Old 07-30-2013, 01:39 AM   #4441
Odin544's Avatar
Trader Rating: 93 (100%+)
Originally Posted by yodace View Post
what's a good futaba servo to get?
The Orion servo I have rubs the steering post ...
If you are dead set on Futaba I would suggest the BLS551. The S9551 is good too just lacks the brushless motor of the BLS551.
If you are open to other suggestions I'd suggest the Ko Propo One10. One of the best servos I've ever used.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 07-30-2013, 03:34 AM   #4442
chasingthepack's Avatar
I have a on and off power push. anything I can change that would get rid of this...
I am running the stock asphalt setup with -.75 roll center up front and 42w front and 40 rear oil...
I run outdoor asphalt sprayed with sugar water ...
stick with the -075 on the ff but on the fr use the -00,reducing the caster will help and the anti dive will help when on the brakes,or put a 1mm shim under fr and leave the -75 on
and depending on tyre wear 1deg of camber helps
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 07-30-2013, 04:05 AM   #4443
rangerjkb's Avatar
Trader Rating: 39 (100%+)
Send a message via MSN to rangerjkb
Can you attach your current setup sheet?
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Old 07-30-2013, 05:00 AM   #4444
mac853's Avatar
Questions??
Excuse for all, could you tell me if is necessary to change from composite to aluminum cross pin of NT1 in rear gear diff, but i am sure that i will use in front gear, due is using steel gear of NT1 and steel outdrive .
In fact when i used TRF417 rear diff then recommend me not to use original 1 but to change occasionally due the wear in the joint.
Thanks for reply!
mac853 is offline   Reply With Quote
Old 07-30-2013, 05:10 AM   #4445
esckalayd's Avatar
Thanks for reply!
If i understand your question, the answer is no, you don't need to run the nt1 steel gears and you don't need to upgrade the cross pin. I have a T4 and an NT1 and i only run steel gears in the rear diff of my NT1 with the lightweight cross pins.
Anthony Schimizzi AKA ~The Rookie~
| Serpent America - DeSoto Racing |
esckalayd is offline   Reply With Quote
Old 07-30-2013, 05:15 AM   #4446
esckalayd's Avatar
Default Mod Gearing Question
Mod gearing question? I know the ball park is 8.3, but it seems only the stock 84T 48P gear will work if you want to use 48P. The 84T is pretty close to the bottom of the chassis. That being said i can get away with a 19T and 20T pinion to fall between 8.0-8.4. Do you guys run 64P gears with mod or are you guys running about the same gearing with 48P gears? Also, has anyone tried to fit the 87T 48P XRAY gear on the T4? If so, does it fit, or is it poking out the bottom of the chassis
Old 07-30-2013, 06:32 AM   #4447
Trader Rating: 20 (100%+)
I am able to just fit an 18t pinion with the 84 spur in my car. Normally I run a 19/84 with the 4.5t.
On the T3 2012 you had to dremel just a touch off the top deck to get a 17t pinion on but the T4 top deck doesn't have enough material for me to feel safe taking any off and I have no need to gear that high.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 07-30-2013, 07:34 AM   #4448
Skiddins's Avatar
In 48dp the 86t spur is level with the bottom of the chassis.
I just run an 82t spur for Mod, If I recall, it ends up around 8.2fdr
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 07-30-2013, 09:06 AM   #4449
if i narrow the front track width what/when would i benifit from it? currently i run 2mm ff and 1.5 fr i just changed it to 1.5 ff and .5 fr?
Old 07-30-2013, 09:17 AM   #4450
Xpress's Avatar
I haven't tested that, but I imagine the car would turn in harder and change direction more quickly. Make sure the driveshafts do not bottom out in the drive cups.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 07-30-2013, 09:37 AM   #4451
thanks for the info and no worries there im using 50mm fronts,im lucky to have a nice patch of low grip tarmac outside my house and after a quick play about i believe your right,im finally making some progress with the t4
although im doubting myself a little with that much arm sweep,would it be better with just 1mm ff?
Old 07-30-2013, 11:01 AM   #4452
mac853's Avatar
Sorry for my mistake in writing.
But thanks for you!
Old 07-30-2013, 05:59 PM   #4453
yodace's Avatar
R/C Tech Charter Subscriber
It is basically the kit setup
With -75 roll center in the front
42.5w up front
40w rear
yodace is offline   Reply With Quote
Old 07-30-2013, 06:26 PM   #4454
rangerjkb's Avatar
42.5w up front
40w rear
Shoot me a "pm" with email address and I will forward setup sheet that you can try if you'd like.
Jason Burks
Old 07-31-2013, 01:19 AM   #4455
Skiddins's Avatar
42.5w up front
40w rear
If you're running kit, stiffer rear springs would be the first thing I change.
Perhaps try softer oil as well.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
