Old 08-05-2013, 09:59 AM   #4546
bvoltz's Avatar
Trader Rating: 44 (100%+)
Originally Posted by TWILL View Post
I'm using button head screws, but I have used them in the past and end up having to Dremel them out of the car. ( CAN"T GET THEM TIGHT ENOUGH)
How much end play do you have in the motor? If it is a lot then the rotor will be allowed to move enough for the pinion to touch both the battery and button head screws. I'm keep my end play (shim the end plate side of the rotor) to a very small amount of end play. I do have marks (very VERY small mark in the battery case, but I 100% do not want the pinion to touch the motor screws. I have never had a problem with the motor sliding, unless in a hard hit. Make sure you are using a long enough screw to mount the motor. I have seen issues when a person only gets contact with a few threads in the end plate. Make sure that the motor screw is long enough to use 100% of the threads in the end plate, but not to long to touch the inside of the motor, I'm using 3 x 6 screws Button Head). If you still have issues, lightly coat the screws with BLUE loctite, let it dry out side of the motor, coat until you have a solid fit...Or a drop of blue loctite on the screws, and mount.. not too much....
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 08-05-2013, 10:06 AM   #4547
Skiddins's Avatar
You should be able to get almost any screw more than tight enough to hold the motor.
Check that the screws you're using aren't going too far into the can and jamming against the stator.
Also check the motor isn't up against the layshaft mount or the top deck.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-05-2013, 10:13 AM   #4548
Fjeld's Avatar
Originally Posted by chasingthepack View Post
ok ,started the race day with a car that was sweet to drive,after 1 round quali im 7th,so the rest of the day im trying to go faster,but this is where it all went wrong,the rear became very loose as the temps came up,i took the 1mm inner link shim off and although a little better its still loose,tried a 1.3 rear bar,still no good,went from 2.7 to 2.6 helped alot (i posted a faster time)but 3/4 mins in the same again,i tried standing them up,laying them down but just couldnt get the rear to grip,was i overheating the tyres? im not sure as i ran a set cold and it was still loose and didnt get better as they warmed,so what should be done and why,thanks
http://forum.teamxray.com/xform/inde...D=484&setup=t4
Where is it loose? Inn or out off the corner?
Front downstop to 6. rear spring 2,3-2,6 is something I would have tried..
|| Yokomo BD7 2015 || XRAY T4'15 ||
|| Muchmore Fleta POWER :D ||
Fjeld is offline   Reply With Quote
Old 08-05-2013, 10:41 AM   #4549
CristianTabush's Avatar
Originally Posted by Nathan Wilson View Post
Cristian, why do you think these relatively simple changes have given alot of steering? All down to chassis flex?
The chassis flex is very similar, so the only thing I can think of is the orientation of the split blocks, these should allow slightly more flex.
However, our prototype has a few different items on it as well, including:
-slightly longer steering arms (0.5mm longer). These do 2 things, they increase the steering speed and provide more steering lock than even our increased steering spacers.
-Spec R Top Deck and Center Post Mount: When used with a captured layshaft and no screws on the layshaft bulkhead the car has more flex around the motor mount, which to me makes the car get better forward bite and quicker entry steering. It also makes the car more reactive.
Personally the gains from the Suspension Mounts I have noticed is a more consistent car that even after hard impacts does not allow the arms to get loose. With the balls on the hinge pin, there is definitely less suspension stiction as well. The car seems to generate more traction over my other car with traditional mounts.
The narrower chassis build allows the car to roll a little deeper in the corner without hitting abruptly which I tend to think translates into better side to side transition and more middle of the corner steering.
I have learned a lot about chassis shapes developing different ones over the past 2 years. One thing is no matter how narrow your car is, the chassis will hit the track. Therefore, the narrower it is, the more the car will roll. More roll usually translates into more middle corner steering up until a point that it is too much and it can make the car lazy. While we could have made the chassis narrower, we have observed that 85mm is about the width that you want your chassis to have.
The last thing I want to elaborate on is the layshaft holders. Ours will be able to be keyed onto the chassis. When you don't use the upper screws on the layshaft, these will get cocked sideways with higher power motors, the keyed layshaft holder will make the car freer as the holders will not move.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 08-05-2013, 11:35 AM   #4550
Odin544's Avatar
Trader Rating: 93 (100%+)
Originally Posted by heretic View Post
Could someone tell me how much exactly a box stock T4 weighs ?
I mean, car complete except for body, electronics, and tyres.
( But WITH wheelnuts and bodyclips ;-)
Thanks !
I've got a car showing up this week sometime. As soon as I get it build I can weigh it for you.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 08-05-2013, 11:39 AM   #4551
hana166's Avatar
Hi
Are you using pre preg with 0-90 deg orientation or 0-45-90 layup for chassis?
What did you prefer?
I have made quite a few myself but have not come to any definite conclusions. Obviously most sheet is supplied 0-90
Cheers
hana166 is offline   Reply With Quote
Old 08-05-2013, 12:19 PM   #4552
chasingthepack's Avatar
i should have added this is on corner entry to mid
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 08-05-2013, 12:20 PM   #4553
hi,its sliding out on corner entry,i dismissed the 2.3/2.6 as i had no luck with them before
Old 08-05-2013, 01:14 PM   #4554
erchn's Avatar
I would probably go up in camber in the rear and/or reduce the front. 1.5 front and 2.0 rear should help.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 08-05-2013, 01:32 PM   #4555
Originally Posted by hana166 View Post
Hi
Cheers
We have tried both. They have their advantages, but nothing too noticeable. Typically the 0-45-90 stays more firm over a longer period of time, where the 0-90 de-laminates more quickly and provides more flex. The 0-90 always needs a "break-in" Period to get the full flex. The 0-45-90 does not change much.
Old 08-05-2013, 02:26 PM   #4556
hana166's Avatar
Thanks for your reply.. Its proving to be a bit of a black art looking for a combination of bottom and top deck for good handling !
Old 08-05-2013, 04:08 PM   #4557
heretic's Avatar
Exactly what I was hoping for. Thanks !
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 08-05-2013, 05:43 PM   #4558
hotrod1933's Avatar
Default weight
I have a built car (no electrics) at home I will weigh.
give me a day or so.
XRAY T4-15 -- nbhc.com -- powerhouse performance -- sma.org
hotrod1933 is offline   Reply With Quote
Old 08-05-2013, 08:34 PM   #4559
hotrod1933's Avatar
Default Weight
just checked car at home.
508 gms it has graphite arms, ecs, alum steering arms (30 2526 COMPOSITE DUAL SERVO SAVER ARM) and low friction belts. none of which would make a huge difference from stock weight wise.
it's a lot lighter than i thought it would be.
Old 08-06-2013, 01:39 AM   #4560
Hey Richard,
I'm guessing this was at west London?
The track is so bumpy so we are all running more droop to stop this happening. .5mm is all that is needed
Cheers,
Jay
jaywestwood is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
