Old 07-27-2013, 12:19 PM   #4411
Are you joking about the support of uk based drivers. I'm sponsored by Rcdisco in the uk and I run at Bedworth where there is another 10 xray drivers.
Zak Finlay and James Hart are the main top drivers in the uk and if you went to the top events for like the Brca Clubmans or Nationals there are loads of xray drivers.
If you need a setup sheet to start up with that is quick around a track just pm me and I will send you one.
jordan.norwood@ is offline   Reply With Quote
Old 07-27-2013, 12:46 PM   #4412
reg
"Joking"
Don't think I questioned at the lack of drivers in the uk!
I asked for a forum based for uk drivers for the T4!
reg is offline   Reply With Quote
Old 07-27-2013, 02:57 PM   #4413
chasingthepack's Avatar
Originally Posted by reg View Post
"Joking"
then your already here,its about the best source of info,if you want set up sheets then the xray forum although most are locked,also petit rc has alot of usefull set ups,as for drivers giving you tips good luck the ones that talk are few and far between
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 07-27-2013, 03:12 PM   #4414
reg
Thanks ill have a look at the sites you suggest,
I think you right,
Nothing like a post to make you feel like a pain in the ass!
Old 07-27-2013, 03:14 PM   #4415
daleburr's Avatar
"Joking"
If that's what you're after, you're already there. There are plenty of us here from the uk, racing both indoors and outdoors.
For setups the Xray website is good, with plenty of T4 setups for uk tracks on uk tyres. If I were a carpet racer I'd start with one of James Harts setups from last winter as he had some mega results with the T4 on carpet.
For specific advice and info, ask a specific question and you'll get plenty of advice on here.
Hope that helps! I've raced cars in the past where there has been no forum support from UK drivers, so I know where you're coming from, as getting those last few bits of setup tips really make a difference. Having said that, the best way to get these is to nose around other people's cars at the track, as the devil is in the detail
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 07-27-2013, 06:33 PM   #4416
reg
Thanks Dale,
Some good info,very good to know uk racers are hear and happy to help,
Looking forward to the indoor season with a new ride
Old 07-28-2013, 12:56 AM   #4417
I relocated the antenna mount behind the servo. Now it doesn't get in the way when I need to remove the top deck. My first hole was too close to the top deck, though. So now I have another empty countersunk hole in my chassis. Doh!
I also played around with the steering linkage some more. Apparently I was wrong about tilting towards the top deck. It does seem to give more even throw with less EPA imbalance when it's closer to vertical with a slightly longer link. But I do need to double Check that my tie rods are even. I was centering the rack by eye.
I am still amazed by how light this car is.
-Mike
Old 07-28-2013, 01:39 PM   #4418
Barry_Hughes's Avatar
Hi,
I'm from the uk and thinking of getting a T4 for the coming indoor season,
Just a bit worried about the support over here,
Any uk drivers point me in the direction of a site aimed at the uk based drivers,
Thanks,
Mark
depends what you mean by a site aimed at uk based drivers.
For tips setups help etc there is either this forum or Xrays own forum.
Most clubs have plenty of T4 drivers who will all help you.
As mentioned the Top Xrays Guys like James Hart are very approachable and will happily give advice.
Built it !
Raced it !
Wrecked it !
Last edited by Barry_Hughes; 07-28-2013 at 01:43 PM. Reason: missed posts after the intial one Doh!
Barry_Hughes is offline   Reply With Quote
Old 07-28-2013, 01:43 PM   #4419
Not sure if anyone in here is looking to sell, but I'm looking for a t4, good condition, not warped or crashed to crap, and spare parts. I want to upgrade my t3 2012, and use that chassis for my VTA car and then sell the 2011.
~Xray~RCAmerica~Motiv~Gravity RC~ORCA~
Swift Racing Services, LLC.
JDC Motorsports
Boostinswifty38 is offline   Reply With Quote
Old 07-29-2013, 12:44 AM   #4420
Hey guys
I was wondering what brand oil i can use that matches the kit oil.
I want the 350 in the shocks and 700 in the diff can anyone give me some different brand equivalents as i liked the standard oils a lot.
"No matter if you win by a inch or a mile, winnings winning".
AleD123 is offline   Reply With Quote
Old 07-29-2013, 01:17 AM   #4421
Originally Posted by AleD123 View Post
Hey guys
Why not just buy the Hudy oils in those weights as they are the ones supplied in the kit?
Any other Brand though rated the same might not actually be the same.
Built it !
Raced it !
Wrecked it !
Old 07-29-2013, 01:27 AM   #4422
Skiddins's Avatar
Hey guys
As Barry said, get the Xray oils and then you know you have the same
Skiddins
P.S. Don't know what surface you're running on, but we've found roughly 2000 oil to be the minimum to get good drive out of corners.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 07-29-2013, 04:14 AM   #4423
kermit's Avatar
Originally Posted by Bishop View Post
Anyone got spur size recommendations for 17.5T blinky and 10.5T blinky?, I have every 48p pinion from 15-40 tooth, just have no idea what size spur will be ideal range wise on the T4 I just got, and I'd rather not have to buy a heap to figure out what will work, thanks.
At the AOC I ran 70-72T with 34-36T pinions in 48P for 17.5 blinky. It's a tight fit with the motor screws and takes a bit of messing around to get the placement of the pinion aligned with the spur but not touching the motor screws.
Adelaide RC Team Driver - www.adelaiderc.com.au
XRAY T4 | Futaba | HOBBYWING | Muchmore
kermit is offline   Reply With Quote
Old 07-29-2013, 05:12 AM   #4424
PDR TOO's Avatar
Trader Rating: 24 (100%+)
In 21.5 Blinky we need to go even further. At my home track in Sydney (SMA) we will run gearing up to 64 spur with 43 pinion (48 pitch). As Kermit says, getting the correct mesh without allowing the pinion to rub on the motor screws takes some patience.
SMA .....The Track.
Previously Raced Vehicles keep me on the track - sort of.
PDR TOO is offline   Reply With Quote
Old 07-29-2013, 05:21 AM   #4425
PDR TOO's Avatar
Default Diff Oils
I currently run 1,000 oil in my T4 diff.
What would be the expected outcome of running say 2,000?
SMA .....The Track.
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
