Old 08-09-2013, 10:30 AM   #4621
Trader Rating: 20 (100%+)
Originally Posted by hyujmn View Post
That's why I love carpet! No scratches and the bottom deck always looks pristine.
Ah, I just don't look at the bottom of my car much while on track so it doesn't matter what it looks like.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 08-09-2013, 11:01 AM   #4622
mac853's Avatar
Originally Posted by Troy Carter View Post
I have not used any of it or anything similar.
But, I would not use the belt tensioner they have shown. It is a nicely integrated piece but I don't think you should put the take up on the bottom of the belt. If there is any slack in the belt that needs to be controlled it's on the top side because the bottom side will have the majority of tension when under load. With the take up on the bottom it's just one more turn for the belt to overcome while it's loaded and will stress the belt and be less efficient. At the same time the top will still be allowed to flop around all it wants under power.
IMO the belt tensioners should not be used strictly to make a belt tighter but to keep control of the loose section of the belt. That makes it smoother, last longer, and stay on the pulley when weird things happen to the car in a crash or other bump. When the belt starts to bounce around uncontrolled it can go anywhere, including off the pulley but that's pretty rare. Leaving this on top stops that and keeps the belt guided properly to the front diff. Most modern cars have enough belt tension built into the diff eccentric that you don't need these to keep the belt tight.
Yep, when you hit the brakes the top is then the tight side, won't matter much unless you're at a high grip track with a mod motor. Even then I'd rather keep the belt controlled and running smooth on the top as it feeds onto the pulley.
Thanks for explain!
mac853 is offline   Reply With Quote
Old 08-09-2013, 05:24 PM   #4623
Skiddins's Avatar
Originally Posted by cyba888 View Post
Any experience with this brand?
I have one on mine now. They're about 0.2mm thick
Doing it's job well so far.
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-09-2013, 09:07 PM   #4624
cyba888's Avatar
Are they same material as the AE?
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 08-09-2013, 09:18 PM   #4625
oladele's Avatar
I'm very new to this hobby and still have similac on my breathe, so pardon my ignorance. So with that being said why do all the fast guys run a a front diff over seas on asphalt but here in the states we run a spool? What are the pros and cons of each?
oladele is offline   Reply With Quote
Old 08-09-2013, 09:22 PM   #4626
Tighter tracks need the diff, Tracks without sharp turns can get away with the spool
Tamiya F104 V2, TT-01E CS Drifter
XRAY T4 '13
Yokomo R12C3
d.k.vmatt is offline   Reply With Quote
Old 08-10-2013, 03:50 AM   #4627
Skiddins's Avatar
They are a sort of vinyl.
The back of the sheet they're on reads;
Oracal 651
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 08-10-2013, 03:53 AM   #4628
Skiddins's Avatar
Originally Posted by oladele View Post
...why do all the fast guys run a a front diff over seas on asphalt but here in the states we run a spool? What are the pros and cons of each?
They don't. Almost everyone runs a spool. (I run a diff in Mod on asphalt tracks to calm the car down under power
Carpet or asphalt, most drivers always run a spool to get the better drive out of corners. I'm one of the only people I know to run a front gear diff.
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 08-10-2013, 04:51 AM   #4629
oladele's Avatar
Thanks Skiddins
Old 08-10-2013, 04:55 AM   #4630
oladele's Avatar
Anyone know where in the states you can order the new XRay closed Layshafts part# 303056? I can't find them anywhere not even XRay's own website!
Old 08-10-2013, 09:13 AM   #4631
Skiddins's Avatar
No idea what postage would be;
http://demonpowerproducts.co.uk/prod...ulkhead-p-7954
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 08-10-2013, 09:18 AM   #4632
Barry_Hughes's Avatar
I have been running front gear diff at Coastal Model Car Racing Club as the Asphalt track is tight & technical and I found the gear diff better than the spool.
On larger flowing tracks the spool seems better
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 08-10-2013, 09:42 AM   #4633
cyba888's Avatar
Oracal 651
Thanks do they hold up on asphalt? I see you run carpet mostly
Futaba 4PX
Old 08-10-2013, 12:49 PM   #4634
T4 for sale?
Zooberg is offline   Reply With Quote
Old 08-10-2013, 01:10 PM   #4635
chasingthepack's Avatar
he races on both
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 02:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 03:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
SEO by vBSEO 3.5.0
