Old 08-08-2013, 12:28 PM   #4591
Originally Posted by locked View Post
Flexes at high speed(some use a 5th body post to counter this)
Speaking of which, how are people doing that on the T4?
-Mike
Old 08-08-2013, 01:05 PM   #4592
locked's Avatar
-Mike
Yeah, I should have added that I haven't seen anyone with a 5th post on a T4, yet. I think you could make a custom bridge piece to go over the front belt using two of the holes at the front of the topdeck that go into the bulkheads. Hard to explain the idea in my head, but I'm pretty sure that something could be made to work.
You could maybe mount one on the top deck's front hole that is meant for a belt tensioner, but it might be difficult to get it to not touch the front belt, and might be a bit too far back to be effective.
locked is offline   Reply With Quote
Old 08-08-2013, 01:14 PM   #4593
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
I have had a 5th on my car since last Oct . I'll post a pic in a few
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 08-08-2013, 01:27 PM   #4594
Works great I put it on that side since we run clockwise it keeps body from dragging if fenders r cracked any and I have swapped it to other side when we reversed the layout . it was a quick easy free 5th mount is at bottom of windshield I feel the perfect spot to get more strength
Justin & Matt Lyons
a800s sanwa m12s
Old 08-08-2013, 01:38 PM   #4595
chasingthepack's Avatar
or you can drill a hole in the shock tower etc etc
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 08-08-2013, 02:25 PM   #4596
Originally Posted by jlfx car audio View Post
The RSD battery holders r the POO! If and when u get them make sure they don't lock down on battery u want .2-.4mm spacing between the battery and tab. It keeps chassis form tweaking and keep form bending them in a hard crash . I put a thin nylon washer under each so I could squash it to the correct distance . good luck
Ok cool, thanks for the advice. How have you stopped the battery getting amazed by the belt and motor?
Mwdynamics is offline   Reply With Quote
Old 08-08-2013, 03:12 PM   #4597
Theirs 2 small m3 nuts on bottom of chassis keeping it from moving in
Justin & Matt Lyons
a800s sanwa m12s
Old 08-08-2013, 03:25 PM   #4598
Why didn't u use the hole in the top deck next to the where ur post is in that pic, I've used a 5th body post once and put it there use a front body post cut down as appropriate then if u need to raise add washers underneath.
U don't need to put a hole in the shell just as long as the shell touches the post it can't collapse in.
Jampot is offline   Reply With Quote
Old 08-08-2013, 04:30 PM   #4599
Skiddins's Avatar
Originally Posted by cyba888 View Post
Anyone tried LTCR lightweight body? Would this work on 4.5t motor running asphalt?
Yes, but I found I was more consistent with a PF Speed6, think it depends on the grip levels etc.
I only use lightweight bodies as the cars handling is improved, it's much better at direction changes.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-08-2013, 04:40 PM   #4600
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
I use two associated 12th scale body posts with set screws and mount it where the two screws go for the bulkhead caps on the rear of shock tower also use the nt1 rear bumper stops on the back of the car
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-MCFACTORY MOTORSPORTS-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 08-08-2013, 08:47 PM   #4601
cyba888's Avatar
Hagberg's European Championships 2013 he also used LTCR LW body. I dont recall seeing a 5th body post on his car. I do not mind the flex at high speeds as long as it doesn't slow me down?
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 08-08-2013, 09:21 PM   #4602
I really enjoy reading this thread, and watching you guys the masters at work with dialing it in.
I have a question: Am I breaking some unspoken rule of RC by having my T4 as a street queen and running it day in and out on my street?
I very much want to hit the track and keep it in tip top shape; but i need to feel the speed more often then i'm able to make it to the track..
I've noticed my chasis is getting pretty scratched up and I've sparked out many m3 screws at this point and munched up the $13 bumper, Can you guys that are track only post pics of the bottom of your chasis so i can compare.
Forgive the bald tires and the scratched turnbuckles (replacements are coming)
and clearly i have a new chassis purchase coming in the near future, any idea if the T4 2014 chassis will be compatible with the parts
Xray T4, RC10T4.2, RC10B4.1 to 4.2 conversion, Axial SCX10 Jeep, 1/8 ERBE, OFNA DM1 spec E (going for 100mph).
BC2G is offline   Reply With Quote
Old 08-08-2013, 09:29 PM   #4603
B00t13g's Avatar
I would probably keep your t4 as a basher and get the new car as your track car. Did I just say basher and t4 in the same sentence?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 08-08-2013, 09:37 PM   #4604
i feel pretty bad about bashing this... i'm doing it... but feel bad
i mean its a freaking 1k+ car....
maybe i buy a basher team associated street car and put a new chassis on this and keep it track only
Old 08-08-2013, 09:49 PM   #4605
Trader Rating: 27 (100%+)
Damn that T4 for sure has seen better days.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
