Xray T4 '13
#5086
Get all your links (Camber and Steering) equal and check again using set up tools or set up wheels at the least. the plastic wheels we race with seem to have a bit of run out normally so any measurements with those will be inaccurate. Things should be pretty close at that point. As you change camber the toe will change a bit as well so if the camber is not equal the toe will likely be off a bit as well. Even with all the links equal right to left you still might have to adjust a tiny bit but there shouldn't be large differences left to right unless something else is messed up. Good luck.
#5088
Figured out my toe/camber issues.. I didn't pay close enough attention to the direction of the suspension holders. Newbie mistake..
Corrected them and everything is now good.
#5091
How about these http://www.speedtechhobbies.com/inde...roduct_id=2309
It says they fit the T3, but it doesn't look like these are offset like xray gears.
#5093
#5095
Anyone interested in trading their closed layshaft holders for my open ones? I am wanting to try the rear screw removal setup.
#5097
How would it effect the car in a high grip carpet situation?
#5099
I *think* the other blocks might be OK as I seem to recall when attaching my protective sticker on the bottom of the chassis that at least some of the screws lined up.
