Old 07-31-2013, 01:55 AM   #4456
Originally Posted by daleburr View Post
Main thing to change is the rear springs, the kit ones are too soft. Run either 2.5 or 2.7 on the rear.
Or if you're on tarmac, run Reflex Racing silvers all round as these are awesome.
The progressive silvers?
Will1/10 is offline   Reply With Quote
Old 07-31-2013, 08:44 AM   #4457
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Yep. Those are a good place to start on asphalt.
Old 07-31-2013, 10:14 AM   #4458
bvoltz's Avatar
Trader Rating: 44 (100%+)
The Silvers from Reflex are progressives, the other set to have, is the Greens (which are also progressives) for the front for higher traction.
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 07-31-2013, 10:19 AM   #4459
bvoltz's Avatar
The setup that is a real good place to start, EA's from the birds. Note that the 2.4 springs should be 2.5, 2.4 are testing springs and did not make it to production. EA Setup
Old 07-31-2013, 06:35 PM   #4460
yodace's Avatar
R/C Tech Charter Subscriber
Originally Posted by Skiddins View Post
If you're running kit, stiffer rear springs would be the first thing I change.
Perhaps try softer oil as well.
would 2.5-2.8 progressives work...
yodace is offline   Reply With Quote
Old 07-31-2013, 08:09 PM   #4461
erchn's Avatar
I found 2.5-2.8 all around to be worse than stock, same or similar traction in front and less direct up front. YMMV.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 07-31-2013, 09:42 PM   #4462
How far can you get with just shock angle, in lieu of spring changes? I'm racing my T4 for the first time this weekend, and have no tuning parts other than shims. I'm starting with the kit asphalt setup. The only spares I have are spool cups, so I hope it lives up to its reputation for durability.
-Mike
Old 07-31-2013, 10:28 PM   #4463
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
I haven't broken any parts since racing my car in February. Only minor shimming up since its developed a bit more slop, but nothing serious. Spool cups started wearing a bit too. I found this car to be very low maintenance. Love it!
Dan is offline   Reply With Quote
Old 07-31-2013, 10:37 PM   #4464
Trader Rating: 27 (100%+)
-Mike
I've found that I get a noticeable amount of change with shock angles, too. It's definitely something to try out.
I'm trying to figure out how to loosen up my T4 as well. Right now I'm running on medium grip carpet and I've got medium roll centers but my shocks are stood completely up, so I've got lots of playing to do.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 08-01-2013, 02:53 AM   #4465
Skiddins's Avatar
It depends on the track and how bumpy it is etc.
I have been running progressives all round on asphalt and found it can make the car more consistent. Then at another asphalt track that was faster and smoother I ran 2.9's with 2.7's
2.7 and 2.5 work well on carpet. If grip comes up enough you could run 2.7 front and rear.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-01-2013, 02:54 AM   #4466
daleburr's Avatar
Lay the rear shocks down a hole or two
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 08-01-2013, 02:56 AM   #4467
Skiddins's Avatar
-Mike
I would definitely buy some springs, they are the easiest thing to change that can make a huge difference.
Quite often I will leave everything else exactly the same and just change springs.
Skiddins
P.S. 90% of my setups have the front shocks in hole 2 and rears in hole 3
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 08-01-2013, 03:50 AM   #4468
rangerjkb's Avatar
Trader Rating: 36 (100%+)
Send a message via MSN to rangerjkb
Skiddins
+1 on the springs. Once you find a great setup that you like the springs, rollcenter blocks, and shims is about all you'll have to change out depending on track conditions and carpet to asphalt requirements. Very durable car!
Jason Burks
Murfdogg Products~Psycho Cells Racing~Hal's Hobby Warehouse~Avid RC~Kal-Gard~VP Powermaster
rangerjkb is offline   Reply With Quote
Old 08-01-2013, 04:43 AM   #4469
chasingthepack's Avatar
matt seems to bethe opposite,he has the rears in 2 and the fronts in 3,im 3 all round but ill be playing around with it this weekend,your back in 13.5 i see,i thought you would have done mod last sunday for the upcoming btcc
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 08-01-2013, 04:55 AM   #4470
Skiddins's Avatar
Didn't know there were going to be any Mod drivers there, so I went with the car set up for 13.5 and left it.
Will be back there next Sunday, will run Mod then (bet no drivers run it!)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
