Old 09-04-2013, 05:09 PM   #4816
b_recliner's Avatar
Trader Rating: 22 (100%+)
i'm seeing a preorder for the 2014 at rcmarket...says it will be in stock october 6
Tracks: Richfield Raceway, LCRC, DRP
Current Cars: Xray t4 '14, Schumacher Cougar KF, Schumacher Mi5, Losi 22 2.0, Losi 8ight E 3.0
b_recliner is offline   Reply With Quote
Old 09-04-2013, 08:49 PM   #4817
Losiho's Avatar
Yup, just saw that too. Time to start saving
Losiho is offline   Reply With Quote
Old 09-04-2013, 11:07 PM   #4818
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
For those racing asphalt, the T-shox springs are also VERY good. I like them over the Xray springs, and they are in between the length of the Xray and ride springs. Make sure you get the "front" T-shox springs. I've been liking the blue springs, green also work well when the grip comes up.
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing - Bezerk RC - Hearns Hobbies - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 09-05-2013, 12:10 AM   #4819
Losiho's Avatar
Xray now Antoni ?? Wow, you're swapping between chassis brands almost as often as me
Old 09-05-2013, 01:50 AM   #4820
Skiddins's Avatar
Antoni
Whenever I've run T-Shox, springs, the car felt almost too safe.
They made it very easy to drive, but not fast enough.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 09-05-2013, 02:56 AM   #4821
daleburr's Avatar
Originally Posted by chasingthepack View Post
nice report dale whats the rate of those springs?
so no use in the uk then
why dont people stick to the xray springs,is there a problem with them?i use a combination of xray and cso springs
Ride spring rates are:
Greys 14.0lbs (2.5)
Reds 14.8lbs (2.65)
Purples 15.7lbs (2.8)
The Xray springs are very good. Both 13.5 BRCA champions (Zac and Liam) just use Xray springs as far as I'm aware, with 2.7 all round being a popular/fast setup.
It's nice to have some options though. Sometimes you want a safer feel, or a more aggressive feel, or more overall grip, or better bump handling, but without changing the spring rate too much. This is where different brands of springs come in.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 09-05-2013, 03:24 AM   #4822
Bishop's Avatar
So far I have just been running the Xray springs, 2.5 up front, and the kit stock 2.3-2.6 rear, I tried a couple of other Xray combos, but either lost steering or had too little rear grip, actually the 2.5 up front gave me steering vs the stock 2.7, and I kind of like the feel of the 2.3-2.6 on the back, but then everywhere I run is either bumpy or low grip.
At some point I think I'll get some RSD springs though to try.
Edit: With the new 2014 kit, I hope they do like an upgrade kit with the new chassis and blocks, although will Xray likely do that?, I'd be temped to get the RSD upgrade if not.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 09-05-2013, 04:28 AM   #4823
Trader Rating: 1069 (100%+)
Anyone know of a 12mm hex with +1.5 besides the XRAY +1.5s that will work? I'm wanting to run VTA fronts all the way around on my USGT car and would like the wheels to fit the body a little better
Less warning labels... more Darwin!
EZ Customs Paint / Xtreme RC
ON ROAD: XRAY T4 '15 USVTA/USGT X1 F1 , OFF ROAD RB6
and for those that don't know me.. I'm a sarcastic A DBL S
Dave Cates Founder of www.GO-RCing.org
bigwavedave33 is offline   Reply With Quote
Old 09-05-2013, 06:00 AM   #4824
Jerz616's Avatar
Trader Rating: 49 (100%+)
I have been searching for the same thing. I only found 6mm or 7mm hex's. integy has both. Spec r and top has 6mm and tamiya has 7mm. Look on tqracing and they have most of them.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 09-05-2013, 06:17 AM   #4825
Have you seen this: http://rcmarket.com.hk/product_info....da98f678684645
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 09-05-2013, 06:38 AM   #4826
I'm thinking these will be close: http://www.amainhobbies.com/product_...Hex-Set-Blue-4
I believe the Slash stub axles are 5mm. The XRAY are 4mm correct?
Old 09-05-2013, 08:17 AM   #4827
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Running the same spring setup too. Its a very nice balance and still easy to drive.
Have the RSD springs still new in package. Haven't opened them up yet because haven't felt the need to.
Dan is offline   Reply With Quote
Old 09-05-2013, 09:08 AM   #4828
Jerz616's Avatar
I think those will be to large. The T4 axle is a 4mm like you said and the slash is 5mm. So I would think you will have too much slop.
Ryan Gracey
XRAY XB8'14
Old 09-05-2013, 10:01 PM   #4829
Yea I swapped after the AOC, got tired of all the aftermarket parts on the Tamiya! Really liking the car so far!
Skiddins
When Talking to Alex he also said this, and that its a track dependent thing. For me they where better on a high grip indoor asphalt track, but I also did a lot of setup work to get the steering back into the car.
Antoni
Antoni Caretti
Old 09-06-2013, 01:16 AM   #4830
Odin544's Avatar
Trader Rating: 93 (100%+)
Why not just use some shims?
http://www.tqrcracing.com/shop/produ...w.asp?p_id=618
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
