprung weight (bad) and force other parts to break upon impact (also bad). Are there good qualities to the aluminum arms that I'm not seeing?
Tommy R is offline   Reply With Quote
Old 11-05-2013, 09:16 PM   #5117
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Tommy R View Post
Thanks, Chris!
Yes, no slop, the plastics will wear out over time, the aluminum will not. I recommend them...
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 11-06-2013, 02:30 AM   #5118
Skiddins's Avatar
Thanks, Chris!
They also run the risk of bending in a big impact, the plastics are a bit more resilient in impacts. You are also adding unsprung weight as you say.
Have to confess, you tend to see them on cars being run by young kids where the parents are fed up with replacing C-Hubs etc in the slower classes.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is online now   Reply With Quote
Old 11-06-2013, 05:04 AM   #5119
I actually asked Lemieux this last weekend about those and he said the difference was negligible. Not really a benefit at all.
~Xray~RCAmerica~Motiv~Gravity RC~ORCA~
Swift Racing Services, LLC.
JDC Motorsports
Boostinswifty38 is offline   Reply With Quote
Old 11-06-2013, 05:05 AM   #5120
I would think this is the case too, since you're probably more likely to "tweak" a servo saver then you are the steering arm, unless you have a super strong ass servo and you ca glued the saver or don't run one.
JDC Motorsports
Old 11-12-2013, 06:42 PM   #5121
Meradin's Avatar
Trader Rating: 19 (100%+)
So I am looking for a little tuning advice. I am running a t4'13 in VTA class and am losing ground in the two 180 degree sections. Take a look at this video and you can see what I am talking about. My car is the white one with the stripes. I started in 2nd position.
For a setup everything is stock rubber tire setup with the exception of...
Front diff with 500,000cst
3mm droop over ride height F/R
2000cst in the rear diff
1.5 negative camber on all four corners
2 degree rear toe
I am looking to get through the 180s a little faster.
+ YouTube Video
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Old 11-12-2013, 07:09 PM   #5122
Odin544's Avatar
Trader Rating: 93 (100%+)
2 degree rear toe
+ YouTube Video
Looks to me like the back end is almost sliding a little through the corner. Have you tried lighter rear diff fluid?
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 11-12-2013, 07:20 PM   #5123
Meradin's Avatar
Not sure if it is sliding or it is me hitting the brakes hard into the first 180 right after the timing gate.
To answer your question, no, I put 2k in when i built the car and haven't tried anything else.
Old 11-12-2013, 08:58 PM   #5124
Odin544's Avatar
I would go lighter. From watching the other classes run as well it doesn't look like traction is all that high.
TriCitiesRC.com
Old 11-13-2013, 05:16 AM   #5125
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
Anyone tried to mimic the 14 settings with any luck?
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 11-13-2013, 08:14 AM   #5126
John Tag's Avatar
Trader Rating: 42 (100%+)
2 degree rear toe
+ YouTube Video
I would also say 1K in rear diff. Also try setting rear droop to 2-1/2 to stop as much transfer. Something I also do on tight tracks with low bite and tight turns ..Sounds crazy, But I disconnect my rear sway bar and car feels like it turns better and still has same grip.
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 11-13-2013, 08:49 AM   #5127
morgoth's Avatar
A thinner rear swaybar gives more off power steering. On low grip surfaces or when I need more rear stability entering a turn, I run a ticker swaybar in the rear.
A soft rear swaybar gives more aggressive turn in.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 11-13-2013, 09:25 AM   #5128
porsche928gs's Avatar
[QUOTE=Meradin;12719777]So I am looking for a little tuning advice. I am running a t4'13 in VTA class and am losing ground in the two 180 degree sections. Take a look at this video and you can see what I am talking about. My car is the white one with the stripes. I started in 2nd position.
2 degree rear toe
Sorry but I don't think is really a problem so much with your setup as it it is with your consistency of driving the line. Remember when you get outside of the racing line your tires may get dirty and It will take a few corners to clean up. I agree with John, if you want to go faster around the 180s use thinner rear diff oil. If you want to hug the corner closer without braking that hard (Initial turn-in) reduce your oil thickness on front diff as well or use a ball diff for faster adjustments.
AKA Gilberto Santos
Banana Raceway
Yokomo BD7 2014-2015-2016, Yokomo BD8, 2018 BD8, YR10f, YZ2-CA -Airtronics M12 Sponsored by Amex :-) open to other sponsorships!
porsche928gs is offline   Reply With Quote
Old 11-13-2013, 09:27 AM   #5129
Meradin's Avatar
I am not sure about the traction comments. Now, I have very limited experience in this. The local rc club used the Ozite stuff and it was like ice compared to this carpet. I can honestly say that this isn't a low traction carpet. Many times I have been able to run dry tires, no sauce needed.
I will give the suggestions a shot though. As I said, I have limited experience in judging traction levels.
I may first try putting 1k in the diff.
Old 11-13-2013, 09:49 AM   #5130
The best thing to do is doing practice laps (same amount) between setup changes by yourself trying to be as consistent as u can so you can appreciate what the change does. Take a day to do this and try everything mentioned before. Take notes, this will let you know what's best for your driving style.
AKA Gilberto Santos
Banana Raceway
Xray T3 2012 rasta_man Electric On-Road 4227 11-14-2017 05:49 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14337 11-10-2017 08:19 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
