Old 08-20-2013, 07:53 PM   #4771
The belts will stay white as they are already available. I've been using them for a while and they are much softer than the black belts, hence "low friction".
Andrew S is offline   Reply With Quote
Old 08-20-2013, 07:56 PM   #4772
stro3579's Avatar
Trader Rating: 20 (100%+)
Whats the part numbers for the low friction belts.
stro3579 is offline   Reply With Quote
Old 08-20-2013, 08:00 PM   #4773
http://rcmarket.com.hk/product_info....ducts_id=15069 for front belts
http://rcmarket.com.hk/product_info....ducts_id=15068 for rear belts
Old 08-21-2013, 02:11 AM   #4774
Odin544's Avatar
Trader Rating: 93 (100%+)
RcAmerica has them as well.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 08-22-2013, 11:46 AM   #4775
Has anyone tried Hagberg's ETS Gran Canaria setup on a US parking lot track? It uses kit springs so I was thinking of trying it. The big differences from kit asphalt seem to be -.75 front roll center, .5mm of arm sweep, shocks one hole down, middle front camber link, camber link shimming, and a low rear diff.
Last weekend turned out to be a practice day. The car seems to work well with the kit asphalt setup. I couldn't spot any particularly bad behavior, but I'm still getting used to mod. If anything, calming the car down a bit so I can be more aggressive with the throttle would be the most help, I think. Maybe a bit more steering while braking, but that may really just be a track layout thing. More overall grip in the corners would be nice, as always.
After all that effort I put into balancing the car, when I got the car home and put it back on the scales, the left side was reading 15g heavy. No idea how that happened. So I leveled my pit board on the workbench and dove back into it. I moved the arms forward 1mm (added 1mm ackerman shims to compensate), and put 4x 7g on the right rear next to the layshaft bulkhead. The car is back to 50/50 left/right, and about 51.7% rear. I'm hoping the extra rear weight will calm down the corner exit steering a bit. I also had very small tweaks in the swaybars that I got rid of. Xray could stand to go to an endlink more like HB/TOP for easier/finer adjustment of the endlinks.
I also went to AE 35wt (425cst according to bottle) all around, in hopes of just making the car easier to drive, and maybe keeping the tires a bit cooler.
-Mike
Old 08-22-2013, 12:47 PM   #4776
Skiddins's Avatar
-Mike
While I can't comment on a lot of his setup, I have tried the anti-dive at the front. But I found it reduced the steering slightly.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is online now   Reply With Quote
Old 08-23-2013, 07:48 AM   #4777
mac853's Avatar
Cool
TC Pro Matched Big Bore Short Spring from Ride:
http://rc-ride.co.jp/product.php?cat_id=7
mac853 is offline   Reply With Quote
Old 08-23-2013, 09:55 AM   #4778
chasingthepack's Avatar
-Mike
i also tried the anti dive but got better results from using the stock arm mounts and putting a 1mm shim under the fr,initial turn in is better but mid corner suffers a small amount and no arm sweep just the 1.5 shims,exit is better too as forward traction and on power steering in increased
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 08-23-2013, 01:16 PM   #4779
rangerjkb's Avatar
Trader Rating: 39 (100%+)
Send a message via MSN to rangerjkb
Received the new Low Friction Blets from RCAmerca, took about 3 days. Can't wait to see how well they work.
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Old 08-25-2013, 07:14 PM   #4780
Odin544's Avatar
Which RSD springs are equivalent to Xray 2.3 and 2.5?
TriCitiesRC.com
Old 08-25-2013, 07:37 PM   #4781
CristianTabush's Avatar
There is no "equivalent" springs. Our black are like 2.4 and our blue are like 2.55. While our pink would be a 2.65. They behave differently though. A blue front/black rear feels similar to 2.5f and 2.3r.
Personally, I like Blue or pink front with a yellow progressive rear on carpet and silver f yellow progressive rear on asphalt.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 08-25-2013, 07:49 PM   #4782
yodace's Avatar
R/C Tech Charter Subscriber
Do have a pic of where u put the shims by chance ?
yodace is offline   Reply With Quote
Old 08-25-2013, 07:53 PM   #4783
Odin544's Avatar
TriCitiesRC.com
Old 08-25-2013, 09:45 PM   #4784
no pic,but if you look at the front of the car where the arms attach to the mount the shims go between the chassis and the front rear mount,some people are using split mounts in this position,if you look in the t4 manual it says its a tuning tip and what its for
Old 08-26-2013, 10:17 AM   #4785
erchn's Avatar
Maybe that's why yodace wanted a picture. In your previous statement you stated you didn't like anti-dive, but what you describe here *is* anti-dive.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
