Old 08-14-2013, 10:27 PM   #4696
cyba888's Avatar
Originally Posted by Odin544 View Post
Read the last few pages. There are also pics posted of the '14 prototype.
Don't recall reading any changes besides the suspension blocks?
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 08-14-2013, 10:34 PM   #4697
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
That's a well deserved change! Finally!
Josh-n-ya is offline   Reply With Quote
Old 08-14-2013, 10:56 PM   #4698
I haven't found an issue with the current suspension? why change?
Tamiya F104 V2, TT-01E CS Drifter
XRAY T4 '13
Yokomo R12C3
d.k.vmatt is offline   Reply With Quote
Old 08-14-2013, 11:48 PM   #4699
Odin544's Avatar
Trader Rating: 93 (100%+)
Thats because thats the only changes that have been noted so far. And whether that will be the production car or not is anyones guess at this point. Xray doesn't usually tip their hand early do they? Not to mention the worlds are coming up and they wouldn't want other people copying anything they may have hidden so far. If they think they have an edge they certainly don't want other mfg's knowing about it.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 08-14-2013, 11:54 PM   #4700
Odin544's Avatar
Evolution? If we went with that thought process we'd still be running brushed motors and NiMH. I don't find anything necessarily wrong with the T4 suspension either. But there is always room for improvement. I love the idea of XB4 style inserts. Gives you the solid mounting like the Tamiya uses, but no need for $100 in different blocks. No more checking the suspension mounts after every single run to get the slop out. The maintenance improvement alone would make it worth it to me.
TriCitiesRC.com
Old 08-14-2013, 11:57 PM   #4701
Bishop's Avatar
Less parts, slightly freer movement, to be honest I was never a fan of full toe blocks, but I do like what has happened with them now with the inserts, it's just a design feature I like the look of.
I'd bet based on what I have read about, Xray are likely testing all sorts of tweaks, that previous pic likely just shows us one set of parts being tested.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 08-15-2013, 02:14 AM   #4702
Skiddins's Avatar
Ill add to the chassis scratch shots.
Vta isn't friendly, looks like the bottom has been sand papered.
and my tapered rear.
What the photo dosent show is how much has worn away on the rear there, those rear screws don't have a lot of the hex left depth why
Replace the screws with no depth before they become a nightmare to remove
I often run a piece of cell tape down each side of the car on the outer parts of the chassis so any scratching or curbs gets the tape before the chassis, then replace it every few runs.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-15-2013, 09:26 AM   #4703
Bishop's Avatar
Did some more work on the T4 today, prep for an interclub round, car be looking good, all fresh wiring, lots of little changes...
The New Xray T4 '13-t4wiring01.jpg   The New Xray T4 '13-t4wiring02.jpg   The New Xray T4 '13-t4wiring03.jpg
QRCCRA
www.qrccra.org.au
Old 08-15-2013, 09:57 AM   #4704
locked's Avatar
Missing a few screws in your top deck Bishop. Don't forget to put them back in.
I accidentally ran the car once with the screws missing from an entire half of the top deck. It really didn't handle as bad as you might think it would. Not a recommended setup though.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 08-15-2013, 10:01 AM   #4705
rosko's Avatar
And narrow chassis
rosko is offline   Reply With Quote
Old 08-15-2013, 08:14 PM   #4706
RCknight's Avatar
It was only a matter of time boys.
Now if Xray would only fix the steering by flipping the steering arms and making shorter posts so we can remove the stupid steering steering limit. Humm...the benefits? Less weight, fewer shims, reduced parts count, lower cg, and no steering limit. I'm sure this feature will be on the T15. lol Then add a 5th body mount on the front tower and a beefier motor mount. Fingers crossed.
RCknight is offline   Reply With Quote
Old 08-15-2013, 08:53 PM   #4707
mac853's Avatar
If is worthy to use this to have more flexibility:
http://www.cso.com.hk/htdocs/modules...ex.php?nsn=296
mac853 is offline   Reply With Quote
Old 08-15-2013, 10:22 PM   #4708
Too much steering travel starts to work against you once you go past a point.
It becames more involved, but if you need more steering, you have to look at other areas than the psychical limit of steering travel.
Think of it like timing on our motors, over 60 degrees then your not achieving much after that!
Andrew S is offline   Reply With Quote
Old 08-15-2013, 10:59 PM   #4709
RCknight's Avatar
Thanks for keeping me in mind. lol
Originally Posted by syndr0me View Post
I'll alert the media!
Old 08-16-2013, 02:29 AM   #4710
Does anyone shim the motor for weight balance? I'm playing with scales after installing my new LRP flow and X20 5.5, and my car is about 14g heavy on the battery side. I have 14g in the middle that I can move out under the receiver, but I don't think it'll be enough. I still have another 14g to add, but with the way I placed the esc (wires facing motor), I don't have any more free space, except behind the motor and in front of the servo, neither of which are very far out. With 2mm shims between motor and mount, it's only 7-8g heavy on the battery side. I just don't know if that will compromise the integrity of the motor mount and lead to stripped spurs. I'm missing that schui motor clamp a bit right now.
-Mike
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
