Old 08-06-2013, 09:18 PM   #4576
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thumbs up
That's really good stuff Goat
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 08-06-2013, 09:54 PM   #4577
hotrod1933's Avatar
Mike
Thanks for the detailed reply. Answers below.
I usually am now getting good consistency but as stated get the odd blinder lap.
Within a given round (to take out track evolution differences), how far off the pace of front-runners are you?
Sometimes the same, (19 sec lap) last night 0.5 slower. last time we ran during the day i was slightly quicker on my good laps but he is definitely better overall.
Are you using the same tires? yes and no. Mostly we use Muchmore 28-32's. Daytime lately the MM Rush 36X have been good. I am thinking I am going to soft maybe as well which gives massive grip but lets you drive harder which may not be as quick. Feels quicker but is not.
Same tire age probably newer
Same tire prep similar
What is the difference between your fastest lap and your top 20 average (consistency)? usually around 0.8 or better some days 0.2 a lot depends on traffic
Some things that would be helpful to know are track type, grip level, layout, tires.
outdoor asphalt two old tennis courts. smooth, grip medium. layout technical but has open areas.
1) Consistent car setup. Have been getting pretty anal on this. mainly keeping car to same setup not playing around to much.
inner roll shims about the only thing changing with grip level.
2) Drive consistent. reasonably good for experience as only a year into it.
3) Don't overdrive the car. this is what I think I am doing. there are areas where you can mash the throttle but i think a bit more progressive and smoother may be the answer. Used to notice it more when i ran VTA you had to go smooth to go fast.
4) When in doubt, drive a tight line and shorten the track. Definitely doing this. usually can go inside a lot of the field.
5) You still have to push, though. Agree. Some areas I can gain heaps at corner entry on others.
Regarding messing around with the radio: Ok
The only radio adjustment that I've stuck to is turning down dual-rate. Already down a bit but I know others are down a lot more.
Hoping this sunday is a practise day not race so i can try different things.
Thanks Stephen
XRAY T4-15 -- nbhc.com -- powerhouse performance -- sma.org
hotrod1933 is offline   Reply With Quote
Old 08-06-2013, 10:02 PM   #4578
Odin544's Avatar
Trader Rating: 93 (100%+)
+1 great post
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 08-07-2013, 12:47 AM   #4579
heretic's Avatar
Agreed, good piece of advice.
One thing that helped me tremendously as an exercise, is to turn down the dual rate to an absolute minimum to go around the track. I mean almost impossible to drive. Turn it down to 30% or something until you really, REALLY can't go lower. It will feel painfully slow, and it probably is, but give it 3 minutes and you will surprise yourself by actually managing to run some consecutive laps. Now run it some more, for a whole run. Doesn't feel so understeering after all ! Now look at the time sheets, sure it's far from your previous PB but it's not as slow as you thought. You can then add very slowly more dual rate, 5% by 5% each run.
What this does is forcing you to work on your lines and throttle control. Usually when you start to push the car and it rewards you with slower lap times, it means you are overshooting the corners and compensating by turning the front wheels too much. It feels fast but you are just killing your cornerspeed. With the trick above, there's a good chance you'll end up improving both your best lap AND your consistency, while still using less throw than before. Your front tires will probably wear less and be more consistent over the course of a run.
Just something that works for me.
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 08-07-2013, 03:20 AM   #4580
Bishop's Avatar
Originally Posted by heretic View Post
I don't have any numbers in mind but the weight difference between rubber and foam can be massive. The set of Ride 32's I have on my desk right now weighs in at 110g.
110g is lite, the MuchMores I have sitting on my desk weigh 128g, foams 'are' lighter, often depending on how much foam is left on them, or what the rims are, but I so love driving on foams...
Note on other subjects being talked about, I like having some scrub steer, the ability to steer beyond what will grip can be useful if you want to wash off some speed without hitting the brakes, also if your track has a mix of tight and open, you will often need a lot of lock regardless, learning that fine control of steering is key though.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 08-07-2013, 05:46 AM   #4581
PDR TOO's Avatar
Trader Rating: 24 (100%+)
The weight of the Ride tyres is affected by the inserts. The wheels with the red writing have the denser rubber inserts. The LT version with the blue writing have open cell foam inserts which causes them to be lighter (30 grams I have been told). I was caught out by this and was underweight at an interclub event this year when I changed from MuchMore VPM32 to Ride 28LT.
SMA .....The Track.
Previously Raced Vehicles keep me on the track - sort of.
PDR TOO is offline   Reply With Quote
Old 08-08-2013, 05:26 AM   #4582
Hi all,
I've got a t4 chassis, looking at getting a lipo graphite strap.
How are these installed without the battery sliding into the belt in the centre of the chassis?
Just a bit worried that my lipo is going to chew my belt up with one and there is not many instructions on installing these on the net. Been looking for a couple of days
Also I have a lrp sxx tc v2 esc, using my old 27mhz tx and Rx and the steering keeps twitching. Do I need to upgrade the radio gear? Go for 2.4ghz?
Thanks in advance!
Mwdynamics is offline   Reply With Quote
Old 08-08-2013, 05:37 AM   #4583
Jerz616's Avatar
Trader Rating: 49 (100%+)
Originally Posted by Mwdynamics View Post
Hi all,
Thanks in advance!
When you put the kit together you will see that there are 2 nylon nuts that attach to the chassis as a back stop for the battery. You won't need anything additional to prevent the batt from hitting the belt. I would suggest using battery tape or RSD's battery hold down system instead of thst full length piece that goes over the battery. I've been told by several good drivers thst those can create some unintentional tweak on your chassis if its not tightened correctly.
As far as your tx/rx, switching to 2.4 would definately help I would think as you wouldn't get any interference from outside electronics.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 08-08-2013, 10:08 AM   #4584
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
The RSD battery holders r the POO! If and when u get them make sure they don't lock down on battery u want .2-.4mm spacing between the battery and tab. It keeps chassis form tweaking and keep form bending them in a hard crash . I put a thin nylon washer under each so I could squash it to the correct distance . good luck
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 08-08-2013, 10:17 AM   #4585
cyba888's Avatar
Anyone tried LTCR lightweight body? Would this work on 4.5t motor running asphalt?
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 08-08-2013, 10:22 AM   #4586
erchn's Avatar
Yes, and yes. Works great.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 08-08-2013, 10:58 AM   #4587
cyba888's Avatar
Thanks what are pros and cos running LW?
Futaba 4PX
Old 08-08-2013, 11:15 AM   #4588
Trader Rating: 27 (100%+)
I installed them in mine and I love them! I have the rsd battery holders in every car
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 08-08-2013, 11:42 AM   #4589
locked's Avatar
Thanks. What are the pros and cons of running LW?
Pros:
Lower CoG, less prone to traction rolling
Less total weight
Cons:
Flexes at high speed(some use a 5th body post to counter this)
Sections of the shell can tear easier in a crash than regular weight, but regular weight shells tend to crack more(not always true. I've had a few brittle LW shells)
I only use lightweight shells now, but I usually smear a liberal layer of shoegoo in the valence and front wheel wells, after painting, to help extend their life.
locked is offline   Reply With Quote
Old 08-08-2013, 11:52 AM   #4590
I use a rattle can of liquid tape(from harberfreight) in my most prone to damage areas . tried really quick and is light enough to do a larger area without adding extra weight
Justin & Matt Lyons
a800s sanwa m12s
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
