Old 08-14-2013, 04:50 AM   #4681
Xray T4 2014
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 08-14-2013, 05:47 AM   #4682
Skiddins's Avatar
Originally Posted by jorgesimes View Post
Xray T4 2014
If you look at page 305 of this thread, I posted that pic a week ago
It's a prototype of the T4'14
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-14-2013, 06:54 AM   #4683
oladele's Avatar
Originally Posted by Bishop View Post
Quick pic, and on mine with this setup, the servo saver will touch the steering post just about the same time your hitting full lock, so not a big deal, depending though on if your trying for more steering travel.
Looks like you have a few things going on there that is preventing more steering
A) at the end of your steering link you need more shimming (4mm)
B) the composite shims you have on your linkage belong at the other end
C) don't use ball cups
This will raise the linkage and allow for more steering, you can dremel where the linkage is hitting a mm or so.
oladele is offline   Reply With Quote
Old 08-14-2013, 08:05 AM   #4684
Skiddins's Avatar
If at full lock his steering knuckles are just off hitting the arm, he has full lock (the shims under the Ackermann plate in the center act as an 'endstop') . So there's no need for more.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 08-14-2013, 08:27 AM   #4685
Ur servo looks high.
Undo screws through servo put ur stitcher sheet under servo (acting as a spacer so servo doesn't touch chassis. Put ball back in top middle and before doing up servo screws just move it out as far from center against the mount hopefully that will be enough to change the angle of the link.
Not sure if this has been advised yet just something I would try.
J
Jampot is offline   Reply With Quote
Old 08-14-2013, 08:34 AM   #4686
oladele's Avatar
Skids, question I'm kind of new at this so I could be wrong so I'm asking your opinion. He and I have the same servo when looking at his and mine by me having the 4mm shim it raises the ball joint so when it reaches its max steering or hits the arm it not hitting the ball joint but rather the shim which is about 1-1.5mm slimmer then the ball joint thus giving him more steering, because it can now turn an additional 1-1.5 mm? Please don't take offense I'm learning so I'm asking questions because I'm rather new to Rc.
Old 08-14-2013, 08:46 AM   #4687
Bishop's Avatar
Um, I posted the picture as an example/result, in that I now have perfect steering throw both direction, with the exact same end points on the radio settings, I can get maximum possible lock each direction without anything touching, it clears the top deck, and does not bind anywhere, it's purely a follow up to past discussion going back a few pages or more.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 08-14-2013, 11:56 AM   #4688
Skiddins's Avatar
That's fine, my response wasn't meant to sound sarcastic (just in case )
When you say 4mm shims are you referring to the shims on the Ackermann plate?
When the shims on that plate hit the steering arms, the steering knuckles should almost be touching the C-hubs. THis helps protect the C-hubs from damage in a crash when on full lock etc.
Do you have some setup gauges with a toe measuring plate? You could use them to see what steering lock you're getting.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 08-14-2013, 01:57 PM   #4689
oladele's Avatar
Yes that what I was referring to in the case of the 4mm shims. Yes I have the set up tools. I will let you know what I'm getting.
Old 08-14-2013, 02:19 PM   #4690
B00t13g's Avatar
I get 25 left and right, kind of curious what everyone else is getting. I'm measuring steering angle with a hudy setup station.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 08-14-2013, 02:23 PM   #4691
chasingthepack's Avatar
thats how i measure mine but when you think about it we're only checking the inside wheel,not the outer wheel which is the one that counts,depending on ackerman settings i think im getting about 20deg on the outer,im getting 23 on the inner
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 08-14-2013, 06:54 PM   #4692
Odin544's Avatar
Trader Rating: 93 (100%+)
You can check both the inner and outer wheel with the Hudy setup station.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 08-14-2013, 07:07 PM   #4693
Any hint at the changes for the 14?
Tamiya F104 V2, TT-01E CS Drifter
XRAY T4 '13
Yokomo R12C3
d.k.vmatt is offline   Reply With Quote
Old 08-14-2013, 09:02 PM   #4694
Odin544's Avatar
Read the last few pages. There are also pics posted of the '14 prototype.
TriCitiesRC.com
Old 08-14-2013, 09:40 PM   #4695
Ill add to the chassis scratch shots.
Vta isn't friendly, looks like the bottom has been sand papered.
and my tapered rear.
What the photo dosent show is how much has worn away on the rear there, those rear screws don't have a lot of the hex left depth why
XRAY T4 '13
Yokomo R12C3
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
