Old 08-16-2013, 03:46 AM   #4711
Tamiya F104 V2, TT-01E CS Drifter
XRAY T4 '13
Yokomo R12C3
d.k.vmatt is offline   Reply With Quote
Old 08-16-2013, 04:09 AM   #4712
Skiddins's Avatar
Originally Posted by grippgoat View Post
Does anyone shim the motor for weight balance? I'm playing with scales after installing my new LRP flow and X20 5.5, and my car is about 14g heavy on the battery side. I have 14g in the middle that I can move out under the receiver, but I don't think it'll be enough. I still have another 14g to add, but with the way I placed the esc (wires facing motor), I don't have any more free space, except behind the motor and in front of the servo, neither of which are very far out. With 2mm shims between motor and mount, it's only 7-8g heavy on the battery side. I just don't know if that will compromise the integrity of the motor mount and lead to stripped spurs. I'm missing that schui motor clamp a bit right now.
-Mike
Someone mentioned they had an option part for shimming out the motor to try and increase roll.
It was pointed out that moving that weight out also changes the CoG etc and can make for inconsistent handling.
For 14g I would just leave it as is
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-16-2013, 08:53 AM   #4713
Trader Rating: 9 (80%+)
When's The Xray T4'14 Release Date? Alex Looked Very Fast With The New Mods
Dan-Dan Team-X is offline   Reply With Quote
Old 08-16-2013, 09:49 AM   #4714
Bishop's Avatar
14g is really not a lot, mine is way more than that, brings up an interesting subject though cause I was just putting the finishing touches on mine tonight, and I did notice just how light the T4 is on the motor corner, hard to find room to put weight back there as well with my cooling fan etc.
I weighed mine again after all the prep work, still like 30g under weight (it's 1380g for this event), no effort has been made to make my car light, so I'm impressed, but I got to find spots to put that much weight on, tricky on the T4, harder when your trying to balance it, in the end mine is going to probably be 25-30g heavier on the battery side.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 08-16-2013, 10:35 AM   #4715
pics of your layout? I got that reflex racing mount thats aluminum to mount a fan to it, that should add weight. Currently, I have just a smaller fan shoe good in behind the motor, like I have always done. I ordered a 30x30 muchmore fan, hopefully it cools well.
X-ray T4'16 stock TC, Xray T4'15 mod sedan, Xray xb4. Xray, Motiv, Team debit card.
Boostinswifty38 is offline   Reply With Quote
Old 08-16-2013, 10:39 AM   #4716
daleburr's Avatar
-Mike
Can you stick the ballast to the outside of the ESC, receiver or servo? Or put it under the receiver since that basically weighs nothing so raising it up won't change the CoG a great deal.
If it's only 14g off measured at the wheels that's not a big deal, although since you've got to add some ballast it makes sense to use it to get the car balanced.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 08-16-2013, 10:53 AM   #4717
elee32's Avatar
Trader Rating: 18 (100%+)
Here is a pic of another way to install a cooling fan. Use a servo mount post, thread a grub screw into the hole on the bulkhead then screw the servo mount to that (kind of how the shocks mount to the arms). Now you have room to add weight underneath your fan
Eric Lee, sponsored by shipping and handling..
elee32 is offline   Reply With Quote
Old 08-16-2013, 11:02 AM   #4718
On the subject of weight balance... Any suggestions for front/rear targets for asphalt? With body off, I'm close to 50/50 front/rear. Just about 5g heavier per rear corner.
-Mike
Old 08-16-2013, 11:51 AM   #4719
erchn's Avatar
-Mike
I find about 52% rear weight is a good target.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 08-16-2013, 12:57 PM   #4720
chasingthepack's Avatar
-Mike
mine was similar,instead of weights put it to good use and get a motor heatsink and fan
the lrp heatsink is 15 gms
have you moved the electrics as far out as you can? also using longer wire,more weight
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 08-16-2013, 01:31 PM   #4721
Thanks. Is that body on or off?
-Mike
Old 08-16-2013, 03:22 PM   #4722
erchn's Avatar
-Mike
Off.
Old 08-17-2013, 01:06 AM   #4723
21g under rx, and 14g behind motor fan. No motor shims. About 1390g total, 2g heavy on battery side, and 50.7% rear. Close enough.
Gotta install my DCJs, and then tomorrow.
I'd post a pic, but the wiring still looks pretty shoddy. :/
-Mike
Old 08-17-2013, 01:18 AM   #4724
How do you guys get your weights, do you have corner scales?
XRAY T4 '13
Yokomo R12C3
Old 08-17-2013, 02:00 AM   #4725
I have some cheap digital scales I found on ebay from hong kong. They get the job done. I don't use them for tweak, though. It's a bit finnicky to get the car settled evenly. I just use them for left/right and front/rear balance.
EDIT: You can get left/right balance really close by just lifting the car with hex drivers under the center of the shock towers, though.
-Mike
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 02:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 03:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
