Old 07-25-2013, 10:20 PM   #4396
Odin544's Avatar
Trader Rating: 93 (100%+)
I'm curious about something. Did they make a running change to the servo mount on the T4? I have 2 T4's and on one of the cars the aluminum piece looks just like this (see pic below). On the other it has the small locating nub on both sides. The side that goes against the chassis and the opposite side. Anyone else see this before or did I end up with a part that was machined wrong?
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 07-25-2013, 10:31 PM   #4397
Mine has nubs on top and bottom. Kit was bought in hong kong around the time of TITC.
-Mike
Old 07-25-2013, 10:38 PM   #4398
klaymon's Avatar
Trader Rating: 71 (100%+)
I bought one of mine in December of 2012 and one March of 2013 (both from Amain) and they both have one nub on the bottom. Top is flat.
klaymon is offline   Reply With Quote
Old 07-25-2013, 10:58 PM   #4399
Jerz616's Avatar
Trader Rating: 49 (100%+)
I bought one the week it was released and it only had one. I bought anther one about a mutha ago and it had 2. Also on the second one I bought it had almost all aluminum shims. The first one I bought was mostly composite. So I guess they made a few changes.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 07-26-2013, 12:19 AM   #4400
Early kits have a located on one side, later ones both.
I've had 4 t4 kits now 2 early s and 2 later ones I found my kit changed in the march time.
I preferred the single nub and found the anodising heavier around the nubs base if that makes sense so it doesn't sit flush in the carbon.
I cleaned the join with sand paper
Jampot is offline   Reply With Quote
Old 07-26-2013, 12:22 AM   #4401
Oh and apart from upper link washers and steering servo arm kits come with plastic washers everywhere else
Old 07-26-2013, 02:27 AM   #4402
Skiddins's Avatar
Originally Posted by Odin544 View Post
What ECS's are most people using on carpet tracks the size of IIC? 50mm or 52mm?
Reflex Racing 'Narrow' which are 51mm
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 07-26-2013, 03:06 AM   #4403
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
+1
Old 07-26-2013, 05:54 AM   #4404
sixace's Avatar
Originally Posted by grippgoat View Post
Honest feedback: If background music is still building, and you're still showing random pictures, after 2 minutes, the rest of the video doesn't matter, which is why I closed it and didn't watch it. It needs to be edited way, way down.
Now, could someone point me in the direction of the panty sand extractor?
-Mike
Extraction not required. I appreciate the feedback. I was worried about that and the overall length too. Attention spans are getting shorter and shorter (myself included). It's my second vid (better than first at least) and they can only get better (hopefully).
I do enjoy watching and filming the sedan crew though. They always put on a great show. Hopefully the gang in this thread won't mind me posting sedan content vids here in the future. If not, let me know guys..
sixace is offline   Reply With Quote
Old 07-26-2013, 06:00 AM   #4405
Jerz616's Avatar
I like it Dan. Gives me something to look back at and watch how bad I am.
Ryan Gracey
XRAY XB8'14
Old 07-27-2013, 07:23 AM   #4406
Bishop's Avatar
Anyone got spur size recommendations for 17.5T blinky and 10.5T blinky?, I have every 48p pinion from 15-40 tooth, just have no idea what size spur will be ideal range wise on the T4 I just got, and I'd rather not have to buy a heap to figure out what will work, thanks.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 07-27-2013, 07:57 AM   #4407
Regional Moderator
CarbonJoe's Avatar
In 64p, 96 tooth spurs are popular for 17.5. Around 3.8 FDR, so 48 tooth pinion.
So, in 48 pitch, 72 spur, and 36 pinion.
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 07-27-2013, 12:44 PM   #4408
reg
Hi,
I'm from the uk and thinking of getting a T4 for the coming indoor season,
Just a bit worried about the support over here,
Any uk drivers point me in the direction of a site aimed at the uk based drivers,
Thanks,
Mark
reg is offline   Reply With Quote
Old 07-27-2013, 12:51 PM   #4409
chasingthepack's Avatar
Originally Posted by reg View Post
Hi,
Thanks,
Mark
you cant beat nick for t4 support
http://demonpowerproducts.co.uk/
or kev at
http://www.modelcarsreading.com/
both are racers so will understand what you need
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 07-27-2013, 01:13 PM   #4410
reg
Thank you,
Sorry for not being to clear,I ment more forum based support,
It's always helps getting build tips and info regards to the brand off this site,but when I start racing I want up be able to get info from people running on the same as me
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 02:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 03:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
SEO by vBSEO 3.5.0
