Old 08-10-2013, 03:55 PM   #4636
Odin544's Avatar
Trader Rating: 93 (100%+)
Originally Posted by oladele View Post
Anyone know where in the states you can order the new XRay closed Layshafts part# 303056? I can't find them anywhere not even XRay's own website!
I just got mine yesterday as well as the new white belts , but I had my buddy who is an Xray driver order them. He ordered them direct from RCamerica I believe. So I know they have them. Maybe give them a call?
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 08-10-2013, 05:15 PM   #4637
Skiddins's Avatar
Originally Posted by cyba888 View Post
Thanks do they hold up on asphalt? I see you run carpet mostly
I run both roughly equal amounts.
Ok, so far.
The big test is tomorrow with a track that has a banked sweeper that isn't that smooth
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-10-2013, 05:44 PM   #4638
cyba888's Avatar
Ok, so far.
Thanks let me know how it holds up
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 08-12-2013, 03:16 AM   #4639
alecladanga's Avatar
hi guys, i know this has been asked ages ago but i cant seem to find the answer:
my servo link is hitting the top deck and i followed the assembly as per the manual. what did i do wrong? what should i look at it all looks fine at a distance. Since its hitting the top deck, i can't get full lock on right.
many thanks in advance.
alecladanga is offline   Reply With Quote
Old 08-12-2013, 03:32 AM   #4640
Post a picture mate
Tamiya F104 V2, TT-01E CS Drifter
XRAY T4 '13
Yokomo R12C3
d.k.vmatt is offline   Reply With Quote
Old 08-12-2013, 03:55 AM   #4641
Jerz616's Avatar
Trader Rating: 49 (100%+)
What kind of servo are you using. A picture would be good to see.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 08-12-2013, 04:11 AM   #4642
daleburr's Avatar
This can happen (it's very close on mine using a Savox 1251).
The solution is to lower the servo on the mounts. Put a couple of pieces of card between the servo and the overhead carbon mount, then tighten the mounting screws, then remove the card.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 08-12-2013, 04:17 AM   #4643
Skiddins's Avatar
You've almost certainly put the steering arms on the wrong way up
Look carefully at the black plastic parts in the following picture;
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 08-12-2013, 06:25 AM   #4644
PDR TOO's Avatar
Trader Rating: 24 (100%+)
I had a similar problem with a pre built T4 I purchased.
Make sure the flat surface of the turnbuckle is horizontal so that it doesn't hook up on the top deck.
I found that by removing 1mm from the spacers between the ball stud and the servo saver, the slight angle created allowed the turnbuckle to be further to the rear of the curve in the top deck. This was sufficient to stop it catching.
I expect there are minor differences in servo dimensions between brands which will cause these minor irritations.
SMA .....The Track.
Previously Raced Vehicles keep me on the track - sort of.
PDR TOO is offline   Reply With Quote
Old 08-12-2013, 10:07 AM   #4645
chasingthepack's Avatar
damian i heard you were in a car crash,hope your ok
this happens on my sons t4 (savox)i have checked the pics and there correct,its with the top hole on the standard servo horn,i use a different horn on mine and it doesnt hit,i had to use the lower hole to get the clearance on his
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 08-12-2013, 10:17 AM   #4646
I'm using a savox and its close but there is still enough room that it dosent touch when I crash haha
XRAY T4 '13
Yokomo R12C3
Old 08-12-2013, 11:30 AM   #4647
The only thing I can think of is maybe the servo is sitting too high. My linkage is close, but doesn't hit (although I'm going to go double-check tonight now that you mention it).
-Mike
Old 08-12-2013, 03:26 PM   #4648
Fjeld's Avatar
Just take out the 6mm spacer and put on 4mm where the link is mounted to the alu steering plate.. Works for Adrian Berntsen so it works for me
|| Yokomo BD7 2015 || XRAY T4'15 ||
|| Muchmore Fleta POWER :D ||
Fjeld is offline   Reply With Quote
Old 08-12-2013, 05:49 PM   #4649
mikeohara's Avatar
I'm looking at buying and setting up a T4 in the near future (I do have a Yokomo BD7 that I'm eyeing as well), and have some general questions about the T4 that I hope you guys can answer.
1.) Is Xray really the best out there for on-road?? I'm wanting to buy something that will last me a good while, through my re-learning of RC (been out of it for a couple years).
2.) Am I gonna have to replace parts all the time? I tend to be a little rough on cars, and will be while I'm looking to relearn how to drive a RC car.
3.) What kind of part support can I expect? My nearest tracks are a couple hours away (Mike's Hobby Shop/Indy RC) in the Dallas area. From what I've been able to tell, XRay parts are more readily available than parts from Yokomo. Can I continue to see this in my shops?
Thanks Guys! Look forward to your answers soon!
mikeohara is offline   Reply With Quote
Old 08-12-2013, 06:27 PM   #4650
I don't have enough experience with my T4 yet to specifically address your questions, but I can tell you why I went with one.
First is price vs. performance vs. quality vs. tuning options. It's cheaper than the Yokomo, and pretty much everything comes in the kit. The only things I'm adding are DCJs, and some springs for carpet. I'm not even buying spares (except for the cheap Spec-R spool cups, and I should probably grab a rear belt), because I don't crash hard very often any more. And with the way the suspension arms mount, you can tune pretty much everything with just spacers. The Yokomo has a higher base price, and doesn't come with the center servo mount, and needs different suspension blocks for messing with rear toe, front sweep, and track width.
Second is straight performance. I care more about carpet than asphalt (because I race 2-3 times as much on carpet). XRays in general have always excelled on high grip carpet, and the T4's low-CG design concept was very appealing to me having struggled with traction roll a lot in the past. Also, pretty much everyone on here who got a T4 loved it straight out of the box, being right on pace or faster than what they had been running before.
Third is that it's an XRay. I felt like after driving not XRay for 3.5 years, it was time to try orange, and see if I like the taste.
If you were to go with the T4, though, I'd wait for the T4'14, which is probably only 2-3 months away now. Scroll back to the discussions of Hagberg's car at the Euros if you're wondering why.
-Mike
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
