Old 07-16-2013, 01:01 PM   #4351
Skiddins's Avatar
Originally Posted by hyujmn View Post
Did you adjust subtrim to straighten out the servo?
Take the servo horn off, and rotate the small spline adapter round the servo output slightly, now try putting the servo horn on again.
I kept rotating mine onto the next spline until it was almost dead vertical with centered trim.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 07-16-2013, 03:31 PM   #4352
rosko's Avatar
T4 2014 im ready. Be nice if its here by sept.
rosko is offline   Reply With Quote
Old 07-16-2013, 03:39 PM   #4353
Odin544's Avatar
Trader Rating: 93 (100%+)
I would guess after IIC...(mid-late Oct)
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 07-17-2013, 05:16 AM   #4354
Does anyone have a set up for west london (Hot weather) would be greatly appreciated
Nathan
Nathan Wilson is offline   Reply With Quote
Old 07-17-2013, 05:38 AM   #4355
tc3team's Avatar
T4 arrived yesterday
No chance to build it until the start of next month but I have heard of people not using the oring in the diff without any problem? (the xray o ring is prone to stretching/going out of shape).
So, should I build them with or without the rings, as I think I may need to make some diff oil changes in the near future once I've had a shakedown with it.....
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 07-17-2013, 05:49 AM   #4356
Skiddins's Avatar
Don't bother with the main o-ring, just make sure you fit the gasket properly.
I also 'seal' around the output o-rings with some thicker silicone grease to help prevent friction on them as well as helping to seal the diff.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 07-17-2013, 05:52 AM   #4357
tc3team's Avatar
Skiddins
Thanks for the heads up.
I was a bit nervous not fitting the orings as I will be running double diffs, and they are not exactly cheap lol
Old 07-17-2013, 05:55 AM   #4358
Trader Rating: 16 (100%+)
thoughts on the new closed layshaft bulkhead?
http://www.teamxray.com/teamxray/sho...e387527b8971a1
Tekno: NT48, ET48, EB48, SCT410
Xray: 2 XB9E, XB9, XT9 E, XB8 E 2014, 808E, 2 T4, XB4, XB4 2015
Losi: SCTE 2.0, 8T 3.0E, 2 8T 2.0E, Mini8T, 2 Mini8,
Mullet1 is offline   Reply With Quote
Old 07-17-2013, 09:57 AM   #4359
chasingthepack's Avatar
itll be a right pain to change a spur gear
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 07-17-2013, 10:02 AM   #4360
erchn's Avatar
Well, you already have to take off the top deck which ~10 screws, 3 screws out of the spur itself, mess with belts, etc... This is just two more screws for the right side bulkhead.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 07-17-2013, 10:09 AM   #4361
Xpress's Avatar
It's not that bad. You'll just have to remove an additional two screws from the bottom of the right side layshaft mount to change the spur.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 07-17-2013, 10:35 AM   #4362
ok point taken,are there any benefits to losing the td screws ,or when would you want to take them off?
Old 07-17-2013, 10:44 AM   #4363
erchn's Avatar
I've not tried it, but according to the graphic, low grip or extremely high grip.
Old 07-17-2013, 01:05 PM   #4364
Skiddins's Avatar
Although the bearings can't move around, the layshaft mounts do allow a small amount of twisting when the layshaft is in position.
That is, the layshaft won't move out of mesh, but also doesn't 'lock' the two sides solidly, so it allows some chassis twist.
I found it made my car more consistent (screws removed) at my local track in Mod.
I haven't had a chance to run it in my usual 13.5 boosted class yet.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 07-18-2013, 01:38 AM   #4365
Skiddins
would you say wlrc had high grip levels recently?
just curious,i have tried removing the forward 2 screws but couldnt feel any difference and lap times stayed the same at amcc,im trying to get the rear toe down to 2.5 or 3 from 3.5 but i cant get it around the sweeper as fast with less toe
so really im looking for other solutions to rear grip,rear tyre wear isnt an issue but im killing fronts within 2 runs and still have a small amount of push in the slower corners which if im right losing some rear toe will help with mid /exit steering
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
