Old 08-19-2013, 06:27 PM   #4756
jag88's Avatar
Originally Posted by Adam B View Post
Really? How about run it before doing so, see what times you get. Then put them in to see if you really feel a difference.
Logic has no place in toy car racing ... lol
jag88 is offline   Reply With Quote
Old 08-19-2013, 11:03 PM   #4757
Tekin Prodigy's Avatar
Trader Rating: 55 (100%+)
Hey guys. What are the latest setups you all have found to be working in regards to spring and shock oils??? Most setups are softening the car up from kit springs compared to the stiff setups of the t3. Also seeing a lot of setup sheets with thicker rear oil than front. Anyone want to elaborate so I can further my knowledge with this car? Thank you!
Xray T4
Tekin Prodigy is offline   Reply With Quote
Old 08-19-2013, 11:03 PM   #4758
B00t13g's Avatar
The only parts I've really worn are blades and belts in mod. In my old stock car all I wore were tires.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 08-19-2013, 11:22 PM   #4759
Trader Rating: 27 (100%+)
How much of a difference does running upper/lower diff positions make? Pretty much every setup sheet I've seen has upper front/lower rear diff positions.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 08-20-2013, 02:39 AM   #4760
Skiddins's Avatar
I can't tell any difference
Lower is supposed to give more traction but if there is a difference it's tiny.
It's more important to use the adjusters to get the belt tensions right, which in my case means the diffs are actually closer to the centre anyway
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-20-2013, 02:50 AM   #4761
Skiddins's Avatar
I seem to recall Hagberg saying that the stiffer rear oil is supposed to help with stability through chicanes etc.
Someone tried it on medium carpet at my club and didn't like it. He was faster when he changed it back.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 08-20-2013, 03:07 AM   #4762
Bishop's Avatar
I lowered mine among some other tweaks at an event during the weekend, did feel like it created an improvement, but then with the other changes maybe I imagined it, either way it did not hurt anything so I'll leave it like that.
My past weekend was fun, first time racing mod, I was average at best, but I liked the T4, actually had a couple of big traction rolls, which surprised me in mod, good car, the in part Hagberg setup I threw on the car worked nice, ended up with different springs though, but really the Panaracer tyres I got from a fellow racer were epic.
I may have the mod bug now (speed...), though I'm dropping back to stock come the state champs next month...
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 08-20-2013, 10:18 AM   #4763
daleburr's Avatar
Originally Posted by reg View Post
What's the wear like for those that have ran week in week out since the car came out,
More the high cost things like diff out drives and drive shafts,
Ran mine all season, sometimes three days a week. Replaced the rear blades a few times (if you replace them before they get too sloppy it reduces the wear on the outdrives). Replaced the front spool outdrives once (these are a cheap enough part as they're plastic). And replaced some of the wheel bearings.
Everything else is original It's nice that paying a bit more up-front reduces the ongoing costs. The car really is bullet-proof and fantastically engineered.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 08-20-2013, 10:29 AM   #4764
erchn's Avatar
Agreed. The belts are too tight in the rear and too loose for the front belt. I end up running mine around center as well.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 08-20-2013, 03:46 PM   #4765
reg
Wow that's a lot of run time
Brilliant feed back and follows what everyone else is saying,
Do people think the new parts that will come on the T4 2014 will be available to buy and update a 2013 car?
reg is offline   Reply With Quote
Old 08-20-2013, 03:58 PM   #4766
cwoods34's Avatar
If the "rumor mill" holds true, you'll need a new chassis plate and the hingepin blocks. Other items of note have been white belts (may be black in production) and the new option enclosed layshaft bulkheads (available now).
Other than that I'd guess it'll be the same car.
Reflex Racing will be releasing a T4 chassis that uses the same style hingepin mounts so you could also "update" your 2013 car that way
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 08-20-2013, 04:54 PM   #4767
rosko's Avatar
Could u use play doh in gear diff (front) if so would it be thicker than 500k. Any suggestions on what i could use without having to order offline and not ruin the diff
rosko is offline   Reply With Quote
Old 08-20-2013, 05:14 PM   #4768
Hagberg's car at Euros also looked to have a top-deck support at the front of the motor mount.
-Mike
Old 08-20-2013, 05:21 PM   #4769
locked's Avatar
You could try it. I doubt it would ruin it, but it might be difficult to clean out. Worst case, it's possible that it could swell the O-rings. I've heard of people trying all sorts of odd things in their front diff, like chopped up earplugs. Some use cleaning putty. Playdoh might start to break down and I think it might be a bit too soft to begin with.
I tried GravityRC 2.5mil up front for a few races, but I ended up going back to a spool.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 08-20-2013, 06:42 PM   #4770
cwoods34's Avatar
-Mike
Oops that's what I forgot! I'd guess with adding so much flex to the car that moving the "pivot" point to the middle of the upper deck balances it out front to rear.
I hope the belts stay white for production.... I don't know why but I think it looks cool
Xray T3 2012 rasta_man Electric On-Road 4227 11-14-2017 05:49 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14337 11-10-2017 08:19 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
