Old 10-16-2013, 04:18 PM   #5056
Cloaked's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Jerz616 View Post
That's all track dependent. I run 3.7 to 4.05 depending on layout. I would check on thst spur that you bought. The Xray's use an offset spur gear. Not to say that the kimborough wouldn't work but I have never tried one.
Ahh crap.
Thanks for the other responses guys.
Nothing...
Cloaked is offline   Reply With Quote
Old 10-16-2013, 04:28 PM   #5057
PDR TOO's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Cloaked View Post
Hey Guys
I just picked up a 2nd hand T4 and will be running 21.5 blinky class.
I know I need an FDR between 3.00 to 3.5, so I went and ordered a 38t Pinion and a 69t Spur Kimbrough spur.
it was only afterwards I should probably ask one here haha, so what gearing should I be looking at for 21.5 blinky?
Sorry if this has been asked before I did a search for 21.5 but nothing specific came up.
Cloaked,
FDR will also be impacted by the track you run at and the motor choice.
I see you are in Sydney. I run a T4 in 21.5 at SMA (Tempe) and use a 48 pitch, 64T Spur with a 43T pinion which gives you a 2.83 FDR – that is running a Reedy (V1) motor. Other guys will run lower gearing with an FDR around 3.2 if running a motor such as a Tekin Gen2 which prefers to rev more. There is usually a "sweet spot" combination of FDR and static timing for each motor.
Two things you will need to be careful with;
1. Do not put too much timing on the can itself if you intend on running the ridiculous gearing we are using. (At the NSW State Titles on the weekend, one of the drivers was running an FDR of 2.2 with no timing on the can – not a T4 though). Then temp check after 2 minutes and adjust as required.
2. Take care that the pinion does not foul on the motor mount screws. There’s not much room between the top deck on one side and the motor mount screws on the other. I believe this has been addressed with the recessed motor mount in the T4 ’14.
Not sure about the Kimbrough spur. I usually use Xray or RW Racing. Northern Beaches Hobby Centre (NBHC) and Powerhouse Performance both race at and sponsor SMA and will help with parts.
If you get to SMA come and see the seniors running T4’s – we will be happy to assist. You will find the guys at Castle Hill and Riverstone will also be very helpful. Riverstone is a smaller tighter track and gearing will be significantly shorter – and it’s usually cool inside so they run hotter tires.
Cheers, Brent
SMA .....The Track.
Previously Raced Vehicles keep me on the track - sort of.
PDR TOO is offline   Reply With Quote
Old 10-16-2013, 05:41 PM   #5058
Cloaked's Avatar
Originally Posted by PDR TOO View Post
Cloaked,
Cheers, Brent
Thanks for the info Brent
I was actually at SMA on Tuesday, I bought Nathans old T4.
Nothing...
Old 10-16-2013, 07:54 PM   #5059
PDR TOO's Avatar
My pleasure.
I sit with Hotrod1933 who posted above, however I will be absent next Tuesday due to family commitments.
Interestingly, Hotrod's post and your response were not on the page when I posted my response - must have been lurking in the ether.
Nathan's car is an excellent purchase. To say he is fussy would be an understatement.
Cheers, Brent
SMA .....The Track.
Old 10-16-2013, 09:25 PM   #5060
Cloaked's Avatar
My pleasure.
Cheers, Brent
Thanks Again.
As a backup I jsut ordered a RWracing 68t Spur from a guy in Queensland and Ill order some pinions to play around with.
Still awaiting for all my electronics to arrive and even then I probably wont be racing for a while.
But will definietely come down and say Hi at SMA,
Nothing...
Old 10-17-2013, 02:52 AM   #5061
RC MARKET's Avatar
CSO T4 Conversion Kit
RC MARKET is offline   Reply With Quote
Old 10-18-2013, 12:00 AM   #5062
Figure I should build my T4 that's been sitting in the dust since I didn't get a chance to race last year.
Any out of the box mods required to make this noob's first touring car bulletproof?
jjjheimer is offline   Reply With Quote
Old 10-18-2013, 12:00 AM   #5063
Old 10-18-2013, 12:18 AM   #5064
Spare spool cups maybe. Mine came with a T3 hard foam bumper and t3 bumper tubey things, and I haven't broken anything. I don't crash often anymore, but I had some good hits learning the ropes in mod this summer. It's a tough car. Oh, and you probably want to trim the axles so they don't stick out so much.
-Mike
Old 10-19-2013, 04:45 PM   #5065
Trader Rating: 5 (86%+)
G'day,
I've just upgraded from a T3'12 to an original T4. Is the gear diff from the T3 different to the one for the front of a T4? The assembly seems narrower on the T4 but I don't know if it's the diff itself or the bearings or the bearing holders.
Thanks - Ken
lipper is offline   Reply With Quote
Old 10-19-2013, 04:54 PM   #5066
hotrod1933's Avatar
plastic bearing holders only are different. diff and bearings are the same.
XRAY T4-15 -- nbhc.com -- powerhouse performance -- sma.org
hotrod1933 is offline   Reply With Quote
Old 10-19-2013, 05:10 PM   #5067
Thanks mate - that makes sense.
Old 10-19-2013, 09:58 PM   #5068
Here's a dumb question.. how do I thread the lower shock ball end onto the headless screw I put into the lower arm?
I've been staring at the manual and the car for 20 minutes and I can't figure it out.
Do you guys threadlock the upper shock mount that screw onto the body mount piece?
I also don't understand when they say "Lower pivot ball has an extra shoulder" - can someone (gently) explain in a little more detail?
Thanks in advance.
Old 10-19-2013, 10:00 PM   #5069
Trader Rating: 57 (100%+)
The ball has a 3mm hex on the no flat side.
PROMODVETTE is offline   Reply With Quote
Old 10-19-2013, 10:00 PM   #5070
really good...
Ezat Hj Ramli is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 02:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 03:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
SEO by vBSEO 3.5.0
